Sci Fi Your Pi
  • Sci Fi Your Pi
Sci Fi Your Pi
Blog QuadCOP - More construction Pictures
  • Author Author: screamingtiger
  • Date Created: 25 Aug 2015 4:27 AM Date Created
  • Views 3138 views
  • Comments 25 comments
  • quadcop_project
  • design_challenge
  • rasberry_pi
  • sci_fi_your_pi
  • quadcopter
screamingtiger
screamingtiger
25 Aug 2015
Previous Posts Here:
http://www.element14.com/community/community/design-challenges/sci-fi-your-pi/blog/authors/screamingtiger?ICID=DCH-SciFiPi-challengers
I have mounted the camera in the head, and have the head moving!  I don't have the servo secure yet so that is why it is wobbly.  I posted a vid below on a preview of how it works.  I just controlled it with my radio but in flight the Raspberry Pi (RPFS) will use it to "Scan" around.
Cut a hole for they eye
Pi camera mounted with hot glue
lens pokes through
Servo, needs hard wood mounts, just held on with glue for now.
A preview.  Note the plastic eye cover, made from a Christmas Ornament.
Watch the Vid of the head.
  • screamingtiger
    screamingtiger over 11 years ago in reply to DAB +2
    For my purpose, I wanted 360 degree rotation but I would need another Magnometer but I only have 1 that works on hand. My original specs say the quad will do a 360 degree sensor sweep, I changed that to…
    jw0752 over 11 years ago +1
    The way he turns his head back and forth reminds me of how I would feel if you were attaching me to a quadcopter. Very nice pictures. Was the pretty lady your very very understanding and supportive wife…
    balearicdynamics over 11 years ago +1
    Very nice !!! It's almost finished Enrico
    DAB over 11 years ago
    Good post.
    It reminded me of the time I drove a helicopter FLIR camera based upon its flight vectors.
    I used five degree steps to keep the movement smooth and then one degree steps once I had the FLIR looking down the flight vector.
    Those were good days, especially during flight test with the UH53.
    Good post.
  • screamingtiger
    For my purpose, I wanted 360 degree rotation but I would need another Magnometer but I only have 1 that works on hand.  My original specs say the quad will do a 360 degree sensor sweep, I changed that to be a 180 degree. The quad wont rotate, just the head.  The head will only moved when stopped but I may add some "bling" movements so it looks around while moving to the next waypoint and while being flown manually.
    the head will have a sonic sonsor and motion detector on it as well.
    Basically the same algorithm I used on my B-25 bomber turret but for that I used Arduino, but the ChipKit can handle it!  It will have a smooth motion with variable speeds.  I am considering putting my Luxeon LED setup on it too so it acts like a search light.
    balearicdynamics over 11 years ago in reply to screamingtiger
    Great video Joey,
    it perfectly gives the idea of what will be the result of the quadcopter !
    Enrico
  • amgalbu
    amgalbu over 11 years ago in reply to screamingtiger
    Hi Joey
    How are you going to implement the motion detector? I would be useful for my project as well.. My idea was to use OpenCV, but may be you have an approach that requires less computing power
    Regards
    Ambrogio
  • screamingtiger
    screamingtiger over 11 years ago in reply to amgalbu
    For my project I planned on using a PIR sensor.  However I haven't tested it yet and I am not sure it will work since the QuadCop probably will not be able to hold perfectly still.  I think the same issue would happen if I used Open CV.
    Joey, you mean a presence / movement sensor to detect the presence of objects in the path or to manage the drone at the same height while flying?
