element14's The Ben Heck Show
Forum Maker bot thing o matic
  • Replies 12 replies
  • Subscribers 31 subscribers
  • Views 1302 views
  • challenge
hello ben my name is nick and I'm 13 years old since I was 9 I was fascinated with technology but sadly I can't build or test anything I think of because I'm inexperienced and don't have any money can you help me. My teacher at school gave me his old maker bot thing o matic but I can't get it to work can you take a look at it or better yet fix it it would help me a lot. if you give me an address I can send it to you thanks. My email is nick@mcgouirk.com
  • kidiccurus
    kidiccurus over 12 years ago
    This might help. If not post again. Thing-O-Matic Troubleshooting. Also, please be more specific about your problem. Can it move? Does it give any error messages? Is it damaged?
  • Nate1616
    Nate1616 over 12 years ago
    Nick
    Can you ask your teacher what is wrong with it?  It might be easier as we could give you the answer to get you up and running.  For what it would cost you to ship it, it might be worth having one of us here on E14 to help you get it up and running.
    Nate
    e14 Contributor over 12 years ago in reply to Nate1616
    I have asked my teacher but he dosent want to help he says it's a waste of his time and the problem is I can't get it to run from my computer
    Icant tell if there are any other problems it moves fine and there are no error messages from what I can tell
  • Nate1616
    Nate1616 over 12 years ago in reply to e14 Contributor
    This might sound stupid but have you downloaded the ReplicatorG host software that will allow you to connect to the printer?  Can you see the board show up in your Serial Port on the computer?  Here is the place to install the drivers ReplicatorG Windows Driver Installation.  Also try this page ReplicatorG Troubleshooting.
    Nate
    Yes I have already done that
  • Nate1616
    Do you see the board showing up on the computer?  If you dont see it then either you have a driver issue or bad printrboard.  When you say it moves fine are you sliding the axis's by hand?
    Nate
    Yes I see the print board no I'm not moving the axis by I'm using the replicators g program
  • Nate1616
    Nick,
    If you can move the axis and home it in ReplicatorG then can you explain what you are having problems with.  It seems like it is working then.  Have you loaded a gcode file to print?
    Nate
    I have loaded a gcode program but it won't let me print
