Low Power IoT Design Challenge
  • Low Power IoT Design Challenge
Documents Low Power IoT - Design Challenge
  • Author Author: e14phil
  • Date Created: 7 Jun 2021 1:40 PM Date Created
  • Last Updated Last Updated: 23 Aug 2021 5:05 PM
  • Views 14050 views
  • Likes 20 likes
  • Comments 34 comments
About this Challenge | Dates | The Judges | The Kit | The Prizes | Technical Resources | Example Application | Terms & Conditions | The Challengers
Join us, in collaboration with Infineon, for the Low Power IoT Design Challenge with the PSoCTm 6S2 + AIROCTm Wi-Fi/Bluetooth Pioneer Kit !
Make IoT work in industry, using Infineon’s low-power compute, connectivity, and sensing technology!
The Challenge
The element14 Community is pleased to introduce the Low Power IoT Design Challenge, in partnership with Infineon Technologies.
So many different applications in industrial and enterprise environments can benefit from lower-power and easier-to-use embedded solutions. From remote monitoring of raw materials, to battery-backed sensor hubs on a factory floor, no company wants to spend money, time, and operational bandwidth to service devices that are energy inefficient. Add in the design issues that come with optimizing system power, implementing analog and digital sensor processing, integrating security, and connecting to the cloud or mobile applications.
Infineon Technologies is deeply committed in its effort to “Make IoT Work.” That means giving developers like yourselves the right hardware platform to build smart, energy-efficient, and secure IoT systems, along with an easy-to-use, flexible, and complete software to bring your ideas to life.
That is why for this Design Challenge, Infineon and element14 are inviting you to use the PSoCTm 6S2 + AIROCTm Wi-Fi/Bluetooth Pioneer Kit (CY8CKIT-062S2-43012) , along with the ModusToolboxTm Software Environment, to build a low-power IoT device. Optimize power in a cloud-connected predictive maintenance module on a production line, extend the battery life of a rugged device technicians would wear to get smart alerts, detect human presence in a smart building doorway using a coin-cell powered sensor node, and more, the possibilities are endless. We can’t wait to see what you come up with!
20 successful applicants will receive the PSoCTm 6S2 + AIROCTm Wi-Fi/Bluetooth Pioneer Kit (CY8CKIT-062S2-43012) to build and blog their project with.
For the chance to win one of the prizes below, you must build your low-power project using the kit above and the ModusToolboxTm.
We aren’t necessarily defining “low-power” parameters, as it varies greatly in different applications, and we want to give you the creative agency to do what is best for your design. We have lots of enablement to help optimize system power (see technical resources below), as well as to implement features such as CapSense capacitive-sensing, graphical displays, machine learning, and much more (again – see resources below!).
Example applications could include:
  • Factory Automation Sensor Hub
  • Predictive Maintenance Module
  • Human Presence Detection
  • Fall Detection Device
  • Cloud-Connected Robot
  • Air Quality Monitor
The Sponsored Kit The Specs
Buy NowBuy Now
• Ultra-low-power PSoCTm 62 MCU that integrates an ArmRegistered CortexRegistered-M4 and Cortex-M0+ onto a single chip and provides up to 2 MB of Flash and 1 MB of SRAM
• The Murata 1LV Module hosting the ultra-pow-power Infineon AIROCTm CYW43012 802.11 b/g/n Wi-Fi + Dual-Mode Bluetooth combo chipset radio
• CapSense capacitive touch sensing enabled buttons and sliders
• PSoC 5LP MCU for program/debug
• ExcelonTm-Ultra 4Mbit 108-MHz QSPI nonvolatile F-RAM in an 8-SOIC package
Suggested Accessories
These are not part of the sponsored kit, but have been highlighted by Infineon as compatible components that could help you out in this challenge.
Suggested Accessories Buy AllBuy AllThe Specs
TLV493D 3DSense Shield2Go Add-On Board
(S2GO_3D-SENSE_TLV493D)
Infineon’s Shield2Go boards offer a unique customer and evaluation experience – the boards are equipped with one Infineon IC. Customers can now develop their own system solutions by combining Shield2Go boards together with Infineon My IoT adapters. All Shield2Go boards share a common pin out design, i.e. pins are hard coded to specific functions like SPI or I2C. This enables a generic PCB evaluation board design for Infineon’s portfolio like the DPS310 Pressure Shield2Go, the TLV493D-A1B6 3DMagnetic Shield2Go, the TLI4970-D050T4 CurrentSense Shield2Go or the OPTIGATm Trust E and X Security Shield2Go.
