Project Videos
  • Project Videos
Project Videos
Documents How to Use LoRaWAN to Launch Model Rockets Wirelessly -- Episode 606
  • Date Created: 7 Jun 2023 5:02 PM Date Created
  • Last Updated Last Updated: 9 Jun 2023 7:24 AM
  • Views 32333 views
  • Likes 9 likes
Launching a model rocket can be as simple as connecting 2 wires to a drill battery, but it doesn't look cool, and you must be close to the rocket itself because of the wires. Instead of doing that, I made a rocket launch terminal in a rugged waterproof case which communicates with a small rocket launcher using LoRa. The rocket is ignited using supercapacitors so that the whole system can be powered using a small 9V battery!
Watch the Video:
Bonus Content:
  • Login Required:  Download the Code and CAD files for Free!  (Register to become a Member!)
Bill of Material:
MULTICOMP PRO WATERPROOF CASE, 10.5"X9.5"X5", BLACK MULTICOMP PRO 1 Buy Now
DFROBOT LCD Board, 3.3 V to 5 V Supply, Arduino UNO R3 Board DFROBOT 1 Buy Now
MULTICOMP PRO Keylock Switch, Off-On, SPST, 2 Position, 1 A MULTICOMP PRO 2 Buy Now
MULTICOMP Toggle Switch, On-Off-On, SPDT, Non Illuminated, Panel Mount, 10 A MULTICOMP 1 Buy Now
MULTICOMP PRO Toggle Switch, On-Off, SPST, Non Illuminated, Panel Mount, 10 A MULTICOMP PRO 1 Buy Now
ARCOLECTRIC (BULGIN LIMITED) Switch Finger Guard, 3900 Series Splashproof Metal Lever Switches, Arco 3900 ARCOLECTRIC (BULGIN LIMITED) 2 Buy Now
ARDUINO RF Antenna, For Arduino MKR 1200, GSM, Micro U.FL Connector ARDUINO 2 Buy Now
KYOCERA AVX Supercapacitor, 0.6 F, 9 V, Radial Leaded, -10%, +30%, 0.5 mm, 1000 hours @ 60°C KYOCERA AVX 2 Buy Now
PROJECTS UNLIMITED Audio Indicator, 3 V to 28 V, Continuous, 90 dB, Sounder, 5 mA, Panel Mount PROJECTS UNLIMITED 2 Buy Now
MULTICOMP PRO Circular Connector, Cable Mount Receptacle, 4 Contacts, Solder Socket, Metal Body MULTICOMP PRO 2 Buy Now
Arduino MKR WAN 1310 ARDUINO 2 Buy Now
Operational Amplifier TEXAS INSTRUMENTS 3 Buy Now
MULTICOMP PRO Circular Connector, Panel Mount Plug, 4 Contacts, Solder Pin, Metal Body MULTICOMP PRO 2 Buy Now
Additional Parts:
Plastic Electronics Hardware Box
PLA Filament
M3 screws and nuts
Model rocket motor
Model rocket tube
Perfboard
Passive components like resistors, capacitors
element14 presents
element14 presents  |  About Milos Rasic |  Project Videos
  • Arduino LoRa
  • Arduino MKR WAN 1300
  • Model Rocket Terminal
  • model rocket launcher
  • e14p_Milos
  • supercapacitors
  • lora
  • Balancing Supercapacitors
  • Wireless Rocket Launcher
  • friday_release
    DAB over 3 years ago
    Takes me back to the 1960's when I built and launched rockets.
