Ben Heck Featured Content
  • Ben Heck Featured Content
Forum Arduino Oscilloscope with Processing.
  • Replies 21 replies
  • Subscribers 44 subscribers
  • Views 2489 views
  • portable
  • challange
  • build_challenge
  • ben_heck
Hi, I think this would be a highly useful build for those viewers on a budget. Not all of us have the ability to buy a oscilloscope so I think this would be replicated by a lot of people. It would run a processing sketch that would display a few different channels in different colors like red, green, or blue. And it wouldn't be big, it would be somewhat a compact package with an arduino and anything else that would make it work.
    shabaz over 11 years ago +1
    Hi Jordan! If you're flexible on hardware, there is a simple analog signal viewer here that uses a Raspberry Pi and XMOS board, so still fairly cheap. It's not really an oscilloscope (none of these projects…
    Hi Jordan!
    If you're flexible on hardware, there is a simple analog signal viewer here that uses a Raspberry Pi and XMOS board, so still fairly cheap. It's not really an oscilloscope (none of these projects are) but perhaps good enough for viewing simple low-frequency signals.
    There are a few other projects that do similar things. Click here for a PSoC board project with an LCD display. Alternatively there is a project using a TI board.
    e14 Contributor over 11 years ago in reply to shabaz
    While those projects are good and all, they're not really what I'm looking for, though the last url was the closest idea I had. I'm thinking a small compact unit with just a few passives to make sure the Arduino can handle it. (example. resistors to bring down currents then in the sketch it would boost the current to match the actual current.) - Thank you for some examples though.
    michaelkellett over 11 years ago in reply to e14 Contributor
    You really can't make much of a scope with an Arduino because the ADC is much too slow - for  a reasonable scope you need at least 100M samples per second per channel (even the really cheap Rigol and similar ones do this).  Even the fancy Arduinos based on ARMs can't cope.
    To make a scope you need a decent front end (amplifier with adjustable gain), a fastish ADC and something to process the data (usually an FPGA or custom chip) - once you've put all that on a shield the Arduino isn't really bringing much the the party.
    The Red Pitaya is a not bad effort to make a cheap single board scope from standard bits but it costs about £300 - you could buy  a Rigol or a Pico for the same money and it would work a whole lot better (but you couldn't reprogramme it yourself).
  • clem57
    clem57 over 11 years ago
    I have to agree with @Michael Kellett, but how about a Raspberry Pi connected to a BitScope Micro for under $200? image
    Comments?
    Clem
    e14 Contributor over 11 years ago in reply to clem57
    Yeah I guess that makes sense but it would still be cool lol
  • toxxn
    toxxn over 11 years ago in reply to clem57
    For under $200 you can get a small oscilloscope.
    Still expensive in my opinion, but it's an oscilloscope nonetheless.
    Example:
    Portable Mini Nano Arm DSO201 Pocket Sized Handheld Digital Storage Oscilloscope | eBay
    There is also the XprotoLab Portable which Ben featured in one of his episodes.
    This one cost around $100
    e14 Contributor over 11 years ago in reply to toxxn
    Thanks for some more info, but do you have the url for the xprotoLab portable
  • clem57
    clem57 over 11 years ago in reply to e14 Contributor
    XprotoLab is $50 or so...
    Thats Tiny Maaan! but explainable for the price.
    michaelkellett over 11 years ago in reply to toxxn
    That isn't a proper scope, the spec is very poor, only 1Ms/second - so the maximum frequency of signal you can reasonably look at is 100kHz. Even simple micro based devices like Arduinos have 16MHz clocks so you couldn't use it to work on them.
    Far better buy a second hand scope (Ebay ?) for the same money.
    The XprotoLab is faster sampling (but still only 2Ms/s but the display is tiny - I can't see it being much use.
