Project Videos
  • Project Videos
Project Videos
Documents Synced NeoPixel Mickey Mouse Ears -- Episode 567
  • Date Created: 23 Aug 2022 8:35 PM Date Created
  • Last Updated Last Updated: 9 Sep 2022 7:24 AM
  • Views 193452 views
  • Likes 8 likes
  • Comments 19 comments
These light-up Mickey Ears show neopixel animations and sync with other ear hats for the ultimate Disney group attire! The sync is made possible with the Micro:bit’s internal radio to broadcast different animation modes. We designed animations to match the attractions across the park so we could really get into the theme of each ride. The templates and code for this project are available on the element14 community so you can make your own. See you at Disneyland!
Supplemental Content:
  • Episode 567 Resources
  • Win a Massive Raspberry Pi to Hang on Your Wall!
Bill of Material:
Single Board Computer, micro:bit V2 Board BBC MICRO:BIT 1 Buy Now
2 X AAA BATTERY HOLDER WITH ON/OFF SWITCH & JST PH CONNECTOR ADAFRUIT 1 Buy Now
Battery, 1.5 V, AAA, Alkaline, 1.1 Ah, Raised Positive and Flat Negative, 10.5 mm MULTICOMP PRO 2 Buy Now
Wire / Ribbon Cable 3M 1 Buy Now
Additional Parts:
Screws and Bolts
1/4 inch craft foam
Glitter Paper
A Black Baseball Hat
Hot Glue / Glue Gun
Straight Pins
element14 presents
element14 presents  |  About Natasha |  Project Videos
  • micro:bit
  • diy
  • disneyland
  • led
  • neopixel
  • Mickey Mouse
  • disney
  • e14p_NTC
  • friday_release
    DAB over 4 years ago
    Nice build, you can also use the ears during Halloween.
    beacon_dave over 4 years ago in reply to DAB
    Could perhaps use the Neopixels for some sort of a wearable light-up skeleton effect. Add in a beating heart and accessorise with a light-up pumpkin. Lots of options for different lighting effects. Might need a larger battery pack though.
  • TechnoChic
    TechnoChic over 4 years ago in reply to DAB
    Great idea! I'd love to see them made into a devil horn hat too!
    beacon_dave over 4 years ago in reply to TechnoChic
    Perhaps a couple of servos to make the horns point toward people like in the cartoons ?
  • TechnoChic
    TechnoChic over 4 years ago in reply to beacon_dave
    Funny you should say that. I saw a girl with positionable ears at Disney and it captivated me because the movement was so natural. I realized that she had a little hydraulic squeeze bubble in her scarf to control them, the effect was awesome because the ears really perked up and followed the sound! It would be fun to do something like that electronically too!
    I'd imagine that hydraulics or pneumatics would be a good choice for wearables as it would be more forgiving with bumps and knocks than with linkages.
    I'm amazed with the pumps in blood pressure monitors as you get around 1,000 cuff inflations with a set of 6 AA batteries. Should be enough to inflate some horns a few times I would have thought. You also can get some small pneumatic solenoid valves that could be controlled from a micro:bit taking compressed air from a small can saving on batteries for the LEDs.
