Path to Programmable 3
  • Path to Programmable 3
Blog Blog 3: Getting Started with Vivado |Path to Programmable 3| Part 2
Join Path to Programmable 3 to participate - click to join for free!
  • Author Author: prashanthgn.engineer
  • Date Created: 26 Jul 2023 12:03 AM Date Created
  • Views 1924 views
  • ultra96v2
  • Zynq DMA
  • tcl scripting
  • element14
  • AMD XILINX
  • avnet
  • ultrascale+
  • vivado
  • Ultra96-V2 Board
  • ultra96-V2-G
  • amd
  • Path to Programmable III
  • mpsoc
  • vitis
  • programmable
26 Jul 2023
Hardware Training Summary
Lesson 4: Peripherals
Zynq MPSoC General connectivity
PS IO : MIO only
  • Qual SPI
  • NAND
  • GEM - Gigabit Ethernet
  • USB2.0 through ULPI interface
  • GPIO : 0-2 Bank
EMIO/EMIO Possibility
  • SD/SDIO/eMMC
  • Control Area Network
  • I2C
  • UART
  • SPI
  • Trace
  • Software Watchdog
  • GPIO - EMIO also can be used
only EMIO
  • GEM as GMII
  • UART modem Signals ( CTS,. RTS, etc)
High Speed PS Peripherals : Configurable GTR Transceiver interfaces
  • PCIe Gen2 : to x4
  • SATA : to 2 Ports
  • Display Port
  • USB3.0
Interconnect matrix used to determine connection.
All interfaces are configurable through I/O configuration window.
Assign them to necessary MIO Pins
Zynq MPSoC Memory Map
Vivado Assigns address for PL based designs Automatically.
LAB 3 : PS Configuration Part 2 MIO Peripherals
Experiment 1: Enable and Map all PS Peripherals
{gallery}Lab3 : Experiment 1
SD0 and SD1 Interface selection
I2C0 and GPI, GPO interface selection
SPI and UART interface Selection
GPIO MIO, SWDT and TTC interfaces
High Speed Port Selection : DP : GTR lanes 0-1, USB 3.0 - GTR Lane 2, USB3.0 GTR Lane 3
Experiment 2: Set the PS Clocks
{gallery}Set the Clocks
Set the Input Clocks
Set the out Put clock : PLL modes
PLL Settings
Validate the Block Design
Reset the output parameters
Generation of output Parameters
Bistream Generation
Experiment 3: Create and Run Test Applications
{gallery}Memory Application
Opening the Platform Project
Hello World Application
Memory Application Test Passed
https://youtu.be/D-4nNUPAGAA
Peripheral test
Lesson 5: The Power of Tcl
What is TCL ?
  • Tool Command Language
  • unite command Languages in all sort of EDAs
  • TCL is Open Source !!!
  • Download & Install Tcl | ActiveState : TCL Webpage
General instruction to TCL
  • For Rapid Prototyping
  • Scriptiong Application
  • Run TCL Commands for any automated process
  • Walk through TCL Commands
  • TCL can be used to create a Block Design
LAB4 : Using TCL in Vivado Embedded Designs
{gallery}TCL
TCL Script
TCL Script -2
Lesson 6: Merging the Processing Subsystem (PS) and Programmable Logic (PL)
AXI Ports
AXI Port Types Qty
Full Power Master Domine Ports 2
Low Power Domine Master part 1
Low Power Domine Slave part 1
High Perfomance Coherent Slave ports 2
High Performance Slave Ports 4
Accelerator Coherency Porst ACP 1
Accelerator Coherency Extension Port  1
Total 12
  • AXI Types: Master and Slave modes only
  • Master to master cannot be connected: only unlike Ports can be connected: Master to slave
  • Full duplex communication from Master to Slave AXI Bus
  • Five AXI Channels
    • Read Address
    • Read Data
    • Write address.
    • Write data
    • Write Response
  • Up to 16 Master and 16 Slaves
  • 32~256 Bit data Width
  • Dedicated oqn clock Domine for master and Slave
AXI Smart interconnect
  • 16 Master -Salve
  • 32~1024 Data bits
  • AXI protocol compliant
  • only Round Robin Arbitration
AMBA BUS : Advanced Microcontroller BUS architecture
AXI Follows Handshakes READY/VALID
AXI4-Lite
  • Lite weight
  • Design tradeoffs- No burst, No ID, 32/64 Bits only
Source : https://semiwiki.com/wp-content/uploads/2020/01/AMBA-history.png
AXI Stream
  • FPD/LPD supports 32/64/128 Bit Data bus
  • LPD Burt Length is limited to 16 Bits only
  • LPD enables Direct access to PL!!! - Like Block RAM and DDR
High performance Slave AXI
  • High bandwidth Master to Slave Data
  • Access to Memories like DDR, OCM, TCM
  • x4 128/64/32 Bit Configuration
  • Smooth Long Latency event
  • Low latency path for DDR, OCM, TCM
More info available on Zynq Ultrascale+ technicial Reference Manual : Zynq UltraScale+ Device Technical Reference Manual (xilinx.com)
LAB 5 : Adding a PL Peripheral
https://youtu.be/yCUj-xQ5exI
{gallery}My Gallery Title
AXI BRAM IP and Connection Automation
Block RAM Generator IP
Zynq Ultrascale+ MP SoC IP : Enabling AXI Master Interface
Connection Automation for AXI Bus
BitStream Generated
Lesson 7: Zynq DMA Controller
  • What is DMA : Direct Memory Access :  IOs can access memory directly without CPU involving.
  •  DMA is the effective way to connect between PS and PL
Data Path
  • Data from Slave AXI to  Slave Interconnect though FPD Main Switch
  • Passs though CCI to L2 cache
  • from L2 to DDDR DRAM
  • FPD and LPD move data between DDR, OCM and Slave PL Peripherals
Additional DMA Controllers included in below peripherals
  • PCIe Gen2
  • SATA
  • Display Port
  • Gigabit Ethernet
  • USB3.0/2.0
  • SD/SDIO/eMMC
  • QSPI
Lab 6 Improving Data flow between PL and PS utilizing PS DMA
{gallery}Lab 6
Adding DMA Application
BRAM to DRAM Application Stuck
DRAM to DRAM is passing
Lesson 8: Creating Custom IP
  • IP Packers includes
    • Source Files
    • Simulation Models
    • Example Design
    • Documentation
    • Test bench
  • Wizard in Vivado to create an IP!!!
  • IP Package creates HDL Source
LAB 7 : Add Custom PL Peripheral
{gallery}Creating the IP
Creating the IP
Creating the AXI Pheripheral
Adding AXI
IP Created available in catalogue
Lesson 9: Vivado's Hardware Manager
FPGA Design is an iterative Process.
ILA : Integrated Logic Analyzer
VIO 3.0  : Vivaldo native Virtual input and Output
JTAG to AXI 1.2
Lesson 10: Tcl Scripting and Next Steps
  • Allow for easy share of Project
  • TCL build projects in minutes
the Learning with ELement14 will continues..
Feel free to Share your thoughts.
Regards
Prashanth Kumar G N
  • Murulidharlm
    Murulidharlm over 3 years ago
    Good blog, your lab session recordings are much needed, thank you Prashanthgn.engineer
