Super Glue Gun
  • Super Glue Gun
Super Glue Gun
Documents Community Feedback 03 - Power Safety Concerns!
Join Super Glue Gun to participate - click to join for free!
  • Date Created: 7 Aug 2017 7:59 PM Date Created
  • Last Updated Last Updated: 18 Jan 2019 4:21 PM
  • Views 1690 views
  • Comments 6 comments
element14's The Ben Heck Show
Community Feedback
Super Glue Gun
See All Episodes
Ben and Karen look through suggestions from anywhere on the element14 community on a segment called Community Feedback. This segment focuses on the Super Glue Gun Build after it just got started. Suggestions include putting a "do not try this at home" warning label when attempting to hook up mains to a breadboard in front of an audience, discussing different loads with their glue gun, and an excel sheet to deal with the non-linearity of thermistors.
Community Feedback comes from cherring ,  tm14 , and mr_widget !
Congratulations you win a Free Ben Heck T-Shirt!
cherring  was concerned when the team attempted to hook mains up to a breadboard. Ben’s explanation is that he does not consider 120 volts to be that dangerous, when they did the test they made sure that everything was isolated, and that this was the fastest way to hook it up.  Karen parses Ben’s explanation by letting the audience know that while it isn’t the safest method, it’s the fastest method, so don’t try this at home.
tm14  suggests that the team talks about different types of loads with their Super Glue Gun.  The glue gun heater coils have low inductance and are mostly resistive. As they get hotter, their resistance changes. So measuring the cold resistance is not the same as the resistance when it is hot. As Ben explains to Karen, we can’t necessarily know what the current draw actually is. It probably won’t make a difference, since they’re using AC, but if the triac is rated lower than what they need, and they are actually drawing more current than they think they’re going to use, then they could blow out the triac. The real problem with electricity is when electricity has no stopping point.
In his designs, mr_widget typically uses 25C NTC thermistors as ambient sensors for oven controllers, while he uses a K thermocouple for the thermal enclosure. He was struck by the non-linearity of the thermistors so he made a spreadsheet, which he offers the team, to help calculate correction factors for Arduino controllers converting the ADC value to a calculated ambient temp.
  • communityfeedbacktbhs
  • SteveQuinn
    SteveQuinn over 9 years ago +3
    Dear Mr Heckendorn, et. al, I have just watched your video on Power Safety Concerns and am appalled by your cavalier attitude towards the dangers of electrical shock. Speaking as a UK Chartered Electrical…
  • avfusion
    avfusion over 9 years ago +2
    I'm appalled by how you approached the AC current. 120V DC is probably okay to touch, a little tingly and uncomfortable, but the Alternating wave of AC makes a prime source to turn the human body into…
  • cherring
    cherring over 9 years ago +1
    Hi TBHS! Thanks for featuring my comment. That comment, especially the other one on youtube, kinda blew up with all sorts of ranting. I didn't mean for that to happen. Sure, I totally agree that 120V isn…
  • SteveQuinn
    Speaking as a UK Chartered Electrical Engineer who has witnesses first hand the life changing impact an electrical shock can have it simply amazes me the level of incompetent stupidity in your statement not considering 120VAC 'to be that dangerous'.
    Why not take some of your own advice and use the oft' well published Element14 community where you can connect and collaborate with...
    Perhaps if you had you would not be so quick to make dangerous asinine comments.
    I can't believe Farnell condone this type of clap trap.
  • SteveQuinn