Buy NowBuy Now
Infineon’s 3D magnetic sensor TLV493D-A1B6 offers accurate three dimensional sensing with extremely low power consumption. Within its small 6-pin package the sensor provides direct measurement of the x, y and z magnetic field components, making it ideally suited for the measurement of 3D movement, linear travel, and 360° angle rotation. Infineon’s S2Go_3DSense_TLV493D boards offer a unique customer and evaluation experience
IM69D130 Microphone Shield2Go Add-On Board (S2GOMEMSMICIM69DTOBO1)
Buy NowBuy Now
Infineon’s IM69D130 MEMS Microphone supports a dynamic range of 105dB with a signal to noise ratio of 69dB(A) SNR, <1% total harmonic distortions up to 128 dBSPL, and acoustic overload point at 130dBSPL. Infineon’s Shield2Go boards offer a unique customer and evaluation experience – the boards are equipped with two high-performance digital MEMS Microphones (IM69D130).
DPS310 Pressure Shield2Go Add-On Board (S2GOPRESSUREDPS310TOBO1)
Buy NowBuy Now
Infineon’s DPS310 barometric pressure sensor supports ultra-high +/-0.005 hPa resolution (equating to +/-5 cm), very good temperature stability due to a linear temperature dependency, and relative accuracy ±0.06 hPa, as well as an integrated FIFO that can store up to 32 pressure/temperature measurements, which enables energy savings on system level. Infineon’s Shield2Go boards offer a unique customer and evaluation experience – the boards are equipped with one DPS310 barometric pressure sensor.
TLI4970 Current Sense Shield2Go Add-On Board (S2GOCURSENSETLI4970TOBO1)
Buy NowBuy Now
The TLI4970 is a high-precision current sensor based on Infineon´s proven Hall technology. The coreless concept significantly reduces footprint compared with existing solutions. It’s an easy-to-use, fully digital solution that does not require external calibration or additional parts such as A/D converters, OpAmps, or reference voltage. Infineon’s S2Go_CurrentSenseTLI4970 boards offer a unique customer and evaluation experience – the boards are equipped with one TLI4970 current sensor.
Be Rewarded on the Community
For entering and taking part in the Design Challenge competition, you'll be rewarded the following badges:
imageApply to join the Design Challenge and receive a badge and points for applying! Make sure you've thought your application through, made it original and your own work. If you are building upon someone else's work, make sure you cite your sources. Direct copies of work will not be accepted.
imagePost your first blog! We expect updates on how your Design Challenge project is going, so don't hold back, tell us your thoughts, difficulties, and how you're progressing. Remember that you're assessed based upon your updates, and don't be afraid - other challengers and members are there to help you with any problems you have, and it helps the staff to keep an eye on you!
image5 blogs! Wow, has it really been that long? We hope you'll keep us updated about your project at least once every two weeks, for 10 weeks. We'll not be impressed if you only put a one-liner in there, that's what messages are for. Blogs are to make sure you're giving us all of the juicy detail, trials and tribulations of what's going on, and it keeps everyone honest!
imageEven if you're not a challenger in the Design Challenge, we appreciate every member who joins in and gives a helping hand to applicants and members. If your messages are found to be helpful, we want to acknowledge that and reward you!
The Prizes
PrizePrize Category
grand prize
Grand Prize*
  • 11” Apple iPad Pro, 128GB, Wi-Fi
  • Solar Powered Charger
runnerup prize
Runner Up*
  • Apple iPad Mini, 64GB, Wi-Fi
finisher prize
Finisher Prize
Multicomp Digital Multimeter
*Or local equivalent
The Judges
Infineon
Technical Judge Team
logo
element14 Community Judges
element14 Community Team
Need help? Comment and read the resources below:
Technical Resources:
Hardware:
  • PSoCTm 6S2 + AIROCTm Wi-Fi/Bluetooth Pioneer Kit (CY8CKIT-062S2-43012) User Guide
  • PSoC 62 MCU (2MB Flash, 1MB SRAM) Datasheet
  • CYW43012 802.11n / 802.11ac-FriendlyTm Ultra-Low-Power Radio Chipset Datasheet
  • Murata Type 1LV Wi-Fi/Bluetooth Module (hosting CYW43012) Datasheet
  • All PSoCTm 6 MCU Technical Documentation
    • App Note: PSoC 6 MCU Low-Power Modes and Power Reduction Techniques (use content for architecture/conceptual learnings, low power code examples below)
    • Low Power Middleware Library Documentation: Low Power Assistant (LPA) for FreeRTOS
Software:
Infineon’s ModusToolboxTm is a set of easy-to-use multi-platform software development tools and a comprehensive suite of GitHub-hosted firmware libraries providing a high-quality experience for developing your IoT applications with Infineon PSoCTm 6 MCUs and AIROCTm Wi-Fi / Bluetooth LE wireless connectivity. Unlike traditional IDE-centric approaches, ModusToolbox provides powerful standalone tools like our easy-to-use configurators and leaves the choice of compiler, editor, debugger, and revision control system up to you.
