element14's The Ben Heck Show
Documents Help Ben Heck Finish His Portable N64!
  • Date Created: 6 Apr 2017 5:26 PM Date Created
  • Last Updated Last Updated: 28 Sep 2017 9:05 PM
  • Views 5196 views
  • Comments 55 comments
Connect with TBHS
Featured Bonus Content
See All Episodes
You must be logged into the element14 Community to submit Feedback for Ben!
Ben Heck gives an update on the much anticipated Portable N64 and requests help from the community with completing the build.  A portable N64 is one of the most frequently requested builds from members but is difficult to hack because it’s easy to damage and requires a lot of rewiring to make it portable.  Specifically, Ben needs help getting the RAM expansion to work. Help Ben finish his N64 Portable in the comments below!
View Progress Made on the Portable N64 in Previous Episodes:
Episode 275: Ben Heck's Portable N64 Part 1 Episode
Episode 276: Ben Heck's Portable N64 Part 2 Episode
In the Comments Below Submit Your Feedback to Help Ben Heck Complete His N64 Portable!
  • portable n64
  • n64 portable
  • n64
  • nintendo 64
  • tbhs_n64
  • jon4248
    jon4248 over 9 years ago +10
    Am I the only one that found this via google? Reverse engineering the jumper pak. | The Official ModRetro Forums Edit - info about: ram swap | The Official ModRetro Forums edit: or perhaps this if your…
  • sudos
    sudos over 9 years ago +6
    Shielded ribbon cable would probably be the first thing to get your hands on to try. 3M stuff, of course, nothing else. this was a problem with the PCIe stuff when bitcoin and dogecoin miners were huge…
  • mayermakes
    mayermakes over 9 years ago +5
    I think the problem is actually in the timing for the ram, (15cm/ns in copper wire if I remember correctly) Because of the way the board is routed I think the traces are calculated to have the suitable…
  • akiramods
    akiramods over 9 years ago
    yGHnWTlfKCDBjG-JQK3iYFDy5OrCNI9pmxADL9JATkZBPHjXGX92zGI1_YV0m_4Ew6AbU4lZQZ4aCHtkzlhRp-b-wpZopSQ3IfB1FeY3GRI_C6MAlb75i5EI6ojCv82z2EDaoVis1pQGpmlvdOABVTwbW1QORXmgQWWOTXvVt7u4XxXe79G6SpURnP3J-i_eIvCdQ6wyedvC5mPASP1-3Un3a-mSyb63HtKHhp-uJ9il_zW5rEJn7hlVdkfijgYqhjQ4REgMTzARI3l8bk9SQWETsrCAriuhfHpJUYVlFtR-c3NvY57Z9OGM_utKTwLMHDEgBH9ryTGZASCdHLMgrzm-Kn4jdsvpMfSR3PEGsRw1JoeXQFGqp3fM2jlHc2DnF2vcB9Jne6teI40_uF55aCQXbEIVa-KmHxK6rb7Mce5JODvt5HNgOMEXFdOI-1IWZxTYqBKM4ZlmGJNjelyeR6XkchrpMaaHydlIcqZxhMjO2e-Tj9iDW3Yq06MJTqvydofONftCohtBsaUDJj5cXwbMDN-r0a-Qa1_t_JkO8pJNE9iGKh08pi3BfFA_mHUq_X10gwoeiYG9j_qKTbMLfnmpyAtZhqMojY2rxQPKRijQikvyK_7QArdJXvfX5SfL39wE-PXd8F8xikOTp7EfpuJ3QPWDCZeo89Y=w1835-h1376-no
    I did a attempt to get the jumperpack working with 2 x 4mb ram.
    this works just fine.
