element14's The Ben Heck Show
Forum Hi Ben, long time watcher of the TBHS. Love it & you. Need Help with Raspberry pi 2 & LCD please!
  • Replies 25 replies
  • Answers 5 answers
  • Subscribers 30 subscribers
  • Views 2810 views
  • raspberry
  • waveshare
  • lcd
  • spotpear
  • pi
  • 2
  • tft
  • 3.5"
Super new to the raspberry pi scene been watching you do various projects with them and figured it would be something new and cool to check out. got my noobs installed perfect now running raspbian.
been moving along following different tutorials trying out new things.
I finaly got stuff working on my Raspbian good and I'm starting to get a little more comfortable doing stuff on my Pi like, 1.) Installed apache and MySQL got wordpress working. (been tinkering around with it a little) also got a working copy of minecraft server vrs.1.8.4 working on my Pi.
Recently wanted to make it a bit more portable.
So I bought the 3.5" TFT LCD from Waveshare spotpear.
thought it was a no brainer plug N play with the Gpio
I pretty sure it is. but I cant seem to get or find proper soft ware, & or documentation to easily install it. there was no software when I got my lcd. it told me to go to few sites which were for the older pi.
I've read through few pages of peoples post seems a lot of new and regulars on the  Pi scene are having similar problems with lcd installations.
Currently My pi is running on hdmi to tv.
Best Related web page related info I could find so far Is http://www.wvshare.com/product/3.5inch-RPi-LCD-A.htm
Please say you can help figure this out.
Also, if anyone else who reads this if you also have a raspi2 w/ the 3.5" tft lcd Waveshare Spotpear addon card let us know if you got it working right and if so let  us know what you did or didn't do, please also provide software as I have been unable to find it.
    e14 Contributor over 11 years ago +1 suggested
    I have that same screen, ordered from china off e-mail for around $20. Ill start by saying that you get what you pay for. It is not as easy to install but it works great! These instructions should get…
    Finally got a moment to work on this..
    so I am following your instructions..
    at the fbcon=map:1 fbcon=font:VGA8x8 section
    I left this out as I want to be able to use either 3.5" or the hdmi
    if possible I would like it to work on both simultaneously.
    or be able to detect when I have hdmi plugged in.
    ok so made it further down before I ran into a problem..
    the sudo nano /usr/shar/X11/xorg.conf.d/99-fbturbo.conf does not seem to exist & wont let me save to create one.
    I have stopped at this point do to the fact this appears to be important.
    I do have a black screen now when loading btw.
    I checked some of your directories and found the problems.
    you left the (e) out in /usr/share/ part that solved that problem
    Ive finished it but cant seem to get the screen to flip or rotate in the upper direction.
    its upside down for me. I tried changing rotate but it would reboot with partial screen working
    Ok, when I run into an issue like that I start by cd'ing to each directory in the list and making sure they are all spelled correct. image
    it's "share" not "shar" If what you entered above is a copy of your line then you forgot an e.
    Correction, I left out an e. lol I correct my post above. Sorry about that.
    yeh, my main problem seems to be getting the screen to be right side up yours has mine with cords at the bottom  also the touch screen seems to be off some how.
    I've tried going back through and changing the rotate but only rotate=90 will give me any picture properly and its upside down for me.
    Ideas?
    There are two rotate points. One in modules and one in the boot config.txt
    If I remember correctly they can be 0, 90, -90, or 180
    I spent a lot of time playing with both for mine the module had to be -90 and the config had to b 90 to get it rotated the correct direction.
    It seems that they would cancel each other out but it actually flips the screen the right direction for me.
    ok finaly got screen rotated as I wanted, got the touch going in the right x & y axis but the touch does not go to edge of desktop in any direction it is like a half a centimeter short of space in each direction. what do I play with to make it go to edge of screen?
    While I wait for a response I will try to get my IOgear GBU521 adapter running and try to figure out how to make a wireless Bluetooth speaker connect (something I have been unable to do) wish me luck on this.
    Try running the touch screen calibration
    sudo TSLIB_FBDEVICE=/dev/fb1 TSLIB_TSDEVICE=/dev/input/touchscreen ts_calibrate
    sudo: ts_calibrate: command not found
    is what i do when i do your command. image
    will this guide work for the 4 inch waveshare spotpear lcd I ccan get it to work on the supplied image but I want to use my propper pi image
    and I would if attall possible use hdmi and screen and if not is it possible to stop kodi or xbmc going through hdmi and use the touch screen or both
    I forgot to sayits pi b+ plus what is the comand to just switch outputs manully as the ones supplied dont seem to work hdmi-sys-show or lcd4-sys-show
    honestly harvey I dont know. I think it will you will have to tinker with res size i think if yours gets a higher res than my 3.5" but it should work I think. as for getting both LCD & HDMI to work i have yet to be able to do that my self. currently still working out kings with the touch as it doesnt quite work yet.
    also failing at getting my bluetooth stuff installed. I think this is probly the number 1 reason most windows users still havent moved to linux is because its not so simple to install stuff on.
    But after all said and done I was so happy to see my screen work at all and even happier when I finaly got it to be in the rotation I wanted. So thank you guys for your help on this.
