Summer of FPGA
  • Summer of FPGA
Summer of FPGA
Blog Security Hardware Accelerator #5 Complete build of SHA256 accelerator in microblaze core
  • Author Author: fyaocn
  • Date Created: 10 Jan 2022 6:44 AM Date Created
  • Views 1912 views
fyaocn
fyaocn
10 Jan 2022
1. Import new platform of xsa file from vivado.
Prepare the platform with xsa in vivado, 64k memory is used. It is Ok for 32k , final code size is about 10k. According to design flow in previous blogs.
2. Creating new Vitis Projects
The platform settings
The application settings
THE architecture
3. Coding
Make the sha-256 code , revised from open-sourced code in github,
The main() functions, build to generate binary file in elf.
#include <stdio.h>
#include <memory.h>
#include <string.h>
#include "platform.h"
#include "xil_printf.h"
#include "xparameters.h"
#include "xgpio.h"
#include "xil_types.h"
#include "sha256.h"
int main()
	init_platform();
    xil_printf("Entered function main\r\n");
    sha256();
    xil_printf("End of application.\n\n\r");
    cleanup_platform();
    return 0;
And sha256() function perform hashing
4. The result is Ok. hash for "abc" is same as precalculation value,
BYTE text1[] = {"abc"};
BYTE hash1[SHA256_BLOCK_SIZE] = {0xba,0x78,0x16,0xbf,0x8f,0x01,0xcf,0xea,0x41,0x41,0x40,0xde,0x5d,0xae,0x22,0x23,0xb0,0x03,0x61,0xa3,0x96,0x17,0x7a,0x9c,0xb4,0x10,0xff,0x61,0xf2,0x00,0x15,0xad};
5. SHA-256 algorithm
SHA-256 is prevail hash algorithm widely applicable. HASH is foundation of Proof of Work in blockchain technology.
 * sha256.c
 *  Created on: 2022Äê1ÔÂ7ÈÕ
 *      Author: north
/*************************** HEADER FILES ***************************/
#include <stdlib.h>
#include <memory.h>
#include "sha256.h"
/****************************** MACROS ******************************/
#define ROTLEFT(a,b) (((a) << (b)) | ((a) >> (32-(b))))
#define ROTRIGHT(a,b) (((a) >> (b)) | ((a) << (32-(b))))
#define CH(x,y,z) (((x) & (y)) ^ (~(x) & (z)))
#define MAJ(x,y,z) (((x) & (y)) ^ ((x) & (z)) ^ ((y) & (z)))
#define EP0(x) (ROTRIGHT(x,2) ^ ROTRIGHT(x,13) ^ ROTRIGHT(x,22))
#define EP1(x) (ROTRIGHT(x,6) ^ ROTRIGHT(x,11) ^ ROTRIGHT(x,25))
#define SIG0(x) (ROTRIGHT(x,7) ^ ROTRIGHT(x,18) ^ ((x) >> 3))
#define SIG1(x) (ROTRIGHT(x,17) ^ ROTRIGHT(x,19) ^ ((x) >> 10))
/**************************** VARIABLES *****************************/
static const WORD k[64] = {
	0x428a2f98,0x71374491,0xb5c0fbcf,0xe9b5dba5,0x3956c25b,0x59f111f1,0x923f82a4,0xab1c5ed5,
	0xd807aa98,0x12835b01,0x243185be,0x550c7dc3,0x72be5d74,0x80deb1fe,0x9bdc06a7,0xc19bf174,
	0xe49b69c1,0xefbe4786,0x0fc19dc6,0x240ca1cc,0x2de92c6f,0x4a7484aa,0x5cb0a9dc,0x76f988da,
	0x983e5152,0xa831c66d,0xb00327c8,0xbf597fc7,0xc6e00bf3,0xd5a79147,0x06ca6351,0x14292967,
