Wireless Power - Beyond the Phone
  • Wireless Power - Beyond the Phone
Forum Additional Coils
  • Replies 8 replies
  • Answers 2 answers
  • Subscribers 6 subscribers
  • Views 2113 views
  • beyond_the_phone
Additional Coils
ipv1
ipv1 over 12 years ago
I may be missing the point here, but I need input. Lots of it!
I got an email from element14 regarding the supply of addional coils. Without the management IC or module? What am I supposed to do with them?
Additionally I want to ask how and if a single coil can be used like in the case of a phone charger?
Thanks in advance.
    mcb1 over 12 years ago in reply to ipv1 +2
    Inderpreet The receiver details and coil number is here http://www.element14.com/community/docs/DOC-65661/l/bq51013bevm-764-wpc-11-compatible-fully-integrated-wireless-power-receiver-ic-evaluation-module…
    mcb1 over 12 years ago in reply to sleuz +1
    Luckily I come from the bottom of the world, and understand 'merci' Gern geschehen This link suggests there are some that don't, although I'm not sure its entirely accurate.
    0 mcb1 over 12 years ago
    I think the idea is to use them instead of the existing coils.
    Some of the entrants are using hardware designs that preclude the demo kit coils.
    There will be some change of the characteristics, and Simon did a posting linking to the datasheet for each of the other coils some time ago in Wireless Power.
    You may have read Hendriks very excellent post and his table of distance and displacement.
    Wer misst, misst Mist - or measuring the performance of the wireless demo kit
    or the english version
    http://blog.hendriklipka.de/archives/2014/03/wireless_power_measuring_qi.html
    You have also been granted a voucher for additional purchases, so you could purchase IC's and parts if you wanted to make the full system.
    Sharing the pcb design (since we all have Eagle) would save some of the others, and provide a good start for many others.
    I haven't quite figured out how we order the coil/coils and Christian is on holiday so I am not asking him.
    Cheers
  • hlipka
    0 hlipka over 12 years ago
    For me the interesting use case is to get a round coil (my kit came with a rectangular one).  Since I cannot guarantee exact placement of the receiver, I want to get as much wiggle room in regards of offset between transmitter and receiver coil. And it should be the same in all directions, regardless of orientation.
    And no, the coil alone cannot be used, you need a receiver IC. Even in the case of a phone charger such electronics is included, I suppose.
  • vsluiter
    0 vsluiter over 12 years ago
    If you design your own receiver hardware or want to put the coil further away from the electronics without demolishing the demo circuit,  you'll need additional coils.
    You can order these at Farnell, or contact your local Wuerth distributor whether they're willing to support you if you build your own circuit.
    I participtated in the previous Wireless Charging Roadtest Challenge, and equiped several devices with a receiver circuit (LEGO train, robot, LEGO battery pack, LED circuit), where each of course needed its own charging coil...
    Victor
  • ipv1
    0 ipv1 over 12 years ago in reply to vsluiter
    Can you provided more detail?
  • ipv1
    0 ipv1 over 12 years ago in reply to mcb1
    Well I would like to seem the effect of changing the coils by myself. My primary activity here is the design, but I am getting more and more curious about how the coils performance varies... My suggestions for the additional coils? I'm already having a tough time finding the datasheet of the one provided on the receiver...
    0 mcb1 over 12 years ago in reply to ipv1
    Inderpreet
    the link to the page doesn't work, but the code number is correct.
    This page even gives an Eagle download
    http://katalog.we-online.de/en/pbs/WE-WPCC_Receiver/760308103202?m=n&sp=http%3A%2F%2Fwww.we-online.de%2Fweb%2Fen%2Felectronic_components%2Fsearchpage_PBS.php%3Fsearch%3D%2B760308103202#vs_t1:3
    Try this link to the datasheet
    http://katalog.we-online.de/pbs/datasheet/760308103202.pdf
    sleuz
    You may wish to update the link
    edit
    Sorry the above wasn't for Eagle but for various other CAD drawings.
    Well done Simon quick response.
  • sleuz
    0 sleuz over 12 years ago in reply to mcb1
    Thanks for your help on this Mark.
    Document has been updated and the links should work now.
    Merci
    Simon
    0 mcb1 over 12 years ago in reply to sleuz
    Gern geschehen
