element14's The Ben Heck Show
Forum challenge
  • Subscribers 31 subscribers
  • Views 646 views
  • hardware
  • build
  • build_challenge
  • idea
  • challenge
  • ben_heck
  • show_idea
challenge
Hi Ben,
I would like to build a system in my house where whenever people are in rooms the lights are on and when they leave they go out, also i would like to have it where each person maybe has a transmitter on them so that when they enter a room the system plays the style of music they like and maybe even adjusts the temp in the room to their preference.
If you have any ideas on how to do this or if you could please do a show on this it would be amazing.
Thank you for your time.
Dean Arvonen
mejake2009@hotmail.com.
    Its called home automation and there are systems on the market that will do exactly what your wanting and more. They just cost hundreds of thousands of dollars.
    The lights thing is easy enough with a motion sensor.When you get into adjusting temp settings and start playing music you get into a much more complicated and expencive setup.
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Thankyou for the reply, but that's why I was wondering if anyone new of a way to do it yourself
    Probably the easiest way would be to set up an RFID reader at the door of the room. Then you scan your RFID tag the system could turn on your sound system and call up your play list. Adjusting the air temp may be tricky. Unless your talking the whole house/apartment and not just a single room. Unless you have a place where each room has its own temp control. You can find al sorts of projects online dealing with various micro controllers, RFID readers and even some thermostat controlled with a micro controller.
  • benheck
    0 benheck over 14 years ago
    There's an existing system called X10, it sends data over your electrical wires.
    So you could rig the X10 master unit to control all the slave devices.
    We'll be doing some home automation in an upcoming episode, so stay tuned!
    0 e14 Contributor over 14 years ago in reply to benheck
    thank you so much Ben! this will help me so much because i have a ganglia in my wrist and i find it so hard and painful to use the light switch and audio system and pretty much anything manual, i wanted to do this so everything can be run off maybe an ipad or something, which doesnt cause me pain, and have it were i control the lights music and maybe temp through the ipad and anything else that uses switches.
    thank you so much for responding to my question,
    Dean Arvonen
  • Nate1616
    0 Nate1616 over 14 years ago
    Like Michael was saying that most houses to not have the capability to adjust the temp in one room.  the typical house will be upstairs\downstarits or some sort of zone split on each level.  this is expensive option since your adding tab units or vav boxes on top of your primary unit so most homes dont have this.  as for having music play depending on whos in the room you could use RFID or even a finger print scanner.