	0x27b70a85,0x2e1b2138,0x4d2c6dfc,0x53380d13,0x650a7354,0x766a0abb,0x81c2c92e,0x92722c85,
	0xa2bfe8a1,0xa81a664b,0xc24b8b70,0xc76c51a3,0xd192e819,0xd6990624,0xf40e3585,0x106aa070,
	0x19a4c116,0x1e376c08,0x2748774c,0x34b0bcb5,0x391c0cb3,0x4ed8aa4a,0x5b9cca4f,0x682e6ff3,
	0x748f82ee,0x78a5636f,0x84c87814,0x8cc70208,0x90befffa,0xa4506ceb,0xbef9a3f7,0xc67178f2
void sha256_transform(SHA256_CTX *ctx, const BYTE data[])
	WORD a, b, c, d, e, f, g, h, i, j, t1, t2, m[64];
	// initialization
	for (i = 0, j = 0; i < 16; ++i, j += 4)
		m[i] = (data[j] << 24) | (data[j + 1] << 16) | (data[j + 2] << 8) | (data[j + 3]);
	for ( ; i < 64; ++i)
		m[i] = SIG1(m[i - 2]) + m[i - 7] + SIG0(m[i - 15]) + m[i - 16];
	a = ctx->state[0];
	b = ctx->state[1];
	c = ctx->state[2];
	d = ctx->state[3];
	e = ctx->state[4];
	f = ctx->state[5];
	g = ctx->state[6];
	h = ctx->state[7];
	for (i = 0; i < 64; ++i) {
		t1 = h + EP1(e) + CH(e,f,g) + k[i] + m[i];
		t2 = EP0(a) + MAJ(a,b,c);
		h = g;
		g = f;
		f = e;
		e = d + t1;
		d = c;
		c = b;
		b = a;
		a = t1 + t2;
	ctx->state[0] += a;
	ctx->state[1] += b;
	ctx->state[2] += c;
	ctx->state[3] += d;
	ctx->state[4] += e;
	ctx->state[5] += f;
	ctx->state[6] += g;
	ctx->state[7] += h;
void sha256_init(SHA256_CTX *ctx)
	ctx->datalen = 0;
	ctx->bitlen = 0;
	ctx->state[0] = 0x6a09e667;
	ctx->state[1] = 0xbb67ae85;
	ctx->state[2] = 0x3c6ef372;
	ctx->state[3] = 0xa54ff53a;
	ctx->state[4] = 0x510e527f;
	ctx->state[5] = 0x9b05688c;
	ctx->state[6] = 0x1f83d9ab;
	ctx->state[7] = 0x5be0cd19;
void sha256_update(SHA256_CTX *ctx, const BYTE data[], size_t len)
	WORD i;
	for (i = 0; i < len; ++i) {
		ctx->data[ctx->datalen] = data[i];
		ctx->datalen++;
		if (ctx->datalen == 64) {
			// 64 byte = 512 bit  means the buffer ctx->data has fully stored one chunk of message
			// so do the sha256 hash map for the current chunk
			sha256_transform(ctx, ctx->data);
			ctx->bitlen += 512;
			ctx->datalen = 0;
void sha256_final(SHA256_CTX *ctx, BYTE hash[])
	WORD i;
	char opt[8];
	i = ctx->datalen;
	// Pad whatever data is left in the buffer.
	if (ctx->datalen < 56) {
		ctx->data[i++] = 0x80;  // pad 10000000 = 0x80
		while (i < 56)
			ctx->data[i++] = 0x00;
	else {
		while (i < 64)
		memset(ctx->data, 0, 56);
	// Append to the padding the total message's length in bits and transform.
	ctx->bitlen += ctx->datalen * 8;
	ctx->data[63] = ctx->bitlen;
	ctx->data[62] = ctx->bitlen >> 8;
	ctx->data[61] = ctx->bitlen >> 16;
	ctx->data[60] = ctx->bitlen >> 24;
	ctx->data[59] = ctx->bitlen >> 32;
	ctx->data[58] = ctx->bitlen >> 40;
	ctx->data[57] = ctx->bitlen >> 48;
	ctx->data[56] = ctx->bitlen >> 56;
	// copying the final state to the output hash(use big endian).
