Project Videos
  • Project Videos
Project Videos
Documents Adding a Parallel Printer Port to an Android Phone -- Episode 553
  • Date Created: 31 May 2022 3:35 PM Date Created
  • Last Updated Last Updated: 3 Jun 2022 7:24 AM
  • Views 152120 views
  • Likes 8 likes
  • Comments 8 comments
When did they remove Printer ports from smartphones? Or did they? In any Case Clem has a dot matrix printer from the flea market and wants to print from his phone! So he builds a piece of custom hardware to add a Printer port to his phone via the USB-C port. We see an Arduino Uno powered prototype, transfer the concept to custom hardware, cover some bumps in the process and write some code to make it work!
Supplemental Content:
  • Episode 553 Resources
Bill of Material:
"PRO SIGNAL USB Cable Pro signal 1 Buy Now
"MULTICOMP PRO USB Cable Multicomp pro 1 Buy Now
D Sub Connector, Right Angle, DB25, Standard, Receptacle, 5504, 25 Contacts, DB, Solder Multicomp pro 2 Buy Now
Additional Parts:
MAYER MAKES Printershield https://lectronz.com/stores/mayermakes
NEC Pinwriter 20 printer, but any centronics compatible printer will work
Smartphone with USB-C port
element14 presents
element14 presents  |  About Clem  |  Project Videos
  • clem
  • android phone
  • Dot Matrix Printer
  • Parallel Port
  • multicomp
  • friday_release
  • e14p_CMM
  • kmikemoo
    kmikemoo over 4 years ago +1
    mayermakes Very cool. I've recycled all of my parallel printers but I've still got my parallel ZIP drive. I wonder... Serialgang.
  • mayermakes
    mayermakes over 1 year ago in reply to sdstiefel
    you can use a shift register that allows for paralell and serial insertion/read of data:
    export.farnell.com/.../shift-registers
  • sdstiefel
    sdstiefel over 1 year ago in reply to mayermakes
    Can I get one ?
    dougw over 3 years ago
    I made some PCBs to adapt parallel printer ports to drive LCDs. To use those adapters today, I would need a USB-to-printer port adapter....or perhaps a Bluetooth-to-printer port adapter....Relaxed
  • mayermakes
    mayermakes over 4 years ago in reply to DAB
    thanks, I have a lot of these adapters in stock actually....maybe there is a theme for another video.
  • mayermakes
    mayermakes over 4 years ago in reply to kmikemoo
    I had a PP zip drive, it was my favourite thing in the world! until ..the dreaded click of death.
    Iḿ sure if someone would be able to reverse engineer the protocoll it could be possible to networkify it.
  • mayermakes
    Hi sorry for the late replies, we got a ton of suggestions over the last few days, and Iḿ happy to report that a new video is inthe works that implemennts afew of the suggestions that came from the viewers!
    DAB over 4 years ago
    Good job Clem.
    Back in the 1980's we used parallel to serial and serial to parallel chips to move printer data over long distances.
  • kmikemoo
    Serialgang.
