Sci Fi Your Pi
  • Sci Fi Your Pi
Sci Fi Your Pi
Blog QuadCop: Final Construction Pics
  • Author Author: screamingtiger
  • Date Created: 26 Aug 2015 3:58 AM Date Created
  • Views 1913 views
  • Comments 6 comments
  • quadcop_project
  • design_challenge
  • raspberry_pi
  • sci_fi_your_pi
screamingtiger
screamingtiger
26 Aug 2015
Previous Posts Here:
http://www.element14.com/community/community/design-challenges/sci-fi-your-pi/blog/authors/screamingtiger?ICID=DCH-SciFiPi-challengers
Here are a few more final construction pics, the rest will just be installing sensors.  Ill post a final pic pointing out the various parts used from the kit.
In the morning I will be posting my github, code, and flow charts.
I am working on a bug with the 3 axis magnometer before I can take another test flight.
PiCam installed in the bottom head with raspberry PI model B hot glued to the side.  This allows the head to rotate without twisting the cable.  A power cable will go to the Pi but it will be long and thin enough to allow the rotation.
A small foam bearing (bottom) was put in place to stop the wobble.
Needs a bit of adjusting, the Raspberry PI pulls it down to one side so I need some weight to balance it.
A video of much better head movement!
  • fvan
    fvan over 11 years ago +2
    Nice build! Also, "Shanghai Noon/Shanghai Knights" in the background ?
  • amgalbu
    amgalbu over 11 years ago +1
    A very interesting project Many compliments!
    balearicdynamics over 11 years ago +1
    Hi John, just like the heli video. This movement seems perfect. A note I though about the possible issue of the antenna... Seeing the final proportions of the object it seems that the external antenna…
  • amgalbu
    Many compliments!
  • amgalbu
    Many compliments!
