Project Videos
  • Project Videos
Project Videos
Documents Reviving the 1984 IBM 5155 - How Hard Can It Be? -- Episode 544
  • Date Created: 24 Mar 2022 2:59 PM Date Created
  • Last Updated Last Updated: 1 Apr 2022 7:24 AM
  • Views 27289 views
  • Comments 5 comments
In The Electronics Inside, we tore down an IBM 5155 from 1984, but the power supply was suspicious. How hard can it be to get it going again? Was the power supply the only issue or was it a symptom of another issue in the hardware itself?
element14 presents
element14 presents  |  About David|  Project Videos
  • Vintage PC
  • recap
  • Luggable PC
  • switch mode power supply
  • david
  • e14p_DE
  • friday_release
  • rickseiden
    rickseiden over 4 years ago
    I kind of cringed a little when you took the power supply out for recapping and closed the machine back up.  I was thinking that you would want to recap everything at once, just to save time in the ordering and installing process.  Turns out that the motherboard and video card need to be recapped, too.
  • rickseiden
  • a531016
    a531016 over 4 years ago in reply to rickseiden
    Well, if they didn't before - they 100% do now!
    My hope was, with the behaviour I saw on the original tear down and attempted power up, was that the power supply was failing. I figured that the power supply couldn't provied the needed power as it was. If the motherboard was pulling too much from a failed cap, I thought it would have shorted and blown the fuse in the PSU?
