PiCasso Design Challenge
  • PiCasso Design Challenge
Blog PiCasso Design Challenge - POV Globe Blog 6
  • Author Author: dwinhold
  • Date Created: 21 Apr 2019 11:32 PM Date Created
  • Views 799 views
  • Likes 8 likes
  • Comments 5 comments
  • picasso
  • pov globe
  • picasso design challenge
  • dwinhold
dwinhold
dwinhold
21 Apr 2019
This update is the wiring of the power to the globe. The below photos and explanations of each, describe exactly what I did. I also include a video at the end.
First photo is of the Positive wires that power the Raspberry Pi and the LED's:
Next is the Negative out:
Next photo is of the underside at the bearings. The spindle is hand made of wood on a wood lathe. I drilled a hole down the middle for the wire to travel:
The last is a video of the power connected turning on LED's:
Hope you enjoyed this update. As always, any questions, comments or ideas you have, please leave a message below!!
Dale Winhold
    balearicdynamics over 7 years ago +4
    Good update, Dale. I have a couple of points to have some clarification on your last progress, something that IMHO may risk to introduce some weakness to the rotation. As you should reach a considerable…
  • dwinhold
    dwinhold over 7 years ago in reply to balearicdynamics +4
    Hi Enrico I like the idea of a soldered board instead, I will definately be changing that out. As for the belt, I already have the type you are mentioning. Since I have to change out the motor I will be…
  • 14rhb
    14rhb over 7 years ago +3
    Hi Dale, a great update, thank you. I like your drive setup and belt (which looks like a piece of cord). I hope all goes well and looking forward to reading about your progress. Rod
  • 14rhb
    Rod
  • 14rhb
    Rod
