Project Videos
  • Project Videos
Project Videos
Documents Building My Dream Digital Clock: DIY 7 Segment Display with a Cute Robot Twist! -- Episode 600
  • Date Created: 25 Apr 2023 3:31 PM Date Created
  • Last Updated Last Updated: 28 Apr 2023 7:24 AM
  • Views 26585 views
  • Likes 15 likes
  • Comments 18 comments
I’d like a new clock for my workshop. Cuckoo clocks are cool, but a little old fashioned. So in todays episode I’m going to see if I can do my own twist on a cuckoo clock and make a digital robot cuckoo clock.
Watch the Video:
Bonus Content:
  • Download Code and Schematics!
  •  Bike Speedometer with Arduino and GPS -- Episode 513
Bill of Material:
RASPBERRY PI PICO W RASPBERRY-PI 1 Buy Now
FEM-1801R340BGWT1 FORGE 4 Buy Now
MAX7219ENG+ MAXIM INTEGRATED / ANALOG DEVICES 1 Buy Now
MP005455 MULTICOMP PRO 1 Buy Now
AI-3245-TF-LW95-R PROJECTS UNLIMITED 1 Buy Now
PIXXILCD-25P4 4D SYSTEMS 1 Buy Now
L4940V5 STMICROELECTRONICS 1 Buy Now
LF60CV STMICROELECTRONICS 1 Buy Now
PEL00398 PRO ELEC 1 Buy Now
MC002825 MULTICOMP PRO 1 Buy Now
element14 presents
element14 presents  |  About Katie Dumont |  Project Videos
  • clock
  • e14p_KD
  • raspberry pi pico w
  • robot
  • digital clock
  • pico w
  • friday_release
  • NTP Clock
  • Cuckoo
    beacon_dave over 3 years ago in reply to hifromkatie +1
    There is an example of how to make one here: https://www.youtube.com/watch?v=ZrJpeASgGeQ The different elements can then be lit separately allowing for animation
    Perhaps have the e14 little blue robots either side that dance when the screen robot looks at them.
    I think someone tried to replace the clockwork mechanism with a motor at one point, so there should be an exploded view somewhere already.
    Could keep the clockwork and just drive it via a clutch mechanism though. Motor via gearbox winds the spring then clutch disengages when it is time to dance. This would make it easier to mount as you could use the wind up key shaft and the lower screw. Clutch will also allow the spring to unwind fully if left to run down, so that you know how much to wind it up each time.
    Simpler still, If you don't want the clutch then you can reverse the motor direction as in this case you can back-drive the clockwork mechanism and even control its speed whilst doing so.
  • hifromkatie
    hifromkatie over 3 years ago in reply to beacon_dave
    I like the robot idea!
    I know I had one here, but not sure if my kids stole it from me. I'll see if I can retrieve it back!
    Just had an idea of a clock where on the hour a door opens and the little man is behind dancing away, I think that might be cool too!
    The cuckoo clocks I have seen tend to be quite ornate, which is something that has perhaps been lost by going digital. No fancy weights, pendulums, bellows or carved mountain chalet style enclosures.
    A  a clock that I've always liked is the 'DCF77 Analyzer/Clock' by Erik de Ruiter
     https://projecthub.arduino.cc/edr1924/a13a0b1a-e11e-414a-91e1-0646cf5e3ec9
    Nice balance between the functionality and the presentation. To me, it's the digital equivalent of leaving the covers off to see the mechanism working away inside.
    You could perhaps do the weather house style clock where the 'rain man' or 'sun woman' comes out depending on the weather forecast. The animation screen could be kept behind the doors or you may want to incorporate the doors into the animation.
    beacon_dave over 3 years ago in reply to beacon_dave
    Was thinking about this some more and a common theme to the more traditional cuckoo clocks tends to be the incorporation of a miniature 3D diorama scene. Either scenic with trees, mountains and wildlife or with waterwheels and woodchoppers, some of which are animated.
    With your current design, then you might be able to replace this idea with an edge-lit multi-layered laser-engraved scene instead. Either as a raster engraving of a more traditional scene as in a diorama piece or alternatively as simple line art graphics such as robots and electronics symbols and stuff like that. By controlling the edge lighting of each of the layers you can animate it via colour and brightness. Each layer can be comprised of separate laser-cut pieces so you could have multiple objects on each layer plane that can be illuminated separately, which would reduce the number of layers and overall depth required.
  • hifromkatie
    Wow, I like that idea. I've seen individual laser engraved edge lit panels, but using multiple to make a scene and making it appear animated sounds amazing.
    I think I really need to try and get myself a laser cutter!
    A bit more geometric line art style than scenic:
    https://www.youtube.com/watch?v=6kdmqn-kbJs
    https://www.youtube.com/watch?v=E_iwSq78gWc
    might help get some creative ideas flowing.
    The 7-seg could perhaps either be cut into a higher translucent panel at the back with the transparent layers lower in front or perhaps into a surround at the front with transparent panels inside. That would allow the wiring to be hidden if you want a cleaner look. I don't think you want to be looking through acrylic to see the clock however.
    Alternatively the clock goes lower down at the front with the acrylic surrounding it and going backwards. Traditionally the cuckoo clock face is either central or toward the top of the scene but lower down may work better here.
  • hifromkatie
    That 3D one is amazing (the first link), I really want to try it now.
    Like the idea of the 7seg type display with layers, thanks for the ideas, just trying to visualise it in my head. Think it's look really cool though, separate segment on each layer, and then illuminate the layers that you need to display the current number. Also liking the idea of the robot animation through illuminating different layers, but not sure how much effect an un-illuminated layer in front of an illuminated layer would have. Think it'd be best to experiment.
    Think the main issue with all of this is the fact that I really need a laser cutter!
    If you want to go down the 'lixie' route for the clock digits, then there is an example here:
    https://www.youtube.com/watch?v=miqN2gR1Zns
    You can see the effect that 9 un-illuminated layers in front of an illuminated layer has.
  • hifromkatie
    Thats what I imagined it might look like when in front of each other. and why I started considering doing each segment of a 7seg on a separate panel, the illuminated portion will only ever have plain acrylic sheet in front of it as nothing would overlap
    You would only need 7 layers that way, so 3 less than the lixie style.
