Vertical Farming
  • Vertical Farming
Vertical Farming
Blog Modular Farm Blog: Post 17 – Plant Growth
  • Author Author: jmbranco76
  • Date Created: 30 Nov 2015 11:46 PM Date Created
  • Views 1453 views
  • modular_farm
  • hydroponic
  • net_zero_energy_farming
  • grow_sharp
  • vertical_farming
jmbranco76
jmbranco76
30 Nov 2015
Hi vertical farmers,
In the previous post we published our repositories for Silicon Labs firmware and KiCad boards. In this post we will discuss the growth of our lettuces.
This has been a very interesting learning process that lead to some reactive improvements on our setup, mainly related to our lighting system.
Our hydroponic system has two allotments of 40 plants each (top/bottom). We started growing on the top floor with an equal ratio of DeepBlue (DB-450nm), HyperRed (HR-650nm) and FarRed (FR-730nm) with a total power of 20 W while we used double of the LEDs on the bottom floor. The results on the growing were so clear after one week that we had to double the LED power installed. Before adding extra light, the plants were very fragile and elongated as shown on the next picture:
With the extra light the plants on the bottom floor grown stronger and more compact.
Also left and right sides got different behaviors due to the reflectivity of the cover material:
The plants from the left side bended towards light direction positioned at a central position. This will lead to another improvement on our next trial spreading evenly on the growing area or shaping the beam light with secondary optics. The effect can be clearly seen on the next image.
Due to the shadow of the metal frame structure used to reinforce the structure and some pipes, four plants on the extremity become elongated and fragile as clearly seen on the next image:
The effect is also visible on the weak radicular system compared to center ones:
Globally this has been an amazing learning journey. Of course the light is only one of the key factors for healthy growing… but we managed to take some interesting conclusions that will help to recreate a better growing system according to plant needs...
Overall we are proud with our first growing trial and for sure we´ll be eating some healthy food on the coming weeks! image
As always if you have any questions or comments please feel free to comment this post.
Thanks for following and keep connected!
    DAB over 10 years ago
    Great update,
    People forget that a lot of families had small home gardens in the yards because getting fresh vegetables was difficult and expensive.
    Today you can get pretty much anything from anywhere, but the purist know that the best stuff comes from your own garden because you know what has been done to it.
  • jmbranco76
    jmbranco76 over 10 years ago in reply to DAB
    Thanks image
  • jmbranco76
    Thanks image
