Project Videos
  • Project Videos
Project Videos
Documents Can We Rebuild a 1930s Accounting Machine? -- Episode 551
  • Date Created: 11 May 2022 9:07 PM Date Created
  • Last Updated Last Updated: 20 May 2022 7:24 AM
  • Views 19221 views
  • Comments 6 comments
Hopefully you've seen the past Electronics Inside episode where Clem and I tore down a 1930s accounting machine. So of course I had to have a go at fixing it again! I hope this doesn't end the same way as my last attempt. I take a look at its very unusual switch type device that controls the motor, test it thoroughly before putting power to it, and much more
element14 presents
element14 presents  |  About David|  Project Videos
  • testing
  • 1930s Accounting Machine
  • Mechanical Calculations
  • david
  • e14p_DE
  • friday_release
    beacon_dave over 4 years ago
    Does the motor only run when the mechanism closes the contacts or does it run continuously from power on ?
    I've seen office equipment from this sort of era that uses an electromechanical clutch mechanism to engage/disengage the drive mechanism from a continuously running motor.
  • a531016
    a531016 over 4 years ago in reply to beacon_dave
    This one only runs when the mechanism closes. It would be frightfully noisy to have that running full time. Although, some dot matrix printers would probably have it beat still!
  • mayermakes
    mayermakes over 4 years ago in reply to a531016
    yeah contrary to my teletype..that one spins constantly and engages the clutch when it needs to type.
  • mayermakes
