Ben Heck Featured Content
  • Ben Heck Featured Content
Forum Engine Management
  • Replies 63 replies
  • Subscribers 48 subscribers
  • Views 6569 views
Engine Management
jack.chaney56
jack.chaney56 over 10 years ago
Hi Ben,
I am a programmer with a very small amount of skill with circuits, and am looking to create a platform for an engine management system, using an Arduino Mega 2560. I had done a bit of the coding, when I ran into some timing issues with the built in Arduino manager, so I switched over and started using AVR Studio and a programmer to go directly to the chip itself.  The code looks like it should work ok, but now I need some additional circuits to handle the energy levels of coils and injectors (Something like IGBTs). Sensors are being run through simple dividers (no protection yet), and cam and crank inputs are through a simple comparitor
Let me know what you think,
Jack
  • jack.chaney56
    jack.chaney56 over 8 years ago +2
    Back again... After a bit of time away seeking enlightenment (and a steady paycheck), I am ready to get back to work on my project. I have continued to play around with the code and a number of components…
  • jack.chaney56
    I want to start this thing right, so the shopping list for people that want to play along at home: Raspberry Pi - version is not significant if you don't mind a slow response when using Eclipse, but 3B…
  • jack.chaney56
    Start off with two things. First, I forgot (neglected) to provide instruction on how to get the compiled code onto the Nano. Fault of familiarity; having done the process so many times, I had shifted to…
  • clem57
    clem57 over 10 years ago in reply to michaelkellett
    Engine Management (part 1: basic principles)
  • jack.chaney56
    jack.chaney56 over 10 years ago in reply to clem57
    There are 4 installments there.  The Blog is probably going to run the collective
    Updating documents via Blog site Engine Management project .  Up to 7 now
  • jack.chaney56
    Back again...
    After a bit of time away seeking enlightenment (and a steady paycheck), I am ready to get back to work on my project. I have continued to play around with the code and a number of components. First, I wanted to have a more interesting development workstation, so I thought it would be fun to use a Raspberry Pi. After installing the latest version of Raspbian and getting all the updates, I loaded the AVR tool set, then Eclipse and the C/C++ components. Then adding the AVR plugin and whoopee I had a workstation.
    I also really wanted to use the Nano for a platform but had problems with adding controls for 8 cylinder coil on plug and still be able to have outputs for solenoids and idiot lights (shift, MIL, etc). Then I thought of using 4 of the port lines to control a 74LS138 and using a bunch of 74LS75s and some inverters, route the other 4 port lines available to create a multiplexed switch network. Got it to light LEDs and the scope signals look right too.  The last part of the puzzle for the Nano was since the 328p is limited for timers, I got inventive for some of the timing pieces (fueling is less time critical).
    So I created a dual path, with the majority of software files being shared between both platforms, only when hardware forces there to be a difference, the same code runs on both Mega2560 and Nano.  I will attempt to provide all the how-to for the development workstation, the Nano setup and programming, and source code with design theory.
    Since much stuff has been refined over the course of time, I will probably be redoing a bunch of stuff and there will probably be a bunch of  repeat.  For anyone interested, it is possible to get a big dose of what is to follow by looking over the early work at Engine Management project
    I am now in the throws of developing the UI to provide the calibration in a more comfortable way. Again, trying to stay with using a Raspberry Pi as the UI platform too.
    Jack
  • 14rhb
    14rhb over 8 years ago in reply to jack.chaney56
    Hi Jack,
    I've just come into this thread but see it is over two years old and someone initially told you it couldn't be done....well my philosophy in life is that if someone else managed to make X in the past then it should be possible to make one myself (sometimes this doesn't work due to limited finances, time, materials, legality or equipment; but in theory nothing should hold you back).
    Look forward to your updates now you are back on track.
    Rod
  • rsc
    rsc over 8 years ago in reply to jack.chaney56
    Hi Jack,
    Interesting project for a single software developer. When I worked at Chrysler in the engine controls group they needed over 30 people to code, calibrate and develop hardware for the SBEC controller.
    Good luck,
    Scott
  • jack.chaney56
    jack.chaney56 over 8 years ago in reply to rsc
    Hi Scott,
    Were you on the second floor over the Dyno Cells?
    Jack
  • jack.chaney56
    The structure of the information, to follow, will be:
    Timing - For whatever is being done with the motor, either ignition or fueling, it is necessary to know the current angle, and the angular velocity. This is obtained using the CAM and CRANK input signals.
    Scheduling - Knowing location and velocity, it is possible to predict time to events.
                             The coils need to be charged and ignition has to occur at a specific time
                             The fuel injector solenoids need to open and close to supply the proper volume of fuel.
    Calculation - Ignition and Fueling.
                             Ignition requires specific timing for angle of advancement, and start of dwell.
                             Fueling calculates the quantity of fuel and depends on mass air flow combined with target air fuel ratio.
    Sensors - The calculated values depend on measured values during operation.  Using A/Ds and providing conversions.
                             Sensors provide measurements for pressure, temperature, throttle position and other values at different locations in the system.
    Steady State vs Asynchronous behaviors - changes in load or demand, and making quick adjustments to improve performance. Math tricks and creative use of units.
    Calibration - Providing adjustments to "tune" the operation and optimize behavior for whatever is required.
    Monitoring - communication of operating parameters
  • jack.chaney56
    I will also have configuration steps for making your own workstation and development platform for anyone that wants to play at home :-)
  • rsc
    Hi Jack,
    I started downtown, then moved to Auburn Hills 3rd floor engine and chassis controls for large car platform.  The coolest toy they had was the engine simulator cube.
    Scott
  • jack.chaney56
    Nice, so you knew Fred, Ron, Dale, and Bob, or were you after that (probably yes if you came from HP).
    Jack
    ps. Trying to keep names and details obscure to protect the innocent.
