Project Videos
  • Project Videos
Project Videos
Documents Let's Build an Electronic Fidget Cube! -- Episode 528
  • Date Created: 7 Dec 2021 6:56 PM Date Created
  • Last Updated Last Updated: 10 Dec 2021 8:24 AM
  • Views 9670 views
  • Likes 12 likes
  • Comments 18 comments
Fidget toys are fun but lack electronics. Let see if we can make an electronics-based fidget cube. What would you like to see on one of the sides?
Join the discussion where Katie discusses her original concepts.
Supplemental Content:
  • Episode 528: Bonus Content: Fidget Cube
  • Link to the Github:  https://github.com/hifromkatie/Fidget-Cube
Bill of Material:
AVR64DA32-I/PT MICROCHIP AVR Microcontroller, AVR DA Family AVR64DA Series Microcontrollers, AVR, 8bit, 24 MHz, 64 KB MICROCHIP 2 Buy Now
PG164100 MICROCHIP Debugger/Programmer, MPLAB Snap, In-Circuit, For PIC, dsPIC, AVR Flash MCUs MICROCHIP 1 Buy Now
53398-0271 MOLEX Pin Header, Wire-to-Board, 1.25 mm, 1 Rows, 2 Contacts, Surface Mount Straight MOLEX 7 Buy Now
53398-0371 MOLEX Pin Header, Vertical, Signal, 1.25 mm, 1 Rows, 3 Contacts, Surface Mount Straight MOLEX 1 Buy Now
15134-0200 MOLEX Cable Assembly, PicoBlade Receptacle to PicoBlade Receptacle, 2 Ways, 1.25 mm, 1 Row, 50 mm, 2 " MOLEX 2 Buy Now
MAX16054AZT+T MAXIM INTEGRATED PRODUCTS Push Button On/Off Controller with Debouncer, Latched Output, 2.7V to 5.5V, TSOT-23-6 MAXIM 2 Buy Now
MCOT128064P1V-WM MIDAS Graphic OLED, 128 x 64 Pixels, White on Black, 3V, I2C, Parallel, SPI, 34.5mm x 23mm, -40 °C MIDAS 1 Buy Now
MCMT5-F-V MULTICOMP PRO Navigation Switch, 1.57 N, 12 V, 50 mA, Solder, 4 MULTICOMP PRO 1 Buy Now
SKSTAAE010 ALPS ALPINE Tactile Switch, SKST Series, Top Actuated, Surface Mount, Round Button, 400 gf, 50mA at 16VDC ALPS ALPINE 1 Buy Now
MSLPT5252BG4MTR ALCOSWITCH - TE CONNECTIVITY Tactile Switch, MSLPT Series, Top Actuated, Surface Mount, Round Button, 260 gf, 50mA at 12VDC ALCOSWITCH - TE CONNECTIVITY 6 Buy Now
JSX08001SAQNL C&K COMPONENTS Slide Switch, SPDT, Momentary Spring Return, Surface Mount, 10 mA C&K COMPONENTS 1 Buy Now
434121025816 WURTH ELEKTRONIK Tactile Switch, WS-TASV Series, Top Actuated, Surface Mount, Round Button, 160 gf, 50mA at 12VDC WURTH ELEKTRONIK 2 Buy Now
PMN48XPA2X NEXPERIA Power MOSFET, P Channel, 20 V, 4.4 A, 0.037 ohm, TSOP, Surface Mount NEXPERIA 2 Buy Now
MAX1675EUA+T MAXIM INTEGRATED PRODUCTS DC-DC Switching Sync-Boost (Step Up)Regulator, Adj, 700mV-5.5Vin, 3.3V-5V/300mA out, 500 kHz, µMAX-8 MAXIM INTEGRATED PRODUCTS 1 Buy Now
MC33275ST-3.0T3G ONSEMI LDO Voltage Regulator, AEC-Q100, Fixed, up to 13 V in, 260 mV drop, 3 V/300 mA out, SOT-223-4 ONSEMI 1 Buy Now
LQH43NH220J03L MURATA Wirewound Inductor, 22 µH, 0.564 ohm, 15 MHz, 300 mA, 1812 [4532 Metric], LQH43NH_03 Series MURATA 1 Buy Now
599-0230-007F DIALIGHT LED, Orange, SMD, 1206 [3216 Metric], 20 mA, 2.1 V, 605 nm DIALIGHT 2 Buy Now
599-0210-007F DIALIGHT LED, Red, SMD, 1206 [3216 Metric], 20 mA, 2.1 V, 633 nm DIALIGHT 2 Buy Now
599-0291-007F DIALIGHT LED, Blue, SMD, 1206 [3216 Metric], 20 mA, 3.2 V, 470 nm DIALIGHT 2 Buy Now
599-0281-007F DIALIGHT LED, Green, SMD, 1206 [3216 Metric], 20 mA, 3.2 V, 525 nm DIALIGHT 2 Buy Now
MC011368 MULTICOMP PRO LED, Orange Red, SMD, 0805 [2012 Metric], 20 mA, 2.1 V, 620 nm MULTICOMP PRO 7 Buy Now
MP000443 MULTICOMP PRO LED, Green, SMD, 0805 [2012 Metric], 20 mA, 3.1 V, 525 nm MULTICOMP PRO 7 Buy Now
KPHCM-2012SYCK KINGBRIGHT LED, Low Power, Yellow, SMD, 0805 [2012 Metric], 20 mA, 2 V, 590 nm KINGBRIGHT 2 Buy Now
MULTICOMP PRO 3D Printer Filament, 2.85mm Dia, Black, PLA, 1 kg MULTICOMP PRO 1 Buy Now
Additional Parts:
PCBs (3)
Rechargable Lithium Polymer Battery with Molex PicoBlade 3 pin connector, 300mAh
element14 presents
element14 presents  |  About Katie Dumont |  Project Videos
  • Fidget
  • molex
  • buttons
  • e14p_KD
  • microchip
  • fidget cube
  • Small Circuits
  • e14presents_katiedumont
  • leds
  • katie
  • maxim
  • friday_release
  • Electronics Cube
    dougw over 4 years ago +1
    Awesome project. I like that little etch-a-sketch.
  • kambot62
    kambot62 over 4 years ago
    how do you make the pcb's?
  • kambot62
    Jan Cumps over 4 years ago in reply to kambot62
    There is a link to github at the top. It contains the gerber/drill files for the 3 boards.
  • kambot62
    kambot62 over 4 years ago in reply to Jan Cumps
    Thank You!
  • kambot62
    I have no clue about this. Are these files for a 3D printer?
  • hifromkatie
    hifromkatie over 4 years ago in reply to kambot62
    There are files for sending to your PCB manufacture of choice, and files for 3D printing the case/framework contained in the project.
    However part 2 (episode 548) has improved 3D printed case files than this version.
    Files for 3Dprinting are the STL extention files
    The files in the zip files under New-files_for_manufacture are the files for PCBs
    beacon_dave over 4 years ago in reply to kambot62
    Looks like there are quite a mix of files file types there Slight smile
    KiCad schematic files
    KiCad PCB design files
    FreeCAD 3D modelling files
    Gerber files for PCB manufacture
    STL files for 3D printing
    MPLabX files for programming.
    If you want to make your own PCBs rather than sending them off for manufacture then perhaps download a copy of KiCad and open up the PCB design files and print off in the format required.
  • kambot62
    kambot62 over 4 years ago in reply to hifromkatie
    Thx!!!
  • kambot62
    kambot62 over 4 years ago in reply to beacon_dave
    Thanks!
