Save The Bees Design Challenge
  • Save The Bees Design Challenge
Save the Bees DC Forum Have you used openmv and/or the Nicla Vision
Join Save The Bees Design Challenge to participate - click to join for free!
  • Replies 14 replies
  • Subscribers 78 subscribers
  • Views 6551 views
scottiebabe
scottiebabe over 3 years ago
Openmv apparently adds a number of machine vision functions (like openCV) to micropython and includes a development IDE.
Source: https://docs.arduino.cc/tutorials/nicla-vision/blob-detection
Recording a video clip is apparently as simple as:
import sensor, mjpeg, time
# Setup camera.
sensor.reset()
sensor.set_pixformat(sensor.RGB565)
sensor.set_framesize(sensor.QVGA)
sensor.skip_frames()
c = time.clock()
# Create the mjpeg object.
m = mjpeg.Mjpeg("example.mjpeg")
# Add frames.
for i in range(100):
    c.tick()
    m.add_frame(sensor.snapshot())
# Finalize.
m.close(c.fps())
Source: https://docs.openmv.io/library/omv.mjpeg.html
You can also setup a rtsp server:
Any ideas for the save the bees design challenge... lol
  • flyingbean
    flyingbean over 3 years ago +4
    One of biggest challenges is from the weather. It is winter at my city and there will have no bees until April/May next year. I can set up a camera outside of my house, burning a camera should be one less…
  • scottiebabe
    scottiebabe over 3 years ago in reply to flyingbean +3
    Yes, it is cold here too ! Even if the weather was warmer think I would still only demonstrate a proof of concept, but I have no ideas just yet. Excited to see what kind of solutions get proposed
  • javagoza
    javagoza over 3 years ago in reply to scottiebabe +3
    I don't know if I will be able to submit an application by the deadline. But if I present something, it will be with the idea of tackling a problem that affects bees, without the need to imply any contact…
  • javagoza
    I don't know if I will be able to submit an application by the deadline. But if I present something, it will be with the idea of tackling a problem that affects bees, without the need to imply any contact with the bees during the project. It can be a project about any type of pollution, light, sound, electromagnetic, thermal... I don't know, I don't know very well the problems of bees and it would be a good opportunity to learn more about them.
  • scottiebabe
    scottiebabe over 3 years ago in reply to javagoza
    I am in a similar situation. I am unsure that I will know the problem and/or the solution to a bee problem in the next few days.
    My interest is really to experiment with the nicla vision and then in the final blog attempt to apply what I have learned to a bee problem.
  • Gough Lui
    Gough Lui over 3 years ago in reply to javagoza
    Same here - if I get around to it, it will be more theoretical and less actual-bee-measuring. Even now in summer here in Australia, I can go out in my backyard and spend an hour without seeing a bee.
    - Gough
  • robogary
    robogary 10 months ago
    I'm investigating an upgrade a small Arduino robot I'm building from a PixyCam's blob detection for guidance , to use NiclaVision for object classification/detection for target tracking and guidance.
    I've quickly read over https://docs.arduino.cc/tutorials/nicla-vision/getting-started/    and https://www.hackster.io/mjrobot/tinyml-made-easy-object-detection-with-nicla-vision-407ddd
    I havent started yet, I'm still googling around for a a cookbook procedure or open source solutions as a starting place.
    Additional recommendations anyone ?
