Project Videos
  • Project Videos
Project Videos
Documents Create a Magic Makeup Mirror with Pose Detection -- Episode 559
  • Date Created: 12 Jul 2022 4:40 PM Date Created
  • Last Updated Last Updated: 15 Jul 2022 7:24 AM
  • Views 110991 views
  • Comments 15 comments
Lorraine has always found putting on eyeliner difficult. Being a Maker she decided to build a technical solution to her problem. Using machine learning on a raspberry pi and a very cool round screen Lorraine created a tool that would draw the eyeliner on her face during a live video. That way Lorraine could just trace the lines! Watch the highs and lows of creating a Magic Makeup Mirror!
Supplemental Content:
  • Tutorial mentioned @4:40:  https://circuitdigest.com/microcontroller-projects/facial-landmark-detection-using-raspberry-pi-opencv
  • The Model from github mentioned 05:42:  https://github.com/italojs/facial-landmarks-recognition/blob/master/shape_predictor_68_face_landmarks.dat
Bill of Materials
Raspberry Pi 4 Raspberry Pi 1 Buy Now
Raspberry Pi USB-C Power Supply Raspberry Pi 1 Buy Now
SD Card TRANSCEND 1 Buy Now
RPI NOIR CAMERA BOARD Raspberry Pi 1 Buy Now
Long camera cable - 1 metre MCM 1 Buy Now
Additional Parts:
HyperPixel 2.1 Round Hi-Res IPS Touchscreen Display HAT for Raspberry Pi
element14 presents
element14 presents  |  About Lorraine |  Project Videos
  • How to draw perfect wings
  • e14p_LU
  • artificial intelligence
  • Artificially intelligent mirror
  • Cosplay MakeUp
  • Makeup Mirror
  • raspberry pi
  • lauren
  • machine learning
  • magic mirror
  • Eyeliner Tutorial
  • Create your own snapchat filters
  • friday_release
    beacon_dave over 4 years ago
    You could perhaps add a LED ring around the HyperPixel display to help throw some light onto your face to help the camera. (Bonus points if you can style it as a theatre style green room mirror with round LEDs that pop out when you open the compact Slight smile ) Just don't overdo the candelas otherwise you will be blinded in the process.
    You could also try a ring of white pixels on the display itself but probably not enough light to make much of a difference.
    Arducam have some R-Pi compatible ultra low light cameras (IMX462 Starvis sensor) which might be worth a look at, although may be a bit large for a final compact mirror.
    https://www.arducam.com/product/arducam-for-raspberry-pi-ultra-low-light-camera-1080p-hd-wide-angle-pivariety-camera-module-based-on-1-2-7inch-2mp-starvis-sensor-imx462-compatible-with-raspberry-pi-isp-and-gstreamer-plugin/
    So a smaller less sensitive camera sensor with the LED light ring illuminator might still work out better (and cheaper).
    I've got one of their IMX291 2MP cameras in a USB webcam format which has quite good low light performance. Sometimes 'less is more'.
    It is UVC compliant but the downside is that without a OEM driver, not all the camera properties are accessible from standard USB camera applications. You either have to use the likes of AMCap or equivalent to access the camera pins or alternatively set their properties using OpenCV, which is something I need to look further into but looks doable according to this:
    https://docs.opencv.org/3.4/d4/d15/group__videoio__flags__base.html#gaeb8dd9c89c10a5c63c139bf7c4f5704d
  • lorrainbow
    lorrainbow over 4 years ago in reply to beacon_dave
    I like the arducam cameras. I had one that had such a bigger field of view than a raspberry pi camera.
  • lorrainbow
    beacon_dave over 4 years ago in reply to lorrainbow
    They have recently added a 64MP R-Pi compatible camera with autofocus lens  to their range.
