element14's The Ben Heck Show
Forum Need help identifying an early 90s PCB thru-hole transformer and a few other questions
  • Replies 20 replies
  • Answers 7 answers
  • Subscribers 34 subscribers
  • Views 4232 views
chrisbc
chrisbc over 8 years ago
Hi. I need help identifying an early 90s PCB transformer. It's on an auto-idle control board from an early 90s gas-powered generator from a company that has since gone out of business. I'm not familiar with components but think I can identify all of the other components to remake another board in case of a catastrophic failure. The problem I'm having is identifying the size and type of what I think is a transformer. I've included a few pictures. It's located at the bottom of the board and has a yellow and red wire wrapped around it. The red wire comes from the generator head and goes out to a breaker to power the receptacles, and the yellow wire comes from a terminal lug next to another terminal lug which accepts the other (yellow) wire coming from the generator head.imageimageimage
And can anyone tell how big the small capacitor is that's located to the right above the transformer? I can't find any marks on it other than the temperature rating.
I also have to replace a 5W 82ohm resistor that blew due to a bad Schottky diode that I've found and will replace. Would it be safer to replace the blown resistor with a 12W 82ohm resistor? And can I use an aluminum encased surface mount resistor on a thru-hole PCB?
Any help would be appreciated!
    jw0752 over 8 years ago +4 suggested
    Hi Chris, The small capacitor is probably marked on the side that is glued down. You may have to pry it loose carefully. You can up the wattage of a resistor without any consequence except that of a larger…
    jw0752 over 8 years ago in reply to chrisbc +4 suggested
    Hi Chris, If you mount a power resistor on the board make sure it is in a raised position so air is free to flow around it. This will keep it from damaging the board. You may not get the full wattage dissipation…
  • three-phase
    three-phase over 8 years ago +3 suggested
    I would agree with jw0752 that the small transformer is a current transformer measuring the load on the sockets to allow the engine speed to be controlled based upon the load the generator is supplying…
  • chrisbc
    0 chrisbc over 8 years ago in reply to mcb1
    I may re-use the old ones but will these work? CERA-MITE .01uF 250v 103Z 12mm disk Radial Ceramic Capacitor? They're 12mm instead of the 6mm on my board... Would it be okay to squeeze them in? And how do I test ceramic disc capacitors? I only have an average digital multimeter but can check capacitance and diodes too. The two SCRs are MCR100-8 thyristors, I've ordered some of those along with a replacement electrolytic cap which was a 47uF 16v.
    Here's a picture of the back of the board and a picture of the pull solenoid that's hooked to the engine's governor arm that the auto-idle board controls. I've pulled a few of the components so is still some flux I've yet to clean off the board. The darkened area on the board is where the 5W 82ohm resistor blew and made a mess (I've cleaned out the carbon with a Dremel). I think I'll replace it with a larger 12w 82ohm resistor.
    0 shabaz over 8 years ago in reply to chrisbc
    Hi Chris,
    The ceramics look good, they don't really need changing. Physically bigger ones would be fine if you really want to, but it is not going to fix anything, because the originals won't be faulty.
    Can I ask, where are you getting your replacement parts from?
    The reason I'm asking is because if I google "CERA-MITE .01uF 250v 103Z 12mm disk Radial Ceramic Capacitor" then I get hits on Amazon and ebay.
    That's not really a good source for parts. You might get lucky with them, but if you're obtaining your semiconductors, i.e. the SCRs from there too, that rings some warning bells. From personal experience, there is a significant risk of getting fake or pre-used parts disguised to look like new.
    Fake/pre-used and real semiconductors are difficult enough for any engineer to distinguish visually (and sometimes even with test tools), so it really isn't worth the risk unless perhaps it is for some low power hobby experimentation (which isn't the case for your repair).
  • chrisbc
    0 chrisbc over 8 years ago in reply to shabaz
    Hi shabaz. Yes, that is where I ordered the MCR100-8 SCRs from... coming from China. I couldn't find them anywhere else in stock. I'm not very familiar with electrical components or where to get them. Where would you suggest I get them where decent quality can be reasonably assured for a moderate cost? Yes, I have bought electric motor bearings off Ebay and found they were counterfeit.
    Hi Chris,
    It could be an obsolete part, I can't find it on the original component manufacturer site (On Semi).
    It is likely that an alternative replacement will have different pin ordering, and might be a different size, so you may need to be adventurous with how you physically mount it (e.g. bending wires into a different order).
    The Farnell website is currently offline, so I'll check later on for a close substitute to hopefully meet your needs.
  • chrisbc
    It was originally made by Motorola. I found an MCR100-8 equivalent on wholesale electronics and ordered a couple. Why would they change the pin order? Is it standard practice to bend and switch pins around? Wouldn't there be a standard pin order that manufacturers follow? Thanks for the info. and the help though... I should be able to fix it from here.
    0 jw0752 over 8 years ago in reply to chrisbc
    Hi Chris,
    Here are some very close equivalents:
    http://www.newark.com/search?st=BT149
    Seems that the MCR100-8 are no longer being produced.
  • chrisbc
    0 chrisbc over 8 years ago in reply to jw0752
    Thanks John.
  • three-phase
    0 three-phase over 8 years ago
    I would agree with jw0752 that the small transformer is a current transformer measuring the load on the sockets to allow the engine speed to be controlled based upon the load the generator is supplying. As John as said they are usually very robust.
    If you do have concerns about it, they can be tested by injecting a current through the primary and measuring the output current on the secondary, depending on your circuits the output current may be converted into a voltage. If you take a few readings at different current inputs you will be able to plot the ratio, which should be consistent across the range. This of course depends on what test apparatus you have and the setup you can achieve.
    If you have a failure, coils can generally be rewound by dismantling them and identifying the wire size an number of turns, quite a slow painstaking job for something that small.
    Kind regards
    Donald
  • chrisbc
    0 chrisbc over 8 years ago in reply to three-phase
    Thanks Donald. That's definitely something I'll keep in mind for future reference.
    I've noticed that Desa had slightly revised their board design in 1998. I've found both of the 68k resistors to be toast; they are 1/4w and the newer revised board looks to have 1/2w resistors, which is what I'll replace them with. The 1k and 2k resistors are fine.
  • jleblanc321
    0 jleblanc321 over 7 years ago in reply to chrisbc
    Hi!
    I am trying to repair the same type of PCB.  I have it almost figured out, but I need to know if SC1 and SC2 are the same P/N.  My SC2 is fried, along with the resistor, so I cannot read the writing on the face of the TO-92 housing.  SC1 is a X0205NA SCR based on the writing on the TO-92 face.
    Thank you,
    Jay
