Project Videos
  • Project Videos
Project Videos
Documents CNC Router Remote Control -- Episode 526
  • Date Created: 24 Nov 2021 10:19 PM Date Created
  • Last Updated Last Updated: 26 Nov 2021 8:24 AM
  • Views 40340 views
  • Likes 9 likes
  • Comments 8 comments
The computer that controls my CNC router is too far away from the router itself. I could have just moved a table and a computer closer to the machine, but that's no fun! But you know what is? Overbuilding a custom solution! Join me as I design, pivot, weld, route, 3d print, and solder my way to a new solution to this problem!
Supplemental Content:
  • Download code from Github: https://github.com/KalebTheMaker/CNC_ControlPanel
Bill of Material:
ITW SWITCHES Industrial Pushbutton Switch, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Square, Red ITW SWITCHES 6 Buy Now
ARDUINO NANO 33 IOT W/HEADER DEVELOPMENT BOARD ARDUINO 1 Buy Now
NKK SWITCHES Toggle Switch, On-Off, SPST, Non Illuminated, 20 A, Panel Mount NKK SWITCHES 1 Buy Now
GRAYHILL Rotary Switch, 4 Position, 1 Pole, 90 °, 150 mA, 220 V, 50 Series GRAYHILL 1 Buy Now
LED, RGB, Hyper Red, Green, Blue, Through Hole, T-1 3/4 (5mm), 60 °, Round, R 20mA, G 20mA, B 20mA KINGBRIGHT 1 Buy Now
Additional Parts:
Product Name
Rii K18 Wireless 3-LED backlit multimedia keyboard
Handwheel CNC, 5v 60mm diameter 4 terminal manual pulse generator
Raspberry Pi Screen 10.1 Inch Touchscreen Monitor 1024x600 Portable HDMI Monitor
3mm Acrylic
3/4" Oak
Kaleb Clark - Kaleb_021-CAD-Files.zip
element14 presents
element14 presents  |  About Kaleb Clark |  Project Videos
  • cnc router control console
  • cnc router
  • cnc router console
  • cnc remote control
  • cnc router remote control
  • friday_release
  • celcius1
    celcius1 over 4 years ago +1
    Is it possible to adapt this for GRBL, as I dont use a MACH4 controlled CNC Router x ( x )
  • mayermakes
    mayermakes over 4 years ago in reply to celcius1 +1
    Sure just xchange the serial commands sent to Mach to Gcode
  • KalebTheMaker
    KalebTheMaker over 4 years ago in reply to celcius1 +1
    The Arduino is just emulating a keyboard sending the appropriate commands for Mach4. I am not sure if GRBL has keyboard input for jog control, but it could be modified to send gcode as mayermakes mentions…
  • angelmoi_123
    angelmoi_123 over 3 years ago
    Hi , great project, it is posible to use arduino pro micro for this project??
    Thanks
  • phoenixcomm
    phoenixcomm over 4 years ago
    I have read some really nasty things about Mach4, ie not stable, axis stop, etc. etc. why don't you use LinuxCNC. It runs under Debian, etc. or just get a Live CD..
    No more problems.
  • phoenixcomm
    kalebclark, I don't know It is in the ISO 7 layer model, so in fact, most folks just think of CAN as a 2 wire system. but that is only LAYERS 1, and 2. you want to put it on USB ok or even ethernet.
    Please check out my articles in 'Aventures in CANaerospace' see my NexGen Blog Index 1.
    enjoy.
    ~~Cris
  • KalebTheMaker
    KalebTheMaker over 4 years ago in reply to phoenixcomm
    Thank you!
    Would that be via a plugin on Mach4?
  • phoenixcomm
    very nicely done.
    BTW this could have been done using an interrupt-driven CANbus.
    Most examples are master/slave but CAN is not ether could be the master or slave.
    ~~Cris
  • KalebTheMaker
    The Arduino is just emulating a keyboard sending the appropriate commands for Mach4. I am not sure if GRBL has keyboard input for jog control, but it could be modified to send gcode as mayermakes mentions instead of keyboard emulation.
  • mayermakes
  • celcius1
    x (x)
