Upcycle It
  • Upcycle It
Upcycle It
Forum Intel's Eclipse-based IDE
  • Answers 3 answers
  • Subscribers 4 subscribers
  • Views 1164 views
konstantinoskonstas
konstantinoskonstas over 9 years ago
I am considering of using Intel's Eclipse-based IDE.
However I have a problem. I am on a 4-core ATOM laptop (64 bit) that has factory installed Win 10 Home edition, aka 32 bit. At Intel's Development site there is only Win 64 bit version to download. Does anyone know where I can get a Win 32 bit one?
Perhaps Huzefa, Martin or Mark could help.
Thanks in advance,
Konstantinos
  • huzefa_nk
    huzefa_nk over 9 years ago +1 suggested
    I have not tried this myself, but found some info here Look at the section ""Windows cannot find eclipse.exe" message". It talks about some additional changes which can be done to install it on 32-bit…
  • konstantinoskonstas
    konstantinoskonstas over 9 years ago in reply to huzefa_nk +1
    huzefa_nk Thanks a lot. I will spend the day trying it. I am not sure of the version I should experiment with. We have Ver. 3.0, 3.5, 4.0, 5.0 so I will start from Ver. 3.0 and see how it goes. It would…
    0 mcb1 over 9 years ago
    You need to use the @name in order to get it into the Inbox
    Personally I don't know.
    martinkronberg  huzefa_nk can you provide some guidance.
    0 konstantinoskonstas over 9 years ago in reply to mcb1
    Thanks a lot for your response and guidance Mark anyway.
  • huzefa_nk
    0 huzefa_nk over 9 years ago
    Look at the section ""Windows cannot find eclipse.exe" message". It talks about some additional changes which can be done to install it on 32-bit Windows OS. Not sure if it will work but worth giving it a shot.
    0 konstantinoskonstas over 9 years ago in reply to huzefa_nk
    huzefa_nk
    It would be very nice if the doc would explain the version it refers to. Unless I missed something due to my age.
    One thing is sure, that it cannot be done with the Installer version.
    Pity because by looking at the following page : IntelRegistered Edison Module Downloads
    https://software.intel.com/en-us/iot/hardware/edison/downloads , it is only on the Installers selection for the current IntelRegistered IoT Developer Kit release that has only : Windows* 64 bit ,   OS X* ,   Linux* selections.
    Further down to : Microcontroller (MCU) SDK for example you get Download options for Windows* 32 bit, Windows* 64 bit, OS X*, Linux* 32 bit, Linux* 64 bit !
    I think a large number of laptops and netbooks come with Win10 Home pre-installed nowadays. Up till now, I've been using CAD and Spice with that version with no problem. So there should be a provision for that.
    Anyway, I will spend my day on that and see what happens.
    Konstantinos
