DC to Daylight
  • DC to Daylight
DC to Daylight
Documents How to Control a DC Motor using Optocouplers with an H-Bridge -- DC to Daylight 18
Join DC to Daylight to participate - click to join for free!
  • Author Author: cstanton
  • Date Created: 14 Oct 2022 12:04 PM Date Created
  • Last Updated Last Updated: 19 Oct 2022 7:24 AM
  • Views 222459 views
  • Comments 11 comments
In this application/project based episode, we're going to put together an H-bridge which will allow us to control the speed and direction of a DC brushed motor. An Arduino will provide the PWM pulses and direction control. We'll also use optocouplers as the interface between the H-bridge and Arduino, which will mitigate noise and potentially dangerous voltages from damaging our IO pins.
Watch the Video
Supplemental Content
  • Schematics
element14 presents
element14 presents  | About Derek  |  DC to Daylight
  • h bridge
  • how to control a dc motor
  • h-bridge
  • pwm
  • dc to daylight
  • optocouplers
  • optoisolator
  • pulse with modulation
  • motor speed controller
    e14 Contributor over 4 years ago
    Hello All,
    It was brought to my attention in the YT comments that I professed about the need to avoid turning on same-side H/L transistors which would short the + and - rails, but didn't account for PQWM software timing which would cause an overlapping state.
    The function in question:
    void motion(int dir, int pwm)
        if(dir == FWD)
            analogWrite(H1, pwm);
            analogWrite(H2, 0);
            analogWrite(L1, 0);
            analogWrite(L2, pwm);
        if(dir == REV)
            analogWrite(H1, 0);
            analogWrite(H2, pwm);
            analogWrite(L1, pwm);
            analogWrite(L2, 0);
    Now that my error has been revealed,... I have a simple solution in mind. How would you handle it? What would you change about this function?
    -Derek
  • bit_wrangler
    bit_wrangler over 4 years ago in reply to e14 Contributor
    const byte FWD = 0;
    const byte REV = 1;
    const byte H1 = 3; // PWM pin 3
    const byte H2 = 5; // PWM pin 5
    const byte L1 = 6; // PWM pin 6
    const byte L2 = 9; // PWM pin 9
    const unsigned long DWELLTIME = 2000; // time mS to hold at max speed
    const unsigned long PWMSTPTIME = 10; // mS delay between PWM changes
    const unsigned long STOPTIME = 25; // mS delay between direction changes
    const byte PWMMAXVAL = 255; // 8-bit PWM so 0 - 255
    byte direction = FWD;
    void stop() {
      analogWrite(H1, 0);
      analogWrite(H2, 0);
      analogWrite(L1, 0);
      analogWrite(L2, 0);
      delay(STOPTIME);
    void motion(const byte dir, const byte duty) {
      static byte current_dir = 2; // keep track of current h-bridge direction, initialized to invalid state
      // Check for direction change (or first execution)
      if(dir != current_dir){
        stop();
        current_dir = dir;
      switch(dir){
        case FWD:
          analogWrite(H1, duty);
          analogWrite(L2, duty);
         break;
        case REV:
          analogWrite(H2, duty);
          analogWrite(L1, duty);
          break;
    void ramp_pwm(const byte start, const byte end){
      if(start == end) return;
      const short step = end > start ? 1 : -1;
      // ramp profile
      for(short pwmvalue=start; pwmvalue != end; pwmvalue += step){
        motion(direction, pwmvalue);
        delay(PWMSTPTIME);
    void setup() {
      Serial.begin(9600);
    void loop() {
      // ramp up profile
      ramp_pwm(0, PWMMAXVAL);
      // dwell in plateau
      delay(DWELLTIME);
      // ramp down profile
      ramp_pwm(PWMMAXVAL, 0);
      // swap direction
      direction ^= 1;
    Something like this, maybe.
    I tried to keep it relatively simple, but my sensibilities scream about using int when it's not necessary (or non-stdint types for that matter, but I compromised).
  • bit_wrangler
    const byte FWD = 0;
    const byte REV = 1;
    void stop() {
      analogWrite(H1, 0);
      analogWrite(H2, 0);
      analogWrite(L1, 0);
      analogWrite(L2, 0);
      delay(STOPTIME);
        stop();
        current_dir = dir;
      switch(dir){
        case FWD:
         break;
        case REV:
          break;
      // ramp profile
        delay(PWMSTPTIME);
    void setup() {
      Serial.begin(9600);
    void loop() {
      // ramp up profile
      // dwell in plateau
      delay(DWELLTIME);
      // swap direction
      direction ^= 1;
    e14 Contributor over 4 years ago in reply to bit_wrangler
    Ha. I cringed a little when I used int's as well, but it's a fine line - keeping a simple presentation vs. the most efficient way to write code.
    Anyway, I like your solution!
