Ben Heck Featured Content
  • Ben Heck Featured Content
Documents Ben Heck's Workshop Hacks Episode -- Episode 162
  • Author Author: joeman
  • Date Created: 5 Dec 2014 4:38 PM Date Created
  • Last Updated Last Updated: 28 Nov 2014 8:24 AM
  • Views 1360 views
element14's The Ben Heck Show
Connect with TBHS
Featured Bonus Materials
See All Episodes
This week, Ben is hacking a material rack, desktop PC power supply and a CNC chip supplier on the newest episode of The Ben Heck Show. Watch how he masters these projects from his new shop!
  • ben_heck_show
  • heck's
  • episode
  • 162
  • hacks
  • ben_heck
  • ben
  • tbhs_ep
  • workshop
    where can we get the templates for the power supply case you build in this video?  seems like a good design i'd like to replicate.
  • darshevo
    darshevo over 11 years ago
    An addition I would make to your vacuum manifold would be a 3rd valve with a vacuum hose attached that you could open when you were done with your routing to clean up the last bits missed by the collection system. I have a few of those ports in my shop for sawdust cleanup.
    Its really important that you have a ground line in the system to prevent static from developing in the air stream. THIS IS MUCH MORE IMPORTANT THAN A SIMPLE BYLINE IMPLIES...  This can cause lost communications to your servos or steppers - wasting material, or worse be potentially destructive to controller electronics. The ground line should run thru the entire air stream -  collector, piping and vacuum, then ground to the frame of the machine, the controller, the pc, and ideally earth ground. This is critical if you route any plastics or foams.
    Additionally - if you route any aluminum using a coolant misting system and chip recovery, explosive vapors can develop in the vacuum during operation. i disconnect my chip system and table vacuums when routing aluminum.
