Summer of Green Tech Design Challenge
  • Summer of Green Tech Design Challenge
Blog AquaFlow - Blog #6 - Conclusions
Join Summer of Green Tech Design Challenge to participate - click to join for free!
  • Author Author: amgalbu
  • Date Created: 18 Oct 2023 2:19 PM Date Created
  • Views 1124 views
  • seeeduino xiao
  • summer of green tech design challenge
  • green tech
  • Xiao
  • aquaflow
  • seeeduino
amgalbu
amgalbu
18 Oct 2023
Posts in this project
AquaFlow - Blog #1 - Introduction
AquaFlow - Blog #2 - The coarse filter
AquaFlow - Blog #3 - The sedimentation tank
AquaFlow - Blog #4 - The reed bed
AquaFlow - Blog #5 - The storage tank
This is the last post of this project. I will talk about some latest changes and publish a video of the grey water treatment system
1. Latest change
I had to make some changes because the sonar did not work properly because the signal was reflected by the sides of the box. For this reason, I had to add a 3D printed cone to exclude reflections made by the box. However, the cone itself reflects the sonar signal, so I glued foam on the internal side of the cone itself
image  image
With the change, the sonar reading looks more precise and reliable
2. Bill of material
This is the list of items I used to build the AquaFlow
2.1 Coarse filter
Qty Description Notes Link
1 5 litres bucket
2 m 30 mm plastic rigid pipe
Non-woven fabric
Volcanic stones
Sand
1 3D-printed filter image https://github.com/ambrogio-galbusera/aquaflow/blob/master/STL/Filter.stl
1 3D-printed filter ring image https://github.com/ambrogio-galbusera/aquaflow/blob/master/STL/FilterRing.stl
2.2 Sedimentation tank
https://it.farnell.com/whale/gp1652/pompa-sommergibile-3m-3-8a/dp/3531309​
1 Seeeduino XIAO board image
1 Seeeduino Grove ultrasonic ranger image https://wiki.seeedstudio.com/Grove-Ultrasonic_Ranger/
1 3D-printed sonar case image https://github.com/ambrogio-galbusera/aquaflow/blob/master/STL/SonarCase.stl
1 3D-printed cone image https://github.com/ambrogio-galbusera/aquaflow/blob/master/STL/SonarCone.stl
2 Relay module image https://amzn.eu/d/g3ModLV
1 LDR module image https://amzn.eu/d/5nXbgas
1 12V-to-5V DC-DC converter image https://amzn.eu/d/hTn6Yfh
1 3D-printed electronic housing image https://github.com/ambrogio-galbusera/aquaflow/blob/master/STL/BoardHousing.stl
1 3D-printed connectors holder image https://github.com/ambrogio-galbusera/aquaflow/blob/master/STL/ConnectorsHolder.stl
1 12V Compressor
1 3D-printed compressor support image https://github.com/ambrogio-galbusera/aquaflow/blob/master/STL/CompressorSupport.stl
1 Water pump image https://it.farnell.com/whale/gp1652/pompa-sommergibile-3m-3-8a/dp/3531309
1 Plastic box image https://amzn.eu/d/0hjCv5B
10 mm plywood
4 3D-printed brackets image https://github.com/ambrogio-galbusera/aquaflow/blob/master/STL/Brackets.stl
1 3D-printed floating  image https://github.com/ambrogio-galbusera/aquaflow/blob/master/STL/Floating.stl
1 3D-printed floating cover image https://github.com/ambrogio-galbusera/aquaflow/blob/master/STL/FloatingCover.stl
1 3D-printed hose hook image https://github.com/ambrogio-galbusera/aquaflow/blob/master/STL/HoseHook.stl
1 3D-printed hose hook cap image https://github.com/ambrogio-galbusera/aquaflow/blob/master/STL/HoseHookCap.stl
2 16 mm gland https://amzn.eu/d/auwwAQF
1 m 16 mm rigid plastic pipe
0.5 m 20 mm rigid plastic pipe
5 m garden hose
1 60 litres tank with cover
Source code https://github.com/ambrogio-galbusera/aquaflow/tree/master/src/SedimentationTank
2.3 Storage tank
1 Relay module image https://amzn.eu/d/g3ModLV
10 mm plywood
1 200 litres tanks with cover
Source code https://github.com/ambrogio-galbusera/aquaflow/tree/master/src/StorageTank
All 3D-printed parts and source code is available here
3. Final demo
4. Conclusions and future work
This challenge has been quite physical, because a lot of hard work has been done to bury the tanks and create the reed bed. The result is quite satisfying, because I am going to recycle a lot of otherwise-wasted water. For sure, next summer will be very important to have a constant source of water for the garden.
This is the first time I used the Seeeduino XIAO board, and it has proved to be a very compact yet powerful for small projects. At first sight, it looks limited in the number of available I/O, but actually the compact size and the flexible configuration makes this platform perfect for a number of DIY projects.
However, some issues must be fixed
  1. the sonar reading is not very precise when tanks are almost full, so I need maybe to find a better position
  2. when tanks are almost full, the floating rod tend to get stuck. I hope this can be solved with a longer slide
I hope I will be able to fix these minor issues soon. In the meantime, I would like to thanks all my readers for reading this long, and Element14 for giving us the possibility to participate. See you at the next challenge!
  • Zhar_14
    Zhar_14 over 3 years ago
    Awesome demonstration video! You very clearly describe the project.
  • amgalbu
    amgalbu over 3 years ago in reply to Zhar_14
    Thanks Zhar_14 !
  • amgalbu
    Thanks Zhar_14 !
