Project Videos
  • Project Videos
Project Videos
Documents Repairing a Neewer 660 Studio light - How Hard Can It Be? -- Episode 594
  • Date Created: 9 Mar 2023 2:01 AM Date Created
  • Last Updated Last Updated: 17 Mar 2023 8:24 AM
  • Views 25015 views
  • Likes 10 likes
  • Comments 46 comments
I’ve got a studio light which has suddenly become faulty, how hard could it be to fix it rather than replace? In today’s episode I try and fault find the PCB to see if its a fault I can fix.
Watch the Video:
Bill of Material:
8 bit MCU, STM8S003F3P6TR STMICROELECTRONICS 1 Buy Now
Fixed LDO Voltage Regulator HOLTEK 1 Buy Now
Pluggable Terminal Block WAGO 3 Buy Now
Additional Parts:
Fault studio light
element14 presents
element14 presents  |  About Katie Dumont |  Project Videos
  • fault finding
  • e14p_KD
  • neewar
  • Pluggable Voltage Regulator
  • 8 bit mcu
  • Fixed LDO Voltage Regulator
  • Studio Light
  • st
  • friday_release
  • led panel repair
  • hifromkatie
    hifromkatie over 3 years ago in reply to RichG +3
    I'm quite tempted to go completely away from the original design and do a 555 based controller, the main operation of the micro was to take the potentiometer input and turn it in to a PWM to the LED driver…
  • RichG
    RichG over 3 years ago +1
    Yes a new project with a microcontroller.
    beacon_dave over 3 years ago in reply to scottiebabe
    If you are connected to different forum instances, then two people can think they were both first to reply, but when things finally sync up, you realise you were beaten to it and now look as if you have just plagiarised the previous post Scream
  • scottiebabe
    scottiebabe over 3 years ago in reply to beacon_dave
    lol I don't know, I blame vernit! Zipper mouth
  • phoenixcomm
    phoenixcomm over 3 years ago
    When I said: "Use what you have and just build a new controller." I did not mean to trash the existing PCB. You have two parts on the current PCB: The drivers, and the 5vdc power supply. So the easy way is to Remove the CPU which gave up the magic smoke. Now you have to identify all of the outputs and inputs. Then you have a choice, use the same CPU as They did or one of your own on a small PCB and wire the IO pins to the others IO pins and write the code. I would stay away from parts that have potential "death upon read" - Good Luck.
    I think I beat you to it by 4minutes Joy
  • scottiebabe
    I think we posted the same thing at the same time, nice work!
  • scottiebabe
    Shame your little MCU gave up the ghost :( As always loved the video!
    I would measure I/V characteristics of your Led strings to double check they still work and what specifications you would need to design to.
    Presumably the panel strings are being driven with a constant current floating buck. Not sure if the regulation is done by the MCU or a dedicated control chip...
    beacon_dave over 3 years ago in reply to beacon_dave
    Might want to verify that the LED and driver side is still working before jumping head-first into a new microcontroller though. Something killed the microcontroller.
    However looks like a good fevive for 'upcycling' as a lot of the tricky bits can be reused as is e.g. case with yoke attachment, barn doors attachments, battery holders, diffuser slot, rails for LED strips and so on. The single PCB looks like it could be traced and a new custom one dropped in to replace it. Perhaps all that is missing on that particular model is a cut-out for adding a LCD/OLED display.
    Do the rotary pots control the LED driver directly or are they analogue inputs into the microcontroller which are used to control the PWM to the driver ? Also, is there  a charging circuit for the camera battery pack portable power ?
    beacon_dave over 3 years ago in reply to jc2048
    Looks like two dimmers, one for the cool white (white) and one for the warm white (yellow) LEDs
    https://cdn.shopify.com/s/files/1/0225/2960/5706/products/90095562_3.jpg
    330 of each on alternating rows
    https://cdn.shopify.com/s/files/1/0225/2960/5706/products/90095562_1.jpg
  • jc2048
    jc2048 over 3 years ago
    Thanks for the video. It's interesting watching how others do these things.
    I'd have skipped pulling the caps off the board, as the probability of a ceramic cap shorting is quite low compared to a chip going.
    It's very likely for a product like this that the processor will have the code protected, so in your place I'd consider a rework with a small SBC, where you can have a bit fun later extending the functionality, rather than trying to repair it.
    It's not too clear from your video, but there appear to be two drivers and two controls. Are the LEDs split into a warm group and a cool group? And is there one control for the intensity and one for the colour temperature?
  • phoenixcomm
    First, your troubleshooting technique needs work. You did a lot of guessing. to short-circuit the debug. it would help if you wired your ps to the output rail of the regulator. to do an unpowered test of the CPU all you needed was your fluke on ohms and measured across its power lands. This would have told you you had a short on the power rail, then unsolder the regulator, the meter still says SHORT, and no burnt or blown disks would say CPU. To build a new driver, well you have half of it there. Use what you have and just build a new controller. fins. Oh, btw you can always start at both ends and work to the middle.