    PAL Board
    - swap the 2 x mb with 2 x 4mb
    - remove the port
    - cut the solder pins from the memory expension on the board, i used my soldering iron after cutting and removing the traces was easy
    - wire up data lines to 5, 7, 9, 11, 13, 15, 19, 21, 25, 27, 29, 31 to the 510 resistor packs
    - wire up at least 3 caps to ground and backside to the common line of the backside of the 510's
    - wire a wire from pin 3 and 17
    - wire the via holes from the pins 8 and 28 to the backside common line of the 510's
    - wire a wire on the back between c311 and c71
    3PlWRgrr590YOwSMONJVlt9cC15lcAk-iMpTMlyfICKsM1WTkcFGdpK9d7eIY0-KzLnHGoc4VascuAfjb158foD-XMwFfOUcmH_Lfv94NbJbA0NtyrBoBQVzz5EtaMnIjEfra723UdOFsGO2y3O9mc8VOPlXngg6OQphnZxmgK_tpMRqh5zyulXbR2VxPmRgKe69b4xPaUbq3L58DfnB7CoZivNIhlJTP3p_gRgT7vmXfbllTg-OCD0RiygQJVz-hxp5-Wo9svbRXyrB-y7mBNJ_u9iYwlbhLMctjVOg1VF23XK1c_j8elz_bJeAtDRP5JAOb6YMPW76EEI-0PrKezii0DJvn9PxKT3jHWJzLPl5Sg5CMGHom058Eyp4X5mkElja-tqbyBUg2-ZWBLbH_gFpTvz7uO6epBZ2SWE90TyKjjou3m9OMJELPEkSKQCi8MGA9Vn1nm8NDIwdyBidVtaiPIKPrCTlwIFHghqEHMAxtpzG2ErW0u48fpMsCzbp8k-JsRXFzkYs-J9aBXKLW8aLytpE7DL7AoPGqvmTxKaC7eXfUKzHhXlvQdbxklc3Cun8zOrbDSOSJY6ogaX2w0Cr0IUJ_TbIK480kFS-r6uMEbAiSTTLc9pKk2SvjxfuBIL_GGSRllca3LJB93mjkdBT00X0A0AfIzU=w1032-h1376-no
    all working fine and you can add your heatsinks.
    98lyrjr8MVqAVXmEMdPwKMJBRIHhXPr8W0gP6WIC5lRk3AXp-Kfw1an21xXvhZT4a2b_l4le-KvkzXQ_kWNtFtpp3VMRRv0gcwwTgb-mQ-shlS00XtvBF98_99JJi4D2VMx67ayvLUMWnWMPFaqv11r1enTxDS8wPNVilA1NAHnDDqeoVXAe5IWJEhljh-x6sC27whi-xDsw6m8Jt-U8DenKEnM14ReygMXNFDY5n5DmMXxsPzit162GXNIVd7jMn3oWKdrntgAWrrGEKOMkx7NJ2fZYn6zaX_95ZtQXpMZpyIKisSOXrvVmcTgqZvaDR8oz2qGwMJTgJJJu_WVxfBnClgqyeLLeX1Vv8G1OKxWlgHTmAxg_mbu5uIAiwCYRClkI_LHwuz8aMmev8nKreNZkaB_zopeCfy9n0LugRm5bExlUQ-fujP9cTLx5Z5hII8NPe0ks4JRnpnmoj4NDSEOvEaBfntfOdp9NUFjF5s3NMD5Gwc9TsUwAHbLMUFxS5wRrgzhrZgdpNKArgOI2IQV2lxbUV0RThEFHaTmKsHaHNLSn8TGP00zNSEaPV8R2I1VTacmt_sfzA_GM4OxJy247TD_sF-BJL-Rs9507sgwvebu8TeCXAIczyHeJtjMy-MSIIu87b1_8DyeD-7gBIuW_HuY5cyflXFw=w1032-h1376-no
    screen is black and white because i wired composite out to Green plug  on YUV port
    reverence pic from modretro forum user Bentomo
  • eb1560
    eb1560 over 9 years ago in reply to akiramods
    Nice work. image
    This mod essentially removes the electrical stubbing extended onto the jumper pak.  You are essentially shifting the transmission lines to a higher impedance upon termination with those wires, just like the back of the jumper-pak.  Have you verified if Vterm is properly bypassed in this setup?
  • eb1560
    Nice work. image
  • akiramods
    akiramods over 9 years ago in reply to eb1560
    How can i check vterm?
    Tomorrow ill add some original heatsinks and let it run a few hours
  • eb1560
    The thin wires (VTerm and ground, not the data lines) connecting the resistors and caps are cancelling the ability of the caps to smooth out high frequency noise.  An oscilloscope would be very handy in this situation, but it might be more practical to have a highly stressful game (Perfect Darl/Turok II) or rendering scene run for a period of several hours - this would give an idea as to whether the RDRAM and RCP can tolerate this circuit design.
