element14's The Ben Heck Show
Forum challenge: xbox 360 red light fixes
  • Replies 10 replies
  • Subscribers 30 subscribers
  • Views 1070 views
  • challenge
i have an xbox 360 and i have had a little bit of a problem with red lights and error codes so i guess i was wondering if you can help me out in fixing my problem so i dont have to shell out an extra 200-300 bucks on a brand new one the primary error code is E73 and the secondary error code is 1021 i think alot of people would appreciate it if you could show us all a way to fix our xbox 360's in a cheap and easy way to do it at home, PLEEZE HELP!!!
  • Kelv
    Kelv over 15 years ago
    Hi Dalton, there is no sure fire home method of repairing those faults. The issue is caused by poor design of the GPU and compounded by poor ventilation / airflow. Proof of this is in the new Xbox Slim. Cpu and gpu integrated into one package and no sign of overheating consoles ... yet, its amazing whats achievable when you let experts design it rather than "doing it on the cheap".
    The only real way to repair this fault is to remove, reball and refit the GPU. It is actually achievable at home but does require some specialist hardware. I used a hotair rework station, a hot plate, a re-balling jig and a couple of temperature sensors.
    The issues can be made worse by people attempting to reflow the GPU by overheating, Towel-trick or paint stripper and clamping the GPU tighter to the board as the fault then has oppotunity to erode the pads on which the BGA sits. More damage to the pads can occur by over-cooking the chip.
    Having done 2 on the cheap, I would suggest taking your time, researching the reflow temperature curves and removing the epoxy that M$ decided was a good idea to hold the chip down.
    e14 Contributor over 15 years ago in reply to Kelv
    well when i did research on the error code it says that there is just a cold solder joint under the southbridge ethernet port area so wouldnt it be logical to just remove the solder and re apply the solder at the appropriate joint (if located)
    What you have is said is correct. I have worked on dozens of xboxs and spent hundreds of hours in research. what i have found is there is ONE website that has people who really know what theyre talking about:
    http://xbox-experts.com/tutorials.php
    Resoldering is one option. But a considerably cheaper, easier, and quicker method is to reflow the solder underneath the cpu and gpu. For this surprisingly all you need is about $20 in supplies and an oven. Before you go off and call me a crackpot, just hear me out.
    The first thing you need to do is strip the xbox down to its bare motherboard, no heatsinks or cables attached. Then you need to place the xbox, unshielded, in an oven at a low temp <200 degrees. This link explains it better:
    http://xbox-experts.com/tutorial/oven-bake/
    After that you need to make reusable heat shileds:
    http://xbox-experts.com/tutorial/u6-reusable-heat-shields-for-oven-reflows/
    http://xbox-experts.com/tutorial/reusable-heat-shield-for-an-oven-reflow/
    either one is suitable, your choice
    This is to protect the sensitive parts of the board, while you use a standard oven to reflow the solder underneath the chips
    Here is the oven reflow guide:
    http://xbox-experts.com/tutorial/the-ultimate-xbox-360-oven-reflow-tutorial/
    Let that cool, put everything back together (make sure to remember to put new thermal paste on the chips), and you should be good to go.
    Now some xboxs are stubborn. if the reflow fails after a few days then you need to address the real issue, the massive design flaws of the old xbox 360:
    http://xbox-experts.com/tutorial/team-hybrids-ultimate-xclamp-fix-released/
    I know this a lot of reading, BUT I have confirmed that this is the only place on the internet that deals with xboxs from a scientific approach. Read for yourself. If you're into the heatgunning and all that, the first link i gave has info on all that stuff
    Cheers!
    thanks for the help ill look into it and if it doesnt work ill either send it to a couple of guys i know that may be able to fix it or beg my mom to buy me a new one lol
    Thanks Again!!!
    no problem. lemme know how it goes
    just got it insulated and in the oven now i just gotta wait and hope it works
    about to remove it from the oven just a few more mins
    and it worked thank you so much now i finally have a way to entertain myself at my moms house thank you so much i dont know what id do if i never asked for help ben heck himself gave me the idea just by watching his videos i give him and you all the credit thank you
    no problem. Make sure to monitor it for the next few days. Sometimes theyll work for a bit, then die out again. Other times its fixes them permanently. remember that if it does break again you should do what it says here:
    its been working lately so i think its permenant but its only been a few days so im still observing it
