Blog IntelliLight - Adaptive Smart Bulb Controller - Part 2 - Project Schedule
  • DesignChallenge
  • Author Author: osjef
  • Date Created: 6 Sep 2022 9:24 PM Date Created
  • Views 1621 views
  • Comments 5 comments
  • esp32
  • vishay
  • proximity sensor
  • esp8266
  • smart hub
  • smart bulb
  • summer of sensors
  • ambient light sensor
osjef
osjef
6 Sep 2022
Recap
In my previous blog, I introduced my project idea for the Summer of Sensors Design Challenge. The project is a low cost, adaptive smart bulb controller using a proximity sensor and an ambient light sensor from Vishay. The proximity sensor will be used to automatically turn the light on and off when the user sits down next to the light. The ambient light sensor will be used to control the brightness of the bulb to equalise with the ambient light level and reduce eye tension.
The purpose of today's blog is to outline the project schedule before the real work begins...
Project Schedule
The following is a rough outline of what I will be doing each week. Some elements of this plan are subject to change depending on circumstances (e.g. lead time delay) and project progress (good or bad).
The plan is to complete a blog for each section below, so please stay tuned if any of the areas look interesting to you. As always, any comments, suggestions and advice are much welcomed.
Wk #
W/C
Title
Details
1
1st Sept
Planning and Research
  • Create detailed project schedule for next 10 weeks
  • Component research/selection
    • micro-controller/processor
    • compatible smartbulb
    • power source (mains/DC/battery etc.)
  • Integration research
    • protocols/technology (WiFi, Bluetooth, ZigBee, etc.)
    • smartbulb control commmand set (on/off, brightness, colour)
    • encryption
2
8th Sept
Design
  • System design (architectural and use-case diagrams)
  • High-Level SW Design (class diagram)
  • High-Level HW Design (block diagram)
  • Low-Level SW Design (sequence diagrams)
  • Low-Level HW Design (schematic diagram, EaglePCB)
  • Note: Diagrams will be drawn in Enterprise Architect and Visio
3
15th Sept
Sourcing and Setup
  • Create full BOM
  • Order components not included in the kit
  • Allow lead time for components
  • Setup SW development environment
    • install SW tools, debuggers, etc.
    • setup configuration control (GitHub)
    • setup SW project and trial building something
4
22nd Sept
Build Prototype (Pt 1)
  • HW build should be fairly straightforward
  • SW development will take up remaining time
5
29th Sept
Build Prototype (Pt 2)
6
6th Oct
Testing and Redesign
  • Initial testing to prove out the design
  • Redesign any elements of HW and SW and retest
7
13th Oct
Printed Circuit Board (PCB)
  • Design PCB (EaglePCB)
  • Manufacture/Order (2wk lead time)
  • Note: Depending on the complexity of the circuit, a PCB may not be required, will gauge when LLD is complete
8
20th Oct
3D Printed Case
  • Design 3D model (SolidWorks)
  • 3D print it
9
27th Oct
Assembly and Test
  • Populate PCB (or stripboard depending on complexity)
  • Assemble into 3D-printed case
  • Unit level (SW) testing
  • System level testing
10
3rd Nov
Calibration and Documentation
  • Final calibration of the proximity and ambient light sensor
  • Tidy up code documentation (most of this will have been done during the development, but there’s always a bit left to do at the end)
  • User manual (readme/latex format)
11
10th Nov
Finishing Up
  • Time to tie up any loose ends and get ready for project submission
Coming Next...
Thank you for your interest in this project and taking the time to read this blog!
My next blog will be a bit more technical as I will be summarising some of the component research undertaken, so please subscribe, stay tuned and check back for regular updates.
Previous Blog (Part 1) Next Blog (Part 3)
    shabaz over 4 years ago
    Hi,
    The title of this blog post may need changing, because all people see is "2 - Project Schedule" with no idea what it's a project schedule of. Maybe it could be something like "MyProjectName part 2 - Project Schedule".
    Also just a brief sentence to introduce what the project is about, before launching into the main content. Not everyone will have seen the part 1 blog, so won't know what the project is.
    Hi,
  • osjef
    osjef over 4 years ago in reply to shabaz
    Thanks for the tips, I have tweaked the titles as suggested
