Save The Bees Design Challenge
  • Save The Bees Design Challenge
Blog Bee Healthy - Blog 2: Hardware Development - Solar Power Supply
Join Save The Bees Design Challenge to participate - click to join for free!
  • Author Author: ralphjy
  • Date Created: 30 Jan 2023 4:51 AM Date Created
  • Views 2170 views
  • Likes 12 likes
  • Comments 9 comments
  • save the bees
  • savethebeesch
  • nicla vision
  • solar power
  • nicla sense me
  • mkr wan 1310
ralphjy
ralphjy
30 Jan 2023
Still waiting for my challenger hardware kit - haven't seen a shipping notification yet, so I thought I'd work on the solar power supply for the project.  I am building it using a surplus solar panel and a USB power bank that I have available in my parts stash.
The solar panel is rated at 5.5VDC @ 360mA and it has a standard USB A power port.  The power bank is rated at 2200mAh and has a microUSB charge input and a standard USB A output.  So this basically involves mechanically assembling the parts and connecting cables.
I am going to connect the power bank to the microUSB input of the MKR WAN 1310 and use the 5V output header to supply power to the two Nicla boards.
I printed a clip to hold the power bank to the back of the solar panel.
And printed a Go Pro mount adapter since I have a lot of Go Pro mounting hardware.
Here is the front, side, and rear views on a tripod.  The Go Pro mount allows orienting the solar panel.
  • JWx
    JWx over 3 years ago
    Hello! It seems that MKR 1310 has internal power bank circuit (based on TI BQ24195L) - so maybe there is room for component count reduction (by eliminating external power bank and connecting battery directly)?
  • ralphjy
    ralphjy over 3 years ago in reply to JWx
    I had considered that, but the MKR 1310 when running on battery does not generate 5V.  It makes adding the Nicla modules messier.  I could have individual batteries for each module and distribute the solar panel voltage.  I would rather not try using 3.3V from the MKR 1310 regulator to power the Nicla modules.
    This method is simpler for me since I needed a mechanical setup to mount the solar panel anyway - and I didn’t have to buy another LiPo battery.
  • ralphjy
