Sci Fi Your Pi
  • Sci Fi Your Pi
Sci Fi Your Pi
Blog TrainingSphere - 6 - The frame
  • Author Author: amgalbu
  • Date Created: 24 Jul 2015 11:25 AM Date Created
  • Views 1946 views
  • Comments 11 comments
  • sci_fi_your_pi
  • training_sphere
amgalbu
amgalbu
24 Jul 2015
The frame is almost completed
I encountered more difficulties than I expected in assembly a structure using steel wires...
It's not very clear in these pictures, but there are three "parallels" corresponding to three "levels"
On the upper level, the raspberry and the accelerometerers will be mounted
The middle level will host the two engines and propellers
The bottom level will host the control surfaces
At the bottom of the sphere (so outside the sphere) I will place the battery and the two servos that move the control surfaces
  • amgalbu
    amgalbu over 11 years ago in reply to tomaja +2
    I expect the complete sphere to be about 700 grams. I used an online motor calculator to size engines and propellers for a thrust of 1.6 kg. I hope the calculator is precise enough!
  • fvan
    fvan over 11 years ago +1
    Nice frame, what's the weight like ?
  • amgalbu
    amgalbu over 11 years ago in reply to balearicdynamics +1
    Yes enrico you are right. One of the results iis that the sphere can bounce thus protecting electronic components and propellers. AAs far as i know carbon fiber has limited elasticity. It's stiffer and…
  • fvan
  • amgalbu
    amgalbu over 11 years ago in reply to fvan
    Hi fvan
    the frame current weight is 250 grams, but I still need to add control surfaces
  • tomaja
    tomaja over 11 years ago in reply to amgalbu
    Nice frame!
    250g doesn't sound like too much but with battery, wiring, motors and electronics (ESC and flight controller) it can easily go near 1kg. This is still fine.
    You just need to make sure you have sufficient lift, and good resource for that is eCalc - the most reliable RC Calculator on the Web
    I really cant wait to see your sphere flying image
    Good luck!
  • tomaja
    Nice frame!
    Good luck!
  • amgalbu
