Project Videos
  • Project Videos
Project Videos
Documents The Game Guy Mini, Upgrading the Unportable Game Boy! -- Episode 577
  • Date Created: 3 Nov 2022 3:34 PM Date Created
  • Last Updated Last Updated: 18 Nov 2022 8:24 AM
  • Views 22923 views
  • Likes 11 likes
  • Comments 30 comments
element14 Community member Joe Ostrander saw the "Unportable Game Boy" that Andy made in a previous video, and decided to make a new and improved version. In this episode, Andy builds a console from Joe's upgraded design and demonstrates its features, including several enhancements that were requested by viewers.
Watch the Video:
Supplemental Content:
  • Episode 531: Game Guy - The Unportable Game Boy
  • Link to code: https://github.com/joeostrander/consolized-game-boy
Bill of Material:
SMD Level Shifter SN74LVC245ANSR TEXAS INSTRUMENTS 1 Buy Now
Crystal, 4.194304 MHz, SMD, 11.5mm x 4.7mm, 30 ppm, 18 pF, 30 ppm, ABLS Series ABRACON 1 Buy Now
CAP, 27PF, 50V, MLCC, 0201 MURATA 2 Buy Now
Surface Mount Tantalum Capacitor, 1 µF, 50 V, 1411 [3528 Metric], ± 10%, 6 ohm, B KEMET 2 Buy Now
Raspberry Pi Pico, Microcontroller Board, RP2040, 32 bit, 2MB Flash, ARM Cortex-M0+ RASPBERRY-PI 1 Buy Now
RES, 10K, 0.5%, 0.1W, 0603, THIN FILM ROHS COMPLIANT: YES YAGEO 2 Buy Now
RES, 1K, 0.1%, 0.1W, 0603, THIN FILM ROHS COMPLIANT: YES YAGEO 3 Buy Now
RES, 500R, 0.1%, 0.1W, THIN FILM, 0603 ROHS COMPLIANT: YES YAGEO 3 Buy Now
Surface Mount Chip Resistor, Thick Film, RC Series, 47 ohm, 100 mW, 1%, 50 V, 0603 [1608 Metric] RoHS Compliant: Yes YAGEO 2 Buy Now
Surface Mount Thick Film Resistor, RC Series, 180 kohm, 100 mW, - 1%, 50 V, 0603 [1608 Metric] RoHS Compliant: Yes YAGEO 1 Buy Now
SMD Chip Resistor, 510 ohm, ± 5%, 100 mW, 0603 [1608 Metric], Thick Film, General Purpose VISHAY 2 Buy Now
SMD Chip Resistor, 1 Mohm, ± 1%, 100 mW, 0603 [1608 Metric], Thick Film, Precision PANASONIC 1 Buy Now
Additional Parts:
1 x Super Gameboy Famicom cartridge
1 x NESPi case
1 x Gana VGA TO HDMI
7-pin NES socket1 x
1 x 32-pin SMD GB cartridge slot
1 each x Custom Main Board, Power Dist, and NES Socket PCBs (Designs Available on Github)
1 x  4-Pin SMD 3x4x2.5mm Tactile Push Button (optional)
element14 presents
element14 presents  |  About Andy West |  Project Videos
  • nes
  • nintendo entertainment system
  • raspberry pi pico
  • game boy
  • Game Guy
  • raspberry pi
  • Consolize
  • consolify
  • gameboy
  • mini
  • friday_release
  • pi pico
  • supertazon
    supertazon over 3 years ago +2
    Finally finished building mine with the link port included! Really awesome work by Joe and Markeno! Thanks to Joe for all the troubleshooting! I recorded a video of me playing Kirby: www.youtube…
  • kgal104
    kgal104 over 3 years ago +1
    Would a version compatible with the Gameboy pocket CPU be possible? Looking through the schematic available here: github.com/.../MGB-xCPU.pdf the only major differences seem to be internal vram and some…
  • markeno
    markeno over 3 years ago +1
    This has been a fun project to put together. I added parts to the pcb design to include the Game Link connection. I am waiting on a second Tetris cartridge to come in so I can see if it works. I wanted…
  • markeno
    These are great projects.  I really would like to put one based on it together.  It seems there is a V3 pcb design for "SGB_CART" but no Gerber files for it?  I take it by looking at the pictures, the SGB is a "Stock" or "Salvaged" GameBoy Game slot?  I was also wondering if a complete schematic is available for the V3 board.  As much as I like that case, I think I would like to work it up in something a little bit different.
  • Joe_O
    Joe_O over 3 years ago in reply to markeno
    Oh, I had only pushed the Gerber for the version in the video.  The newer SGB cart version should be there now.  I put a newer schematic up too  Thanks for noting that!
    The cartridge slot in the latest version is indeed from the SGB cartridge.  So now you can reuse 4 things from the cart (CPU, RAM x2, Cart slot).
    dougw over 3 years ago in reply to Joe_O
    awesome!
  • markeno
    markeno over 3 years ago in reply to Joe_O
    Thanks for posting those Joe.   You haven't come across a source for the DMG Link Port have you?  I want to add the link port as well.  I have found the Game Boy Color port but it is different.  It's a completeness feature more than anything, and I still have my original DMG.  It seems like it would be cool to try it out.
  • markeno
  • Joe_O
    Search for DMG-07, they're fairly cheap and you can desolder 3 ports.  Since it also has a cable, you could even use that -- just connect 1 end of the cable to your PCB and the other can plug right into a gameboy.
  • markeno
    Thanks for that. That will work great.
