Pi IoT
  • Pi IoT
Pi IoT
Blog [Pi IoT] Plant Health Camera #5 - OpenCV
  • Author Author: gpolder
  • Date Created: 25 Jul 2016 7:59 AM Date Created
  • Views 2442 views
  • Comments 5 comments
  • image processing
  • opencv
  • machine_vision
  • git
  • github_repository
gpolder
gpolder
25 Jul 2016
As described in my first post, OpenCV is an important requirement for my application, In this post I will describe how I installed OpenCV on the Pi 3.
Previous posts:
[Pi IoT] Plant Health Camera #4 - Putting the parts together
[Pi IoT] Plant Health Camera #3 - First steps
[Pi IoT] Plant Health Camera #2 - Unboxing
[Pi IoT] Plant Health Camera #1 - Application
Install OpenCV
Next thing we need is OpenCV. I installed it from source, as described in this Install guide: Raspberry Pi 3 + Raspbian Jessie + OpenCV 3 - PyImageSearch tutorial. This is a very well written tutorial, it doesn't make much sense to repeat all steps here, so below I only describe the steps in which I deviate from this tutorial.
First make sure that I indeed run the latest Raspbian version:
pi@pi3iot:~/planthealthcam $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
Then I followed the steps of the above mentioned Install guide until 'Step #3: Download the OpenCV source code'.
I decided to do a git clone instead of downloading the zip file. This way it is much easier to update to the latest version.
pi@pi3iot:~/opencv $ git clone https://github.com/opencv/opencv.git
Cloning into 'opencv'...
remote: Counting objects: 191347, done.
remote: Compressing objects: 100% (49/49), done.
remote: Total 191347 (delta 22), reused 0 (delta 0), pack-reused 191298
Receiving objects: 100% (191347/191347), 414.50 MiB | 904.00 KiB/s, done.
Resolving deltas: 100% (132424/132424), done.
Checking connectivity... done.
Checking out files: 100% (4791/4791), done.
pi@pi3iot:~ $ git clone https://github.com/opencv/opencv_contrib.git
Cloning into 'opencv_contrib'...
remote: Counting objects: 15903, done.
remote: Compressing objects: 100% (6/6), done.
remote: Total 15903 (delta 0), reused 0 (delta 0), pack-reused 15897
Receiving objects: 100% (15903/15903), 114.08 MiB | 910.00 KiB/s, done.
Resolving deltas: 100% (9087/9087), done.
pi@pi3iot:~ $
Tutorial Step #4: Python 2.7 or Python 3? instructs to install pip. In my case pip seems to be already installed:
pi@pi3iot:~ $ pip --version
pip 1.5.6 from /usr/lib/python2.7/dist-packages (python 2.7)
I also installed the virtualenvwrapper, as recommended by the tutorial.
I decided to use python3 for my project:
pi@pi3iot:~/planthealthcam $ mkvirtualenv cv -p python3
Running virtualenv with interpreter /usr/bin/python3
Using base prefix '/usr'
New python executable in /home/pi/.virtualenvs/cv/bin/python3
Also creating executable in /home/pi/.virtualenvs/cv/bin/python
Installing setuptools, pip, wheel...done.
virtualenvwrapper.user_scripts creating /home/pi/.virtualenvs/cv/bin/predeactivate
virtualenvwrapper.user_scripts creating /home/pi/.virtualenvs/cv/bin/postdeactivate
virtualenvwrapper.user_scripts creating /home/pi/.virtualenvs/cv/bin/preactivate
virtualenvwrapper.user_scripts creating /home/pi/.virtualenvs/cv/bin/postactivate
virtualenvwrapper.user_scripts creating /home/pi/.virtualenvs/cv/bin/get_env_details
(cv) pi@pi3iot:~/planthealthcam $
Note the (cv) preceding my prompt, indicating that I am in the cv  virtual environment.
