Project Videos
  • Project Videos
Project Videos
Documents Build Inside The Box Challenge! -- Episode 500
  • Author Author: kellyhensen
  • Date Created: 20 May 2021 2:11 PM Date Created
  • Last Updated Last Updated: 28 May 2021 7:24 AM
  • Views 10314 views
  • Likes 15 likes
  • Comments 39 comments
Welcome to the 500th episode of element14 presents!  We decided to try something new for this episode - pitting three of our content creators against each other with the limitations of creating a working project with all of the parts in THE BOX.  We also challenged the community members with the same restriction - you can see their projects here.
James, Clem and Katie are competing in this challenge - but they're playing for their favorite STEM organizations.  See more about the competition.
Here's a link to the prizes the STEM organizations can win.
BONUS content:
Since we covered three builds in this episode, we thought you might like some more behind the scenes footage of each of the projects:
Katie's Digital Theremin
Clem's Parcel Calculator
James' Getting Sound out of an Arduino
Member's Entrants:
We also challenged our members to Build Inside The Box , click through to see the Member Projects! Also watch related episode 504.
And here's the Brainstorming Call where they discussed the parts when they received them.
Here's what's in THE BOX:
The BOX Buy the Box*
Arduino MKR Zero
Buy Now
MULTICOMP PRO Portable USB High Capacity Power Bank
Buy Now
WAGO Pluggable Terminal Block
Buy Now
Microchip Op Amp
MICROCHIP MCP604-I/P Operational Amplifier
Buy Now
Vishay Phototransmitor
VISHAY Phototransistor
Buy Now
MIDAS OLED Graphic Display
Buy Now
MICROCHIP Temperature Sensor IC
Buy Now
ST Microelectronics Gesture Sensor
ST Range/Gesture Sensor 53L0-SATEL-I1
Buy Now
element14 presents
Build Inside the Box
About the Challenge | What's In The Box | element14 presents | Project Videos | Member Challenge Winners | Episode 504
  • vishay
  • clem
  • microchip
  • arduino mkr zero
  • baldengineer
  • e14presents_mayermakes
  • 500_episode
  • e14presents_katiedumont
  • e14presents_baldengineer
  • build_inside_the_box
  • katie
  • james
  • friday release
  • multicomp
  • build inside the box
  • midas
  • wago
  • friday_release
  • bitb
  • cstanton
    cstanton over 4 years ago +8
    These projects are so good it's difficult to choose! I'm impressed as to how well everyone came up with ideas for the bunch of kit in the box I threw together, mwa hahaha!
  • cummns
    cummns over 4 years ago +7
    I wanted to make sure I put all the things I liked about each of the builds. While voting is great, I wanted to make sure everyone knew that they were all awesome builds! Great job! Clem's Parcel Measurer…
  • mayermakes
    mayermakes over 4 years ago in reply to cummns +3
    Thanks Keith! I actually plan to make another iteration on that project with Barcode reader addition and more selective parts for the buld to practicalyl use it on my little webshop. Honestly I Am in great…
  • johntk256
    johntk256 over 4 years ago
    Three great projects, well done all :-) Question for Katie, you said you used a "power resistor" to stop the power bank from switching off, I'm having the same issue with a power bank and an Adafruit sound board, so what type of power resistor would I need and how is it wired into this type of circuit? :-)
  • johntk256
  • kmikemoo
    kmikemoo over 4 years ago in reply to johntk256
    johntk256  You'll need a periodic draw of around 100mA to keep the power bank awake.  50Ω, 1/2w gets you there.  As you can tell, Katie went with a bit more robust resistor.  Check out John Wiltrout's (jw0752 post.  You may find his device useful.
    On Using a USB Battery for a Portable Project Power Supply
  • hifromkatie
    hifromkatie over 4 years ago in reply to johntk256
    I used what I had on my bench which was, a 12ohm 25W power resistor (https://uk.farnell.com/cgs-te-connectivity/hsa2512rj/resistor-alu-housed-12r-5-25w/dp/2009315 this exact one)
    I put it directly between gnd and the 5v pad on the arduino.
    It's a fairly crude solution, but works.
  • johntk256
    johntk256 over 4 years ago in reply to hifromkatie
    That's great, thanks for the info Katie, I'll give that a try :-)
