Sci Fi Your Pi
  • Sci Fi Your Pi
Sci Fi Your Pi
Blog TrainingSphere - 6 - The frame
  • Author Author: amgalbu
  • Date Created: 24 Jul 2015 11:25 AM Date Created
  • Views 1946 views
  • Comments 11 comments
  • sci_fi_your_pi
  • training_sphere
amgalbu
amgalbu
24 Jul 2015
The frame is almost completed
I encountered more difficulties than I expected in assembly a structure using steel wires...
It's not very clear in these pictures, but there are three "parallels" corresponding to three "levels"
On the upper level, the raspberry and the accelerometerers will be mounted
The middle level will host the two engines and propellers
The bottom level will host the control surfaces
At the bottom of the sphere (so outside the sphere) I will place the battery and the two servos that move the control surfaces
  • amgalbu
    amgalbu over 11 years ago in reply to tomaja +2
    I expect the complete sphere to be about 700 grams. I used an online motor calculator to size engines and propellers for a thrust of 1.6 kg. I hope the calculator is precise enough!
  • fvan
    fvan over 11 years ago +1
    Nice frame, what's the weight like ?
  • amgalbu
    amgalbu over 11 years ago in reply to balearicdynamics +1
    Yes enrico you are right. One of the results iis that the sphere can bounce thus protecting electronic components and propellers. AAs far as i know carbon fiber has limited elasticity. It's stiffer and…
  • ravi_butani
    ravi_butani over 11 years ago
    Nice frame...
    CF tubes will be more better than steel... In terms of weight and durability too...
    balearicdynamics over 11 years ago in reply to ravi_butani
    What do you intend as CF ? Carbon fiber ?
  • ravi_butani
    ravi_butani over 11 years ago in reply to balearicdynamics
    Yes carbon fibre... 3mm outer and 2 mm internal dia tube or even 2mm dia rod will best for banding to give circular shape..
    Maybe, but with too much issues like: expensive, needs more complex nodes, less or identical flexibility. For a prototype this material is better. Also because this is a perimeter structure while - accordingly with the previous designs of Ambrogio - the core of the system is inside a tubular structure. So this is only for external shaping and protection. IMO
  • amgalbu
    Yes enrico you are right. One of the results iis that the sphere can bounce thus protecting electronic components and propellers. AAs far as i know carbon fiber has limited elasticity. It's stiffer and lighter but in case  of shock it cracks.
  • amgalbu