  • ModusToolbox Software and Tools Informational Page
    • Download available on this page for WindowsRegistered, macOSRegistered, and LinuxRegistered
  • For PSoCTm 6 and Wi-Fi MCU development in ModusToolbox, start here!
    • All ModusToolbox Software Environment Documentation
  • ModusToolbox Software Code Examples GitHub Repository
    • Low Power code examples to get started with quickly:
      • mtb-example-psoc6-switching-power-modes
      • mtb-example-psoc6-low-power-capsense-freertos
      • mtb-example-psoc6-low-power-sar-adc-thermistor-als
      • mtb-example-psoc6-low-power-analog-front-end
      • mtb-example-anycloud-offload-tcp-keepalive
      • mtb-example-anycloud-wlan-lowpower
      • mtb-example-anycloud-ble-battery-server
The Dates
Project Phases
Dates
CURRENT PERIOD:
Build Period
27th August - 5th November 2021
Projects Due5th November 2021
Winners AnnouncedNovember 2021
Prizes ShippedNovember 2021
The Terms
Selected official applicants will be chosen to receive the "Kit" listed above. These successful applicants will be our sponsored challengers, and they must use the PSoCTm 6S2 + AIROCTm Wi-Fi/Bluetooth Pioneer Kit (CY8CKIT-062S2-43012) within their project, and publish their final code and designs on the element14 Community for others to use. Those not chosen as sponsored challengers may also join the competition, but they must base their projects around the kit listed above OR another PSoC 6 Kit and adhere to all terms and conditions of the challenge.
They need to post their progress and final project as at least 5 blog posts before the closing date (see above) when projects are due.
Posts which are media rich with photos, videos, and code samples will be viewed more favorably in the judging process.
Please read the full terms and conditions of the challenge, attached below.
Ready to join the challenge? Then Apply Here!
If you are not successful in becoming a sponsored challenger but still want to enter, all you need to do is use the Kit as described above in your project and adhere to the same Terms and Conditions for a chance to be our winner! Non sponsored challengers are eligible for the Finisher and Winner Prizes as well.
imageLow Power IoT Design Challenge Terms Version 2.pdf
  • infineon
  • design_challenge
  • low_power_iot
  • e14phil
    e14phil over 5 years ago +9
    Very interesting question misaz vlasov01 Let me speak to the sponsor and see if they want to expand the definition of which boards are in the T&C. A core part of this challenge is using the Modus Toolbox…
  • e14phil
    e14phil over 5 years ago +8
    Update to the Terms and Conditions After discussing it with Infineon we are happy to allow challengers who already own a PSoC 6 series kit to enter this challenge. "Sponsored Challengers Selected official…
    Jan Cumps over 5 years ago in reply to Jan Cumps +7
    Some more inspiration: The AnyCloud: WLAN low power example that's available in ModusToolbox shows how you can save energy on an active TCP WiFi connection. It uses the same Low Power Assistant that I…
  • kurst811
    kurst811 over 5 years ago
    Can you give us update on who got selected for the challenge ?  e14phil
  • vlasov01
    vlasov01 over 5 years ago in reply to kurst811
    I think the main reason with the delay are problems in supply chain. This board is out of stock at this moment. Probably some components are not available to manufacture this board. Just look at the announcement from Toyota today. It cuts global production by 40% due chip shortages. It is an on uncharted territory for the business.
    The good indicator when challenge will be started is the availability of this board at Newark/Avnet. You can click a button buy now and it will show the availability.
    Obviously it will be great to hear when the challenge may start as we can commit to other endeavors meanwhile.
  • vlasov01
  • sferenci
    sferenci over 5 years ago in reply to vlasov01
    If the contest has to be delayed due to a part shortage, you would think an inventory would have been secured before rolling out the competition. The application dates were extended to encourage more entrants and have more people commit their time to this endeavor.  Each individual who submitted an application devoted personal time to this project.  It is not an unreasonable request to ask the organizers to provide an update, since we should already be building the project under the original timeline.
  • misaz
    misaz over 5 years ago in reply to vlasov01
    Board is availaible on official Cypress store (https://www.cypress.com/documentation/development-kitsboards/psoc-62s2-wi-fi-bt-pioneer-kit-cy8ckit-062s2-43012 ) and it is also availaible at farnel and other distributors so I think this is not an significant issue in this case. Selecting chalengers/winners always take some time because they must read lot of applications and evaluate them. Usualy it takes about week or two so I recommend just wait.
