Project Videos
  • Project Videos
Project Videos
Documents How to Run the Distance to the Moon with Strava Data and a Pico W Board -- Episode 611
  • Date Created: 12 Jul 2023 6:56 PM Date Created
  • Last Updated Last Updated: 14 Jul 2023 7:24 AM
  • Views 22057 views
  • Likes 10 likes
  • Comments 11 comments
Lorraine and her family have joined together to run to the moon! To motivate them Lorraine has pulled their running data from an online API into a multicolored ladder to the *moon. Note: the moon might be too far and may be substituted with other (closer) space objects.
Watch the Video:
Bonus Content:
  • GitHub:  https://github.com/Lorrainbow/Strava-Python-Run
  • Strava API
  • Download CAD and Code
Bill of Material:
Raspberry Pi Pico W Raspberry Pi 1 Buy Now
Pin headers 1 row of 20 pins Harwin 1 Buy Now
micro USB cable element14 1 Buy Now
Jumper Wire Kit, Male to Female, Multi-Coloured, 200 mm, 0.1" Dupont Connector, 0.2 mm² Multicomp 1 Buy Now
RGB LED strip DFRobot 1 Buy Now
USB extension cable Startech 1 Buy Now
Tiny breadboard Pro Signal 1 Buy Now
Additional Parts:
Something to run to! It could be the moon, the ISS or your childhood home
Note the light strips in the video are 30 LEDs per metre, but linked above is 60 per metre.
element14 presents
element14 presents  |  About Lorraine |  Project Videos
  • python
  • e14p_LU
  • strava
  • raspberry pi pico w
  • data visualisation
  • raspberry pi pico
  • pico
  • laser cutter
  • raspberry pi
  • strava API
  • pico w
  • circuit python
  • friday_release
  • laser cutting
  • running
    beacon_dave over 3 years ago
    Looking at edge lighting for the rungs, it appears that you can now get acrylic that is specifically designed to be edge lit:
    https://www.perspex.co.uk/materials/perspex-cast-acrylic/edge/
    It also appears that you can now get acrylic that is "...specially designed to be routered out and LEDs embedded inside...":
    https://www.perspex.co.uk/materials/perspex-cast-acrylic/spectrum-led/
    You can also now appear to get acrylic that appears black in daylight but will still transmit LED light:
    https://www.perspex.co.uk/materials/perspex-cast-acrylic/secret-sign/
    Armed with a laser cutter it should be possible to come up with some pretty illuminating results using that lot.
    While still down today's rabbit hole, I stumbled across this old Agilent application brief on "Light Guide Techniques Using LED Lamps" which some members may find of some interest.
    https://megaled.com/wp-content/uploads/pdf-for-edge-lighting-light-guides.pdf
    I'm guessing that a resin 3D printer along with some optical grade epoxy could produce some nice light pipe designs, to help edge-light laser-cut acrylic projects.
    beacon_dave over 3 years ago in reply to lorrainbow
    You could also pull in the orbit data to run an animation when the space station is overhead. This could turn it into a more generic project where it can display information / generate a reward by unlocking the lid etc. for anything with a suitable API.
  • lorrainbow
    lorrainbow over 3 years ago in reply to beacon_dave
    Genius Dave!
    Perhaps connect Strava to the cookie jar as an interlock mechanism.
    "next cookie unlocked in 4.5km..."
    "...run 9.5km for bonus cookie"
    dougw over 3 years ago in reply to lorrainbow
    Maybe you can count hours spent on e14 projects as mental fitness miles...Space invader
  • lorrainbow
    lorrainbow over 3 years ago in reply to dougw
    Or I should run more Grinning
    A variation using some of the Derby game features might be to have a 'space elevator' that carries some sort of display so that you get the cumulative distance shown by elevator position and then a percentage breakdown plus other info shown on the display.
    beacon_dave over 3 years ago in reply to beacon_dave
    As would sending your siblings to the moon perhaps...
    beacon_dave over 3 years ago in reply to dougw
    Removing a few rungs usually slows people down a bit Slight smile
    Looking good.
    I'm sure there is an in-joke in there somewhere about someone in the Computing Dept running to ISS Joy
    For motivational purposes, if you're a 'couch to 5k' runner, you could perhaps use one stile (side rail) to indicate smaller 500m increments and the other stile to indicate 15km increments. Otherwise they don't get to see much LED activity day-to day.
