Make Life Accessible
  • Make Life Accessible
Blog EyeLiner - Post 3 - Installing OpenCV
  • Author Author: amgalbu
  • Date Created: 25 Apr 2016 10:22 AM Date Created
  • Views 1122 views
  • makelifeaccessible
  • make life accessible
  • python
  • eyeliner
  • opencv
  • accessibility_projects
  • make_life_accessible
amgalbu
amgalbu
25 Apr 2016
Previous posts
Post 1 - Introduction
Post 2 - Installing OpenCV - Prerequisites
At this point we have all of our prerequisites installed, so let’s grab the 3.1.0  version of OpenCV from the OpenCV repository.
$ cd ~
$ wget -O opencv.zip https://github.com/Itseez/opencv/archive/3.1.0.zip
$ unzip opencv.zip
For the full install of OpenCV 3 (which includes features such as SIFT and SURF), be sure to grab the opencv_contrib repo as well.
$ wget -O opencv_contrib.zip https://github.com/Itseez/opencv_contrib/archive/3.1.0.zip
$ unzip opencv_contrib.zip
The first step in setting up Python for our OpenCV compile is to install pip , a Python package manager:
$ wget https://bootstrap.pypa.io/get-pip.py
$ sudo python get-pip.py
we can install NumPy, an important dependency when compiling the Python bindings for OpenCV. NumPy downloads and installs will take a while...
$ pip install numpy
We are now ready to compile OpenCV.
$ cd ~/opencv-3.1.0
$ mkdir build
$ cd build
$ cmake -D CMAKE_BUILD_TYPE=RELEASE \
 -D CMAKE_INSTALL_PREFIX=/usr/local \
 -D INSTALL_C_EXAMPLES=OFF \
 -D INSTALL_PYTHON_EXAMPLES=ON \
 -D OPENCV_EXTRA_MODULES_PATH=~/opencv_contrib-3.1.0/modules \
 -D BUILD_EXAMPLES=ON ..
Now that our build is all setup, we can compile OpenCV:
$ make -j4
The -j4  switch stands for the number of cores to use when compiling OpenCV. Since we are using a Raspberry Pi 2, we’ll leverage all four cores of the processor for a faster compilation.
However, if your make  command errors out, I would suggest starting the compilation over again and only using one core:
$ make clean
$ make
Using only one core will take much longer to compile, but can help reduce any type of strange race dependency condition errors when compiling.
Assuming OpenCV compiled without error, all we need to do is install it on our system:
$ sudo make install
$ sudo ldconfig
Provided build finished without error, OpenCV should now be installed in/usr/local/lib/python2.7/dist-packages :
$ ls -l /usr/local/lib/python2.7/dist-packages/
Let’s verify that your OpenCV installation is working by importing cv2 , the OpenCV + Python bindings:
$ python
 >>> import cv2
 >>> cv2.__version__
 '3.1.0'
You can see a screenshot of my terminal below, indicating that OpenCV 3 has been successfully installed:
    DAB over 10 years ago +1
    Nice detailed post. I will probably try OpenCV on my PC first before trying to use it on my RPi. DAB
  • Workshopshed
    Workshopshed over 10 years ago +1
    Useful tip on the -j4 parameter. That might have been helpful on my dragonboard compile of OpenCV.
    Nice detailed post.
    Nice detailed post.
