Project Videos
  • Project Videos
Project Videos
Documents Repairing a Neewer 660 Studio light - How Hard Can It Be? -- Episode 594
  • Date Created: 9 Mar 2023 2:01 AM Date Created
  • Last Updated Last Updated: 17 Mar 2023 8:24 AM
  • Views 25029 views
  • Likes 10 likes
  • Comments 46 comments
I’ve got a studio light which has suddenly become faulty, how hard could it be to fix it rather than replace? In today’s episode I try and fault find the PCB to see if its a fault I can fix.
Watch the Video:
Bill of Material:
8 bit MCU, STM8S003F3P6TR STMICROELECTRONICS 1 Buy Now
Fixed LDO Voltage Regulator HOLTEK 1 Buy Now
Pluggable Terminal Block WAGO 3 Buy Now
Additional Parts:
Fault studio light
element14 presents
element14 presents  |  About Katie Dumont |  Project Videos
  • fault finding
  • e14p_KD
  • neewar
  • Pluggable Voltage Regulator
  • 8 bit mcu
  • Fixed LDO Voltage Regulator
  • Studio Light
  • st
  • friday_release
  • led panel repair
  • hifromkatie
    hifromkatie over 3 years ago in reply to RichG +3
    I'm quite tempted to go completely away from the original design and do a 555 based controller, the main operation of the micro was to take the potentiometer input and turn it in to a PWM to the LED driver…
  • RichG
    RichG over 3 years ago +1
    Yes a new project with a microcontroller.
  • RichG
    Yes a new project with a microcontroller. ThumbsupThumbsup
    beacon_dave over 3 years ago
    You could perhaps look at adding:
    • wireless control that allows individual or group adjustments
    • DMX interface so as they can double up as party lights
    • preset store/recall option
    • display on the back
    • strobe feature
    If you plan to re-lamp them in the future, then you could do RGB / white and then some colour temp control options.
    dougw over 3 years ago
    Presumably the MCU is controlling the power to each color using PWM. You could look at the working light to see what the MCU outputs look like. I expect you can see if the lights work just by connecting the output pad to 5V. If you only need one color at one brightness, you might get away with just using a short or a switch in place of the MCU.
  • kmikemoo
    kmikemoo over 3 years ago in reply to beacon_dave
    beacon_dave   I looked at the MCU datasheet.  It's got Read-Out Protection so there is some risk involved.  I'd go with trying to duplicate functionality - or at least "working".
  • kmikemoo
    hifromkatie  I enjoyed the troubleshooting.  I would be surprised if you haven't already fixed the light. Laughing  I'm interested in hearing how you chose to repair the light.
    Since you have the second working unit, you could perhaps look at downloading the code from that working one to reprogram a new replacement microcontroller with. Or at least use it to work out what the microcontroller does and then write new code to duplicate the functionality.
