Project Videos
  • Project Videos
Project Videos
Documents Using a Pi Pico to Convert Keyboard Input to Morse Code -- Episode 573
  • Author Author: cstanton
  • Date Created: 14 Oct 2022 12:51 PM Date Created
  • Last Updated Last Updated: 21 Oct 2022 7:24 AM
  • Views 151812 views
  • Likes 13 likes
  • Comments 51 comments
Ever fancied sending a message via Morse code, but the process of working out the dots and dashes seems daunting? Then why not make a keyboard that will convert the text you type into Morse code, in an audible and visual form!
Watch the Video
Supplemental Content:
  • Wiring and Code
Bill of Material:
RASPBERRY PI PICO W RASPBERRY-PI 1 Buy Now
RPI-KEYB (UK)-BLACK/GREY RASPBERRY-PI 1 Buy Now
PROJECTS UNLIMITED Transducer, 3 V to 28 V, Continuous, 90 dB, Sounder, 5 mA, Panel Mount PROJECTS UNLIMITED 1 Buy Now
element14 presents
element14 presents  |  About Katie Dumont |  Project Videos
  • how to use the pico as a keyboard
  • rpi pico
  • morse code
  • raspberry pi pico
  • raspberry pi
  • text to beeps
  • text to code
  • friday_release
  • scottiebabe
    scottiebabe over 3 years ago +1
  • scottiebabe
    scottiebabe over 3 years ago in reply to dougw +1
    If you were able to decode that with out computer aid, you deserve a prize! I cheated and used: https://morsecode.world/international/translator.html lol
  • hifromkatie
    hifromkatie over 3 years ago in reply to scottiebabe +1
    Thank you! Made me realise, I didn't add punctuation in my code, I'll add that when I get a chance.
    dougw over 3 years ago in reply to kmikemoo
    That  is definitely a delicate soldering job - good work Katie.
    beacon_dave over 3 years ago
    Perhaps needs a Baudot–Murray code option so as you can send messages to Clem's 1960's Teletype ?
    /challenges-projects/element14-presents/project-videos/w/documents/27567/episode-546-mapping-the-outputs-of-a-1960s-teletype-machine---how-hard-can-it-be
  • scottiebabe
    Yes your method is much more human readable, but harder to copy into a web translator lol Slight smile
  • scottiebabe
    scottiebabe over 3 years ago in reply to hifromkatie
    (AMAZING!!)²
    I liked how you used the keyboard as the project enclosure, I will have to consider this idea in the future!
    beacon_dave over 3 years ago in reply to dougw
    "...Initially I thought it was a line of text where only 2 rows of pixels were displayed..."
    Time to replace the ribbon on your DECwriter terminal?   Slight smile
    dougw over 3 years ago in reply to scottiebabe
    I mean it took me a minute just to figure out that it was Morse code. Initially I thought it was a line of text where only 2 rows of pixels were displayed. I had to select/highlight it to realize what it was. Relaxed
    Here's an attempt with emoticons: Black circle Heavy minus sign     Black circle Heavy minus sign Heavy minus sign      Black circle      Black circle Black circle Black circle       Heavy minus sign Heavy minus sign Heavy minus sign        Heavy minus sign Heavy minus sign
    beacon_dave over 3 years ago in reply to hifromkatie
    There is Morse code embedded into the music composition.
    https://www.youtube.com/watch?v=BEfv6QtYFAM
    Even more room after you remove the keystroke logging device first Open mouth
  • hifromkatie
    hifromkatie over 3 years ago in reply to kmikemoo
    You could connect it like I did whilst testing, plugging the pico into a normal USB keyboard (without a hub) using a micro USB otg cable.
    You would also need to power the pico with 5v to the header pins as well though
    That was almost too easy. Can you solve 'STENDEC' ?  Thinking
