Project Videos
  • Project Videos
Project Videos
Documents CNC Router Remote Control -- Episode 526
  • Date Created: 24 Nov 2021 10:19 PM Date Created
  • Last Updated Last Updated: 26 Nov 2021 8:24 AM
  • Views 40288 views
  • Likes 9 likes
  • Comments 8 comments
The computer that controls my CNC router is too far away from the router itself. I could have just moved a table and a computer closer to the machine, but that's no fun! But you know what is? Overbuilding a custom solution! Join me as I design, pivot, weld, route, 3d print, and solder my way to a new solution to this problem!
Supplemental Content:
  • Download code from Github: https://github.com/KalebTheMaker/CNC_ControlPanel
Bill of Material:
ITW SWITCHES Industrial Pushbutton Switch, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Square, Red ITW SWITCHES 6 Buy Now
ARDUINO NANO 33 IOT W/HEADER DEVELOPMENT BOARD ARDUINO 1 Buy Now
NKK SWITCHES Toggle Switch, On-Off, SPST, Non Illuminated, 20 A, Panel Mount NKK SWITCHES 1 Buy Now
GRAYHILL Rotary Switch, 4 Position, 1 Pole, 90 °, 150 mA, 220 V, 50 Series GRAYHILL 1 Buy Now
LED, RGB, Hyper Red, Green, Blue, Through Hole, T-1 3/4 (5mm), 60 °, Round, R 20mA, G 20mA, B 20mA KINGBRIGHT 1 Buy Now
Additional Parts:
Product Name
Rii K18 Wireless 3-LED backlit multimedia keyboard
Handwheel CNC, 5v 60mm diameter 4 terminal manual pulse generator
Raspberry Pi Screen 10.1 Inch Touchscreen Monitor 1024x600 Portable HDMI Monitor
3mm Acrylic
3/4" Oak
Kaleb Clark - Kaleb_021-CAD-Files.zip
element14 presents
element14 presents  |  About Kaleb Clark |  Project Videos
  • cnc router control console
  • cnc router
  • cnc router console
  • cnc remote control
  • cnc router remote control
  • friday_release
  • celcius1
    celcius1 over 4 years ago +1
    Is it possible to adapt this for GRBL, as I dont use a MACH4 controlled CNC Router x ( x )
  • mayermakes
    mayermakes over 4 years ago in reply to celcius1 +1
    Sure just xchange the serial commands sent to Mach to Gcode
  • KalebTheMaker
    KalebTheMaker over 4 years ago in reply to celcius1 +1
    The Arduino is just emulating a keyboard sending the appropriate commands for Mach4. I am not sure if GRBL has keyboard input for jog control, but it could be modified to send gcode as mayermakes mentions…
  • phoenixcomm
    phoenixcomm over 4 years ago
    I have read some really nasty things about Mach4, ie not stable, axis stop, etc. etc. why don't you use LinuxCNC. It runs under Debian, etc. or just get a Live CD..
    No more problems.
  • phoenixcomm
    No more problems.
