Project Videos
  • Project Videos
Project Videos
Documents Adding a Parallel Printer Port to an Android Phone -- Episode 553
  • Date Created: 31 May 2022 3:35 PM Date Created
  • Last Updated Last Updated: 3 Jun 2022 7:24 AM
  • Views 151994 views
  • Likes 8 likes
  • Comments 8 comments
When did they remove Printer ports from smartphones? Or did they? In any Case Clem has a dot matrix printer from the flea market and wants to print from his phone! So he builds a piece of custom hardware to add a Printer port to his phone via the USB-C port. We see an Arduino Uno powered prototype, transfer the concept to custom hardware, cover some bumps in the process and write some code to make it work!
Supplemental Content:
  • Episode 553 Resources
Bill of Material:
"PRO SIGNAL USB Cable Pro signal 1 Buy Now
"MULTICOMP PRO USB Cable Multicomp pro 1 Buy Now
D Sub Connector, Right Angle, DB25, Standard, Receptacle, 5504, 25 Contacts, DB, Solder Multicomp pro 2 Buy Now
Additional Parts:
MAYER MAKES Printershield https://lectronz.com/stores/mayermakes
NEC Pinwriter 20 printer, but any centronics compatible printer will work
Smartphone with USB-C port
element14 presents
element14 presents  |  About Clem  |  Project Videos
  • clem
  • android phone
  • Dot Matrix Printer
  • Parallel Port
  • multicomp
  • friday_release
  • e14p_CMM
  • kmikemoo
    kmikemoo over 4 years ago +1
    mayermakes Very cool. I've recycled all of my parallel printers but I've still got my parallel ZIP drive. I wonder... Serialgang.
    DAB over 4 years ago
    Good job Clem.
    Back in the 1980's we used parallel to serial and serial to parallel chips to move printer data over long distances.
  • mayermakes
    mayermakes over 4 years ago in reply to DAB
    thanks, I have a lot of these adapters in stock actually....maybe there is a theme for another video.
  • sdstiefel
    sdstiefel over 1 year ago in reply to mayermakes
    Can I get one ?
  • sdstiefel
    Can I get one ?
  • mayermakes
    mayermakes over 1 year ago in reply to sdstiefel
    you can use a shift register that allows for paralell and serial insertion/read of data:
    export.farnell.com/.../shift-registers
