Ben Heck Featured Content
  • Ben Heck Featured Content
Documents Ben Heck’s Raspberry Pi Zero Portable Episode -- Episode 244
  • Author Author: pchan
  • Date Created: 30 Jun 2016 7:31 PM Date Created
  • Last Updated Last Updated: 24 Jun 2016 7:24 AM
  • Views 4508 views
  • Likes 11 likes
  • Comments 28 comments
element14's The Ben Heck Show
Connect with TBHS
Featured Bonus Materials
See All Episodes
In this episode Ben uses the Raspberry Pi Zero to create the smallest Pi portable computer that he has ever made!
Supporting Files
Click Herefor access to all the supporting files you will need to replicate this build!
Bonus Content:
Ben Heck's Raspberry Pi Zero Portable Contest Video!
Winner Announcement: Ben Heck's Raspberry Pi Zero Portable!
Check out more Raspberry Pi Projects in Ben Heck's Raspberry Pi Builds!
  • hack
  • ben heck's raspberry pi builds
  • episode 244: ben heck’s raspberry pi zero portable
  • ben_heck
  • heck
  • ben
  • tbhs_ep
  • bh_buildkit
  • makerkaren
    makerkaren over 10 years ago +2
    I'm working on getting all the files posted and linking the github to the peisode, but here is what we have for now. https://github.com/thebenheckshow/244-tbhs-raspberry-pi-zero-portable
  • rider51
    rider51 over 10 years ago in reply to makerkaren +1
    Do you know when the parts list will be updated on the GitHub?
  • retrogamer
    retrogamer over 10 years ago +1
    Really like this build. Something relaxing about soldering. Enjoyed watching Ben solder up the switch matrix. Really cool build, and awesome video.
  • aeitzean
    aeitzean over 8 years ago in reply to demonclaw
    Im not sure if I'm too late, but i think that the pins are defined in the keypad driver source, in the 'define' section:
    #define col0  22
    #define col1  10
    #define col2  9
    #define col3  11
    #define col4  5
    #define col5  6
    #define col6  13
    #define col7  19
    #define col8  26
    #define col9  7
    #define col10 12
    #define col11 16
    #define col12 20
    #define col13 21
    #define row0 27
    #define row1 17
    #define row2 4
    #define row3 23
    #define row4 24
    So column 0 (the first column) is pin 22, row 0 (the first row) is pin 27, etc. If i'm wrong I'd love to know before I try to use this myself, but that's what I think so far.
    Edit: ok so those are the broadcom chip pins, which translate to the pi pins like this:
    https://github.com/thebenheckshow/244-tbhs-raspberry-pi-zero-portable/blob/master/DataSheets/GPIO.png
    You can see the broadcom numbers as GPIO#
    So col0 = GPIO22 = pin15
    Its a bit complicated but I hope this helps.
  • suavesmeigle
    suavesmeigle over 9 years ago
    A s7 edge screen on that would be joy
  • demonclaw
    demonclaw over 9 years ago
    I'm trying to make my own copy of this but I don't see which pins were used for the keyboard matrix I looked over the files and don't see which were used please help.
  • makerkaren
    makerkaren over 9 years ago in reply to xfx9500
    That might depend on the program you are using to open them or if Ben saved in metric or SAE measurements, then which your program is set to. I've seen 3D design/printer programs scale files strangely due to these factors.
  • xfx9500
    xfx9500 over 9 years ago
    hi
    way are the stl files broken =?  image
    all parts have the wrong size !°
  • makerkaren
    makerkaren over 10 years ago in reply to skyplace345
    Thanks for the heads up. Looks like Ben had some of the layers turned off when he saved so it doesn't translate to older versions of AI. I'm having them fix it and Felix will update the file on github. Watch for the commit to be more current than July 4th.
  • skyplace345
    skyplace345 over 10 years ago
    Mr. Heckendore when I downloaded your Pi zero portable build guide I discovered that there isn't the laser cut parts included ) :
    Can you Please update it as soon as possible PLEASE and include hose laser cutting files.
  • skyplace345
    skyplace345 over 10 years ago in reply to rider51
    Well I think he used:
    Lithium Polymer battery 3.7v 2500mAh
    Powerboost 1000c
    Raspberry pi zero
    Slide Switch
    4.3inch Lcd camera monitor
  • nobble
    nobble over 10 years ago
    Alright now we have to see this amazing Pikedex for real!!! 8)
  • ravelox
    ravelox over 10 years ago in reply to ravelox
    I etched a PCB for the filter circuit and soldered everything up. It sounds much better. https://www.youtube.com/watch?v=ZgBQyksaOro
