Ben Heck Featured Content
  • Ben Heck Featured Content
Documents Hex Game 03: Hex Game Review - Advice from Avid Technology -- Episode 327
  • Date Created: 7 Dec 2017 8:44 PM Date Created
  • Last Updated Last Updated: 26 Jan 2018 8:24 AM
  • Views 2729 views
  • Comments 11 comments
element14's The Ben Heck Show
Hex Game
Community Feedback
See All Episodes
James Ray, the engineering department manager at AVID Technologies, joins Ben to discuss the Hex Game Prototype the team has been working on. AVID Technologies is a design services company that takes concepts into full production, utilizing sister companies throughout Avnet.
James Ray gives his initial observations of the Hex Game.  The switches give it a nice tactile feel, the buzzer gives good feedback, and the simple design looks really good.  It was also fun to play with.  His suggestions include improvement on the ergonomic design, so that it feels better in your hands.  He also suggests adding radio communication so it can link up to up to your cell phone for added game play options.  This would have minimal impact on the certification as long as you pick a certified radio and didn’t adjust anything in the RF path.
If you were to follow his suggestion, you could add a radio addition using a BBC:microbit, for example.  That would give you more flexibility and additional game modes.  Making the board a carrier for the BBC:Microbit could improve marketability and expand the target audience.    They’ll need to contemplate the tradeoffs between incorporating a radio module into their design versus making it a carrier for the Microbit.  They also need to settle on function.  Is it part of a kit for kids to put together or could it be incorporated in tech classes to practice soldering, learn hex or binary, and programming.
Following up on James Ray’s advice, they prototype a BBC:Microbit module. James recommends using something that is already made to plug into their hex game. He goes over considerations for placement of the antenna. Any metal in proximity to the antenna will detune the antenna and make it resonate less optimally. Anything that has capacitance, including mounting screws, will introduce a shift in the resonant frequency.  Felix locates the datasheet for the card edge connector, which Ben uses to find the dimensions, and goes to work designing a 3D model to see how it might fit into their kit. Ben and James go over the pros and cons of incorporating the BBC: Microbit.  The pros are that it’s well-documented, fairly powerful, it’s certified wireless, it’s got a lot of software, there’s name recognition, an LED matrix, and switches.  A big con would be the form factor.  They’re trying to find an orientation for placement but are running into trouble because the coplanar version of connector is through-hole.  There is a surface mount vertical version but they don’t want it to be vertical. The microbit solves a lot of problems but it creates physical layout problems.
Disclaimer
  • hex game
  • rf path
  • led matrix
  • hack
  • octal notation
  • card edge connector
  • hexidecimal
  • through-hole
  • episode 327: hex game 03: hex game review - advice from
  • ergonomic design
  • bbc microbit
  • radio module
  • coplanar
  • binary notation
  • capacitance
  • heck
  • ben
  • tbhs_ep
    DAB over 8 years ago +3
    Nice discussions on the issues involved with taking a prototype to a production environment. I think I would go with a PSOC instead of the Microbit. You would get much more capability for inputs (capacitive…
  • RovertScott
    RovertScott over 8 years ago +3
    When the idea of having it connect to your phone was proposed, I too groaned. I hate the idea that everything must have phone connectivity. It sounds like a "Millennial Problem" than an actual one. There…
    beacon_dave over 8 years ago in reply to DAB +3
    What's the education sectors adoption/support like for PSOC ? Perhaps one advantage of the micro:bit is that it is already out there in the education sector and there is a growing amount of curriculum…
    I think I would go with a PSOC instead of the Microbit.  You would get much more capability for inputs (capacitive sense) and outputs.
    You would get a lot more growth capability and upgrade options.
    Perhaps one advantage of the micro:bit is that it is already out there in the education sector and there is a growing amount of curriculum support materials based around it. It may not have the inputs of the PSOC but it may be easier to launch an educational kit like this into an already established market.
    I suspect that a lot of educational hardware kits struggle to keep student interest on their own if there are no easily accessible student 'workbooks' to continue the learning process.
    This project has perhaps reached a fork in the road. Is it what it started out to be - a stand alone hex trainer game/electronics kit, or is it perhaps going to be a more generic user interface to an established educational infrastructure.
    DAB over 8 years ago in reply to beacon_dave
    Hi Dave,
    The development environment for the PSOC is well supported and relatively easy to use.
    The big advantage over the microbit is a more robust voltage interface, programmable pin termination plus the programmable digital and analog hardware blogs for custom circuits.  All for about 4 USD.
    So if you want great hardware and software flexibility, I would go PSOC.
