Path to Programmable 3
  • Path to Programmable 3
Blog Blog 2: Getting Started with Vivado |Path to Programmable 3| Part 1|
Join Path to Programmable 3 to participate - click to join for free!
  • Author Author: prashanthgn.engineer
  • Date Created: 25 Jul 2023 9:10 PM Date Created
  • Views 1770 views
  • Likes 8 likes
  • ultra96v2
  • design challenge
  • element14
  • AMD XILINX
  • soc
  • xilinx
  • fpga
  • vivado
  • axi
  • prashanth kumar g n
  • Ultra96-V2 Board
  • Block Design
  • Path to Programmable III
25 Jul 2023
What is Vivado
  • IDE to Synthesize and Analysis of HDL/Verilog Language
  • A single tool to Write, Compile, Simulate and Program
Hardware Training Summary
Lesson 2: The Case for a System-on-Chip
Case for SoC : Why do we need SoC
  • Processor utilization > 90%
  • Quelength > 2
  • Multi Proc System, Time >50%
  • Intensive recurring task :
Effect of Poor Performance Processor
  • Data Latency
  • Delayed interrupt handling
  • Lowered data throughput
  • Sequential processing limits performance : Parallel Processing is Efficient
  • Parallel processing can be done using FPGA
  • FPGA Needs central controller and Memory management : Dual Chip Solution needed
    • External FPGA and Processor Requires to be connected Externally
  • Solution is to combine FPGA and SoC in Single Chip
  • Processing System : ARM Quad core A53  and Dual core R5
    • DRAM, Flash, SD for memory interface
    • SPI, i2C, UART, Gigabit Ethernet, SATA, PCIe
    • PL can be used to provide Custom Peripheral Interface
    • Common and Custom accelerator
    • 1.5GHz with 13800 DIMPS performance
  • Zynq Ultrascale Architecture - From Datasheet
  • Optimised and Simplified HW/SW partitioning
    • Hw acceleration enables scaling SW performance to address many applications
    • Low latency interfacing for efficient co-processor implementation and high throughput data transfers.
    • C application can be Run at A53 and R5 Processor
    • HDL can Run at  PL
  • Hw handles heavy data path algorithms
  • SW controls and updates the algorithms
  • Intensive recurring tasks can be embedded through adaptive algorithms
Advantage of using an a Soc in system level
  • Reduced power reduction
  • Reduced latency
Hardware software Codesign Flow
  • Processor boots first like an ARM based Soc
  • PL Can be left unconfigured while developing the real HW
  • PL can be programmed through JTAG
Security Features
  • ARM Trust Zone
  • PS to PL Data can not be snooked externally
  • Encryption and crypto accelerators
  • Key Rolling
SW and HW Design Methodology
Block Based Design Methodology for Rapid HW Design Flow
LAB 1
{gallery}Lab 1
Vivado IDE installed on Windows 10
Create a New Project
Assign a Project Name
Select RTL Project
Currently New Project, No need to add any Resource
Select the Zynq Ultrascale+ Device used in Ultra96 Board
Click Finish
Creating the Project
Click on Create Block Design and Give Default name
Wait for the tool to load the Block Design windows
Click on + to add Zynq Ultrascale+ IP Block
imageREPLACE THIS TEXT WITH YOUR IMAGE
Zynq Ultrascal+ IP block
Block Design
Select UART1 IO configuration: Select the respective MIO Pins to be connected.
UART1 being configured
Baud rate can be Hardcoded
SOC Clocking
PS REF clocking
DDR memory Configuration
Design validation
Creating HDL Wrapper : Vivado Create a Basic HDL code :
IP Block Design eases the HDL Files creation : No need to scratch our head to create the base HDL Files
Bits Stream generation
End of Lab1
Lesson 3: Zynq MPSoC Processor Overview:
  • Zynq MPSoC PS Blocks
    • Quad Core A53, Dual Core R5
    • Arm Mali GPU
    • Security UNit
      • TrustZone
      • Encryption
      • V/T Monitor
    • Platform Unit
      • Power & System management
    • DDR Controller
      • DDR4/3/3L LPDDR4/3 controller
      • 256KB OCM with ECC
    • High Speed Connectivity
      • DP, USB3.0, SATA, PCIE Gen2, PS-GTR
    • General IO Connectivity
      • Gigabit Ethernet, CAN, UART, SPI/QSPI, NAND, SD-eMMC
    • AXI,Clocks and Reset Interfaces
Power Architectures
  • 4 Power Domines
    • LPD
    • FPD
    • PLPD
    • BPD
  • Explanation on A53
    • Supports 2.3DMIPS/Mhz and upto 1.5Ghz operation.
    • Emploes Harward architecture with 64-bit data and instruction set.
  • ARM Cortex-R5 Processor
    • Dual Core 600MHz
    • 67/2.02/2.45 DIMPS/MHz
    • IEC 61508 and IEC26262 - Functional Safety Standards
    • Supports Lock Step Cores
    • ARMv7-R with HW FPU
    • For Real Time applications, redundant core operations
  • Cache Coherence : uniformity of Data being stored at Multiple Cache Locations
    • Multi Level L1 - Fastest and Limited Size, L2 - Faster - Larger Size
    • Layered above the memory
    • Snoop Control unit
      • Migrate modified Data in one L1 Cache to another
      • Process ACP(accelerator coherency port) Transactions
    • Cache coherent interconnect
      • Connects APU, TCU, IOs, Core Switch
      • A central element connects multiple units
      • APU transactions pass though CCI on ACE - AXI Coherency Extensions
      • Full and IO coherency levels
    • DDR3, 3L, 4, LPDDR3 and LPDDR4 Modes : Up to 32G Memory capcity
    • Up to 2400 Mb/s or MT/s
    • 32 and 64 Bits configuration with ECC will be additional 8 Bit
    • 5 AXI ports at 128 Bits and 1 at 64 Bits
  • Zynq MPSoC PS PL interfaces - 12 Independent Ports
    • ACP 128/64 bit ps Slave
    • X4 high Performance 32/64/128bit PS Slave
    • X2 High performance Coherent(HPCx) PS Slave
    • X1 AXI Extension PS Slave
    • X2 high Performance PS Master port for FPD Masters
    • X1 high Performance PS Master Port for LDP Master0
    • X1 LPD Slave
  • Zynq MPSoC Clock Generation Module
    • One Primary clock Inputs and 4 Alternative inputs
    • Generates clocks for APU, RPU, IOU, DDR
    • PS_CLK - 27-66MHz : 33.33 MHz Recommended
    • 4 GP Clock outs are generated - Frequency can be set accordingly
    • clock Group
      • Main clock Groups - Support LDP and FPD
      • Secure Clock Groups - Internal 200MHz clock for CSU
      • RTC Clock Groups for RTC 32 KHz
      • Interface clock groups - Peripheral clocks and PL clocks
LAB2: PS Configuration Part 1 - HelloWorld
https://youtu.be/_22Oq8HVsKk
Please feel to provide your comments and feedbacks.
The Learning with Element14 Community continues...
Regards
Prashanth Kumar G N
  • prashanthgn.engineer
    prashanthgn.engineer over 3 years ago in reply to vishnu123
    Thank you vishnu
  • vishnu123
    vishnu123 over 3 years ago
    Mind blowing information & presentation in video. Helps to understand from scratch.
    prashanthgn.engineer over 3 years ago in reply to Murulidharlm
    Thank You Murulidharlm
  • Murulidharlm
    Murulidharlm over 3 years ago
    I am Eagerly waiting for your hardware training blog, Your blog looks different than others, I like your way of presentation, keep going...!