Since I cloned the distribution using git, I used the following make build:
cd ~/opencv/
$ mkdir build
$ cd build
$ cmake -D CMAKE_BUILD_TYPE=RELEASE \
    -D CMAKE_INSTALL_PREFIX=/usr/local \
    -D INSTALL_PYTHON_EXAMPLES=ON \
    -D OPENCV_EXTRA_MODULES_PATH=~/opencv_contrib/modules \
    -D BUILD_EXAMPLES=ON ..
Unfortunately the make -j4 build process stoppen after 44% (27 min) with an error compiling ffmpeg:
Building CXX object modules/videoio/CMakeFiles/opencv_videoio.dir/src/cap_ffmpeg.cpp.o
[ 44%] Built target opencv_dnn
In file included from /home/pi/opencv/modules/videoio/src/cap_ffmpeg.cpp:47:0:
/home/pi/opencv/modules/videoio/src/cap_ffmpeg_impl.hpp: In member function ‘double CvCapture_FFMPEG::get_fps() const’:
/home/pi/opencv/modules/videoio/src/cap_ffmpeg_impl.hpp:1138:49: error: ‘AVStream’ has no member named ‘r_frame_rate’
     double fps = r2d(ic->streams[video_stream]->r_frame_rate);
modules/videoio/CMakeFiles/opencv_videoio.dir/build.make:169: recipe for target 'modules/videoio/CMakeFiles/opencv_videoio.dir/src/cap_ffmpeg.cpp.o' failed
make[2]: *** [modules/videoio/CMakeFiles/opencv_videoio.dir/src/cap_ffmpeg.cpp.o] Error 1
CMakeFiles/Makefile2:6100: recipe for target 'modules/videoio/CMakeFiles/opencv_videoio.dir/all' failed
make[1]: *** [modules/videoio/CMakeFiles/opencv_videoio.dir/all] Error 2
Makefile:147: recipe for target 'all' failed
make: *** [all] Error
Quickest solution was to exclude ffmpeg from the build:
    -D BUILD_EXAMPLES=ON \
    -D WITH_FFMPEG=OFF ..
Now the make -j4 runs just fine, and after 95 minutes and 37 the make process finished at 100%.
Last step is to install it with:
$ sudo make install
$ sudo ldconfig
Test OpenCV
After some small additional steps described in the tutorial I have a working OpenCV environment.
Lets give it a try:
pi@pi3iot:~/planthealthcam $ workon cv
(cv) pi@pi3iot:~/planthealthcam $ python
Python 3.4.2 (default, Oct 19 2014, 13:31:11)
[GCC 4.9.1] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import cv2
>>> cv2.__version__
'3.1.0-dev'
Now let's try a small demo program, in this python script a camera image is grabbed, and a canny edge detector is applied, showing the edges in the image. Both the input image and the edges are displayed.
# import the necessary packages
from picamera.array import PiRGBArray
from picamera import PiCamera
import time
import cv2
# initialize the camera and grab a reference to the raw camera capture
camera = PiCamera()
rawCapture = PiRGBArray(camera)
# allow the camera to warmup
time.sleep(0.1)
# grab an image from the camera
camera.capture(rawCapture, format="bgr")
image = rawCapture.array
edges = cv2.Canny(image,100,200)
# display the image on screen and wait for a keypress
cv2.imshow("Image", image)
cv2.imshow("Edges", edges)
cv2.waitKey(0)
This gives me the following result:
Success!
An important software requirement for my plant health camera is now ready to use.
stay tuned for the next steps.
  • gpolder
    gpolder over 10 years ago in reply to pettitda +2
    David, no this will have no effect on the Pi B+, luckily the Pi 3 has 4 cores.
  • gpolder
    gpolder over 10 years ago in reply to clem57 +1
    its a video codec, if you need to work with video formats like .avi, .mp4, .mpeg, etc. I don't need it for my application.
    DAB over 10 years ago
    Very good post.
    I was curious how easy it was to put OpenCV on the Rpi, and you have shown that it can be very easy.
    Definitely looking forward to the next post.
    Very good post.