	for (i = 0; i < 4; ++i) {
		hash[i]      = (ctx->state[0] >> (24 - i * 8)) & 0x000000ff;
		hash[i + 4]  = (ctx->state[1] >> (24 - i * 8)) & 0x000000ff;
		hash[i + 8]  = (ctx->state[2] >> (24 - i * 8)) & 0x000000ff;
		hash[i + 12] = (ctx->state[3] >> (24 - i * 8)) & 0x000000ff;
		hash[i + 16] = (ctx->state[4] >> (24 - i * 8)) & 0x000000ff;
		hash[i + 20] = (ctx->state[5] >> (24 - i * 8)) & 0x000000ff;
		hash[i + 24] = (ctx->state[6] >> (24 - i * 8)) & 0x000000ff;
		hash[i + 28] = (ctx->state[7] >> (24 - i * 8)) & 0x000000ff;
	for (i = 0; i < 32; ++i) {
		//char opt = hash[i];
		itoa(hash[i],opt,16);
		xil_printf(opt);
	//unsigned char opt= to_string(80);xil_printf(opt);
	//int aa=0xef;	char c[10];	itoa(aa,c,16);	xil_printf(c);	itoa(hash[16],opt,16);	xil_printf(opt);
int sha256()
	//BYTE text2[] = {"abcdbcdecdefdefgefghfghighijhijkijkljklmklmnlmnomnopnopq"};
	//BYTE text3[] = {"aaaaaaaaaa"};
	//BYTE hash1[SHA256_BLOCK_SIZE] = {0xba,0x78,0x16,0xbf,0x8f,0x01,0xcf,0xea,0x41,0x41,0x40,0xde,0x5d,0xae,0x22,0x23,0xb0,0x03,0x61,0xa3,0x96,0x17,0x7a,0x9c,0xb4,0x10,0xff,0x61,0xf2,0x00,0x15,0xad};
	//BYTE hash2[SHA256_BLOCK_SIZE] = {0x24,0x8d,0x6a,0x61,0xd2,0x06,0x38,0xb8,0xe5,0xc0,0x26,0x93,0x0c,0x3e,0x60,0x39,0xa3,0x3c,0xe4,0x59,0x64,0xff,0x21,0x67,0xf6,0xec,0xed,0xd4,0x19,0xdb,0x06,0xc1};
	//BYTE hash3[SHA256_BLOCK_SIZE] = {0xcd,0xc7,0x6e,0x5c,0x99,0x14,0xfb,0x92,0x81,0xa1,0xc7,0xe2,0x84,0xd7,0x3e,0x67,0xf1,0x80,0x9a,0x48,0xa4,0x97,0x20,0x0e,0x04,0x6d,0x39,0xcc,0xc7,0x11,0x2c,0xd0};
	BYTE buf[SHA256_BLOCK_SIZE];
	SHA256_CTX ctx;
	print("Hello SHA-256 Coder \n\r");
	sha256_init(&ctx);
	sha256_update(&ctx, text1, strlen(text1));
	//sha256_update(&ctx, text2, strlen(text2));
	//int idx;for (idx = 0; idx < 100000; ++idx)	   {sha256_update(&ctx, text3, strlen(text3));}
	sha256_final(&ctx, buf);
	//int pass = 1;pass = pass && !memcmp(hash1, buf, SHA256_BLOCK_SIZE);
	//pass = pass && !memcmp(hash2, buf, SHA256_BLOCK_SIZE);
	//pass = pass && !memcmp(hash3, buf, SHA256_BLOCK_SIZE);
	//return(pass);
	print("\r\nComplete SHA-256 Coder. \n\r");
	//print(buf[1]);
	return(1);
  • Angelahelen
    Angelahelen over 4 years ago in reply to fyaocn
    This type of software acceleration is very good to do.
    https://jealouscomputers.com/7-best-ways-to-cool-the-laptop-while-gaming/
  • fyaocn
    fyaocn over 4 years ago in reply to Jan Cumps
    This is kind of software acceleration. One round takes several seconds.
    I shall try  hardware acceleration and packing as IP. It takes more times but it could be much faster.
    Jan Cumps over 4 years ago
    great!
    It would be nice to try and implement the acceleration in Vitis HLS. I've reviewed a few projects that do encrypt/decrypt  with it. I'm not fluent enough with the tools to reproduce thir exercise.
