Sci Fi Your Pi
  • Sci Fi Your Pi
Sci Fi Your Pi
Blog QuadCop: Final Construction Pics
  • Author Author: screamingtiger
  • Date Created: 26 Aug 2015 3:58 AM Date Created
  • Views 1913 views
  • Comments 6 comments
  • quadcop_project
  • design_challenge
  • raspberry_pi
  • sci_fi_your_pi
screamingtiger
screamingtiger
26 Aug 2015
Previous Posts Here:
http://www.element14.com/community/community/design-challenges/sci-fi-your-pi/blog/authors/screamingtiger?ICID=DCH-SciFiPi-challengers
Here are a few more final construction pics, the rest will just be installing sensors.  Ill post a final pic pointing out the various parts used from the kit.
In the morning I will be posting my github, code, and flow charts.
I am working on a bug with the 3 axis magnometer before I can take another test flight.
PiCam installed in the bottom head with raspberry PI model B hot glued to the side.  This allows the head to rotate without twisting the cable.  A power cable will go to the Pi but it will be long and thin enough to allow the rotation.
A small foam bearing (bottom) was put in place to stop the wobble.
Needs a bit of adjusting, the Raspberry PI pulls it down to one side so I need some weight to balance it.
A video of much better head movement!
  • fvan
    fvan over 11 years ago +2
    Nice build! Also, "Shanghai Noon/Shanghai Knights" in the background ?
  • amgalbu
    amgalbu over 11 years ago +1
    A very interesting project Many compliments!
    balearicdynamics over 11 years ago +1
    Hi John, just like the heli video. This movement seems perfect. A note I though about the possible issue of the antenna... Seeing the final proportions of the object it seems that the external antenna…
    Hi John,
    A note I though about the possible issue of the antenna... Seeing the final proportions of the object it seems that the external antenna position maybe not so problematic as though.
    Enrico
    Hi John,
    Enrico
  • screamingtiger
    screamingtiger over 11 years ago in reply to balearicdynamics
    My name is Joey!  ENRICO!  I should I call you Ricky?  image  Just kidding.
    balearicdynamics over 11 years ago in reply to screamingtiger
    Ha I should send you my smartphone virtual keyboard with fantastic self-correction software. Please update it image
    Enrico
    BTW, as you call me if you answer to my post, I receive the notification anyway image And probably does not note this "detail" haha
