Super Glue Gun
  • Super Glue Gun
Super Glue Gun
Documents Super Glue Gun Steps
Join Super Glue Gun to participate - click to join for free!
  • Date Created: 8 Mar 2017 6:25 PM Date Created
  • Last Updated Last Updated: 13 Apr 2017 7:52 PM
  • Views 775 views
element14's The Ben Heck Show
Super Glue Gun Build
Featured Bonus Content
See All Episodes
Super Glue Gun
1.  GETTING STARTED
    • Discuss original idea / episodes (use footage flashbacks)
    • Talk about what we liked / didn’t like
    • Why we believe it’s a good project
    • Map out project goals / major design challenges
    • Design drawing and sketches
    • Decide major parts and begin sourcing:
      • Hot end extruder
      • Extruder motor
      • Power supply
      • Trigger/controls
      • Microcontroller
      • Automatic stand & casing
GOAL: Create product roadmap & design spec
2.  EXTRUDER MOTOR
    • Knowing what the hot end can do and what the PSU can supply, figure out the best way to mechanically move the glue through the device
    • Source gear motors / knobbed extruder heads and work on a variety of 3D printed prototype tests.
    • Find a motor that works within the constraints of the PSU.
    • Isolate DC motor noise from the rest of the circuit. Work on stabilizing voltages.
    • Test glue loading, idle wheel spring, and basically try and break the mechanism.
GOAL: Using a PWM controlled motor, extrude glue through the gun at both low, carefully controlled speeds and high “gushing” temperatures
3.  HOT END EXTRUDER
    • Discuss why we must decide this part first (certainly before PSU)
    • Source and test multiple commodity extruder parts
    • Do safety tests & find best / cheapest method of reliable temperature sensing & control
    • Determine force required to extrude glue through gun and temperature falloffs
    • Talk about solid state current control and PWM techniques
    • Try and break it / burn it up to find the limits of safety
GOAL: Decide on a hot end and know all of its specs and how this will affect the rest of the project
4.  POWER SUPPLY
    • In this episode we figure out the best way to power our Super Glue Gun
    • Decide between cord / battery powered (probably going to be AC cord)
    • Test power supply with all conditions of the previously established Hot End
      • Figure out the cheapest way to provide (and control) high-voltage AC hot end power as well as stable 3.3v / 5v logic voltages
      • Find solutions that will provide the quickest path to UL/FCC certification
GOAL: Select the best switching control for hot end and logic circuits. Breadboard temperature sensor tests with MCU
5.  TRIGGER / CONTROLS
    • Figure out what controls and indicators the device needs and build prototypes
    • Decide best way to get analog trigger input (potentiometer, hall effect, optical)
    • Test the pros and cons of each method (ie, motor EMF could corrupt a hall effect sensor)
    • Controls will influence product case design, so start narrowing down ideas for this and do sketches
    • Begin initial tests / designs for an auto-deploying kickstand
GOAL: Translate analog trigger control to PWM DC motor driver / extruder, and see if capacitive trigger touch is affordable / easy to manufacture.
6.  MICROCONTROLLER
    • Decide what this MCU must do based off our mechanical tests thus far:
      • Temp sensing (be compatible with whatever we attached to hot end)
      • Analog trigger control
      • Capacitive touch sense – built in to save external circuitry?
      • Fewest external parts (crystals, PSU, EEPROM)
    • Source and test multiple MCUs (well before episode films) create pro/con list
    • Request help from vendors / supply side solutions?
GOAL: Select a MCU that is the cheapest possible thing that will support all of the features we’ve tested on the unit thus far (and has good availability / factory programming support)
7.  CASING & AUTOSTAND
    • Try and get an automatic deploy stand to work (controlled by capacitive touch trigger)
    • Decide if this feature is economically feasible
    • Using all previous parts, begin designing enclosures
    • Fusion 360 / software collaboration?
GOAL: 3D print an enclosure that is in the ballpark of something that could be injection molded as a final product.
  • super_glue_gun
  • ben_heck
